Have you tried the HF metal cutting Circ Saw?
   / Have you tried the HF metal cutting Circ Saw? #1
dex3361
Elite Member
N. of Charleston WV
Kubota L4400-1 HST,FEL, 3x3 remotes, TNT. BX1500 54 mmm
I picked up the Harbor Freight Metal Cutting Circ Saw #8897 and it does a great job. I hope they come out with a 14 Chop saw style with this blade and RPM. I cut some 1/4" mild steel plate at a rate of 6" in about 40 seconds and even tried some 3/4" and at a rate of 6" in about 120 seconds. I bought the warranty as I am getting ready to start the fab of a grapple and I will put it to an endurance test on that project alone.
   / Have you tried the HF metal cutting Circ Saw? #2
I may sound like the safety police but maybe wear a decent dust mask cutting up all of that metal. Nothing like sneezing out metal flakes later in life.
This saw uses a blade that looks like a carbide tipped blade but is made specifically for metal. Its metal particles are shaved of and are about as long as the plate is thick or a little smaller and they aren't airborne so no dust to worry about but thanks for mentioning it.
   / Have you tried the HF metal cutting Circ Saw? #4
Randall, you are a busy bee. I liked the fel sub soiler, are you making a grapple for your bucket or a whole new attachment?
I am going to try my hand at making a grapple using rippers like the ones used on a box blade. I am starting with a plate like the E-bay model that I showed you in the ripper post. I am having trouble finding suitable material to use for pin bushings. I tend to do a lot more welding in the cooler weather.
   / Have you tried the HF metal cutting Circ Saw? #6
funny you say that you are rippers out of a box blade, i thought of using that on a "bucket grapple" for my bucket. i will watch and see how yours comes out. I don't know where to find pin bushing. looking at the grapples on ebay (the ones for $350) it looks like they just bolt together. i don't guess they will last as long. I thought of using solid 1/2" rod and threading each end, slip that into a 1/2" tube, with the threads sticking out on ether end use a large fender washer and locking nut to hold in place. on the out side of the tube drill and tap for a grease fitting. Don't know if that would work but thats what i was going to try.
good luck and keep me posted
brian
brian
You could try it, I have had many tries and some successes. I have just about decided to use schedule 80 black pipe for pin bushings. I was looking for a place to get hardened ones to last longer.
   / Have you tried the HF metal cutting Circ Saw? #8
That's a good idea, I bought a cheap air compressor from them that I plan to work the **** out of, and, at the end of 3 years I get a new one if it has the slightest problem. I've already taken it back once and they gave me a new one with no trouble.
   / Have you tried the HF metal cutting Circ Saw? #9
I had some pins and bushings made @ a local machine shop for the grapple i am making I think he charged 60ish which would have taken me more than hour to do. I'll get a photo if ya want. fyi grapple would a great reason to buy a plasma cutter. lol have fun welding as i have several hrs in mine already and probbly 8 more to finish it.
   / Have you tried the HF metal cutting Circ Saw? #10
if you don't mind on the photo of the bushing that would be great
thanks
brian
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2010 Dodge Ram 4x4 Crew Cab Pickup Truck (A59230)
2010 Dodge Ram 4x4...
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
