Scratch that BX24...I'm getting a BX25
   / Scratch that BX24...I'm getting a BX25 #11
Changes from BX24 to BX25:
Hard reverse stop corrected
Hood and fenders changed from plastic to metal
3 pt hitch is now an extra cost option
Hydraulic pump will now move loader at idle (Slowly)
BH, Loader, engine, drivetrain remain the same.
Any I've missed?
Just that the price went up along with the changes. Seems to be about $1000 - $1500 more w/ 3pt hitch difference between the 24 and 25.
   / Scratch that BX24...I'm getting a BX25 #12
All of the above problems did not exist on the BX22/23. :rolleyes:
Guess I'll know exactly what I've got soon, as it's being delivered within the next couple hours.
Thought I'd videotape the unloading and operating run through, if the sales guy is cool with that. Whatever he explains to me, chances are I'll forget half of it by tomorrow.:eek:
   / Scratch that BX24...I'm getting a BX25 #17
Its really pretty simple to pick up. Just read the operator manual though. Things like stopping before you engage the differential lock are useful to know.
Yes, the transmission is supposed to make that whine sound.
Check your front axle fluid in about 15 hrs as it seems to settle and end up low. I would check all fluids before first use but they should be topped off by the dealer.
   / Scratch that BX24...I'm getting a BX25 #18
Ha, guess that's why they introduced the BX24, so they could add some bugs which could then be remedied (at a higher cost) in the BX25.:D
Well, no version is perfect....
The BX 23 seems to have had a few issues that I came across on a very quick search....
- Fender issue
-HST pedal sticky
Improvements with the BX24 were....
Curved FEL and BH angle of relief
More BH legroom
Protected Hoses inside the boom
cruise control
higher 3 pt hitch lift.
Thats what I came across on a quick search...
   / Scratch that BX24...I'm getting a BX25 #20
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56438)
Kuhns AE10 Small...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2014 Ford F-250 Ext. Cab Service Truck (A59230)
2014 Ford F-250...
3650 (A47477)
3650 (A47477)
