Build A Pond?
   / Build A Pond? #41
Off the top of my head, "gunite" is when you add air to concrete and spray it on. The air allows it to stick to verticle walls and even overhead applications. It's used in swimming pools for this reason.
Anything you add to your soil to make it water proof is going to be expensive. A concrete or cement base material that does not have allot of rebar will just crack and leak. Even the best clay leaks to some degree, the only sure fire, will not leak material out there is a rubber liner.
Clay is going to be the cheapest material if it's available. If not, there are just some ponds that are too expensive to make.
Eddie
   / Build A Pond? #42
A neighbor of mine just down the road built a new home and built a pond so he could use a GEO w/pond loop. The pond wouldn't hold water so that winter he had to use his emergency heat.
The next summer he tilled in Bentonite and it has held water ever since.
ben⋅ton⋅ite/ˈbɛn
tnˌaɪt
/ Show Spelled Pronunciation [ben-tn-ahyt] Show IPA Pronunciation
墨oun Mineralogy. a clay formed by the decomposition of volcanic ash, having the ability to absorb large quantities of water and to expand to several times its normal volume.
   / Build A Pond?
Re: Dump trailer. Just did a quick Craigs List and looks like 20 cyd for under $5,000 is not unusual. Suspect recent hurricane construction and trash hauling is wraping up and it may be a very good time to buy. Three questions: 1. dump angle seems to be a big factor, many pic's look like thirty or so degrees. Seems to me that bigger angle may be needed to actually dump dirt. 2. single axel with duals or tandem axel? and 3. ball hitch or goose neck. Hope I got the terms right.
   / Build A Pond? #44
Be sure you are looking at a dump that is rated for dirt and not debris. 20 yards is a massive amount of dirt and depending on moisture content, can weigh up to 80,000 pounds. 4,000 pounds a yard X 20 yards = 80,000 pounds. If it's dry, it might be half this amount depending on it's content. On the light side, figure 2,500 pounds a yard, but that's pretty light.
There is no way in there world that you have a tractor or vehicle that can handle this. 20 yards of debris, like timber framing or branches has allot of air pockets in it when loaded, so that 20 yard rating is more on volume and not weight. Debris trailers are becoming more and more popular for contractors because they do not require a CDL license. If I need stuff hauled off, I can have anybody with a drivers license tow a dump trailer, but if I want it in a dump truck, I need somebody with a CDL license. They are all over the place, but not any good for hauling dirt.
A dirt trailer will be smaller and designed for dirt. It will be obvious when looking at them. Yes, you can load dirt in a debris trailer, just be sure to stay within it's limits. Too much dirt will cause all sorts of problems, including catastrophic failure of the lift.
One of the reasons moving dirt is so expensive, it's VERY HEAVY!!!!
Good luck,
Eddie
   / Build A Pond? #45
$5,000 for a dump trailer!:eek: What are you going to tow it with? If you plan to use your tractor, you will have to hook it up, tow it to the site, unhook it, fill it carefully so the tongue weight stays right, hook up to it, tow it to the dumpsite, dump, return to dig site, unhook. . . ad infinitem. To make this an efficient operation, you really need a tow vehicle and another person to drive it. This doesn't even sound like fun to me.
I'd love to agree with you that this is a good idea, but I just can't. Why don't you see what that $5,000 will get you for a dozer in your area? Here is the way I see this working out:
Week 1 - Gee! This is really fun. Look at what I've done.
Week 2 - Still making good progress. I love having tools to do work myself.
Week 3 - Look at how the dirt is piling up. It's slower than I thought, but I'm getting there.
Week 4 - It rained a bit and I've got to get the water out before I can continue. I found a good trash pump on Craigslist for $700. I think I'll buy that and pump out the water.
Week 5 - Well, I got most of the water out, but got stuck in the mud and had to call out a wrecker to pull me out. It was only $150, so that's not too bad. Back to hauling dirt.
Week 6 - Whew! I'm still making good progress, but my back and legs are killin' me.
Week 7 - This is gonna take awhile. You guys really were right that this is a huge job for my tractor and me. I look at dozers and daydream about having one.
Week 8 - I talked to a dozer guy today. He said he'd be glad to finish my project for me for around $3000. I think I'll see what he can do.
Week 9 - Wow! That dozer got the job done quickly. Now, all I have to do is clean up and do some landscaping.
Week 10 - If anybody on TBN ever suggests that they can dig a pond with their tractor, I'm gonna tell them they should hire a dozer.
Sorry, but I just don't see a lot of happy times for you a few weeks down the line. Just please do one thing for me before you start. Find a dozen people with the size pond you want on their land. Ask all of them how the pond was put in. If anyone of them says they did it with a compact tractor, then go ahead and try it. If all of them say they used a dozer or something bigger than a compact, don't try it. There is very little reward in being the first to do it. You'll spend lots of money and maybe wear out a $20,000 compact tractor and $5000 trailer. If I didn't see a little of my own experience in my list above, I wouldn't feel this way.:)
   / Build A Pond? #46
Any dam would back water up into neighbors land. I have cut a small ditch to improve drainage over the past three years and think I can work next to the ditch so it would take exceptionally heavy rain to fill pond in progress. Then near the end I can cut into ditch area.
The simple plan-dig till I'm tired or have reached desired size. Then move dirt as needed for other projects over the next few years. Neighbor might have big tree removal project so heavy equipment help is not ruled out. I never plan projects that I can't do by myself.
Well, maybe, but just about every tank I've dug has had a spillway to allow water to bypass the dam once the tank was full. It will take a little planning and some grade work, but very possible in most cases. Or, there is the option of a flow-through tank, where the spoil is pushed to either side of the slope instead of the the deep end (think of basically digging a creek deeper rather than damming a side.) Of course, if you do not like the looks of either, then it perfectly okay to haul the dirt, that is just time and money.
If you are just going to haul on your own place, if you can get it in where you need it, and if you can find one small enough to load with your tractor, I'd go with an old dump truck rather than the dump trailer. Sure, you have an extra engine to maintain for awhile, but anything that you can do to make less trips will save you many hours over the long haul. Most dump trucks loaded way too high will haul (and still be able to dump) much more than a dump trailer loaded way too high. And if you're just going to haul on your own place, then there is no worries about tags, sticker, insurance, or being over weight.
   / Build A Pond? #47
Several years ago I had a 1 1/2 acre pond dug an average of 6 foot deep with one corner about 10 foot deep for 400 bucks. A local dirt guy took the first 4 feet for free over the course of 3 months. One day he tipped his big 4 wheel loader over on some loose dirt and we were able to get a basement digger down the road to stop by. He had a huge CAT back hoe and pulled the loader back over. As I was talking to him, he said he would come back the next week and finish the digging for 400 bucks. That machine in the hands of a skilled operator could move a bunch of dirt fast.
One thing I did was have him create an island. This helped a bunch in cutting down how much dirt the hoe had to move. I'll never forget him tracking up the side of the island swinging his bucket back and forth and when he got to the top he rotated in circles tamping down the sides.
The two things I learned were find someone willing to take the top soil and also think about an island to save dirt moving.
I finished the landscaping with my small Ford. I was working second shift at the time so most of my seat time was from midnight to 3 am using a bunch of lights on the rops. Looking back, that was a heckuva lot of fun.
   / Build A Pond? #48
An interesting variation of this idea is to leave underwater islands in the deepest areas of the pond. Above water islands can have some drawbacks, such as being very difficult to maintain. An underwater island in the deep regions can turn unused water around the thermocline into productive ambush zones for fish. My approach is to leave underwater islands about three feet below the eventual water level and then add some quality brush to the top three feet. It creates some amazing fish zones. Don't forget to mark them.
Another variation of this theme comes into play when renovating an old pond...what to do with all the tons and tons of muck. My solution has been again the underwater island of muck, ringed with good clay to hold it in place. Works for me.
The pond in my avitar has four underwater islands and its about 4 acres total size.
   / Build A Pond? #49
When I built my big pond, also 4 acres in size, I built three underwater islands that are four feet below the surface when the pond is totally full. Since I'm down a foot or two by the end of summer, that means they have 2 to three feet of water over them when we're out there fishing. The sides of my islands drop four feet to the bottom of the pond and the pond depth varies from 8 to 12 feet when full. Stumps and logs that didn't burn are piles and scaterd over the bottom as well as along the sides of the islands in places.
My small pond has an island for the very reason mentioned. Save time in removing dirt. I justified it as a place for ducks to be safe and hang out, but they rarely use it. I was hoping for ducks in my big pond, but the shoreline is too steep for them to have any feeding and the water is too deep for them. I get a few ducks from time to time, but mostly they avoid it. I don't think a good duck pond is the same as a good bass pond, and I built mine for growing large bass.
Eddie
   / Build A Pond? #50
I was hoping for ducks in my big pond, but the shoreline is too steep for them to have any feeding and the water is too deep for them. Eddie
Same here...but often we get the exhausted ducks/geese looking for a "motel". One time we had about 5 or 6 geese that were so exhausted from flying that they just crashed and wouldn''t even move when you walked up to them. Very vulnerable...but within 24 hours they were back to normal and on the wing south.
DEUTZ MARATHON...
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
2005 JOHN DEERE 310SG BACKHOE (A60429)
2005 JOHN DEERE...
2015 Peterbilt National NBT40 40 Ton Straight Boom Crane Truck (A60460)
2015 Peterbilt...
Case SV280B (A60462)
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
