John Deere 4300 complete rebuild
   / John Deere 4300 complete rebuild #351
Paint looks great, in the pictures I don't see a difference...you have done a great job and it was really nice of you to post the progress and all of the pictures..Thanks and enjoy what you have done.
Thx, Bob. The front panels are all about 1/8" thick plastic (ABS?) with
color all the way thru. No paint. Most of mine were gone. I have $1000
in these new parts.
The rear fenders are painted green over a 3/8" thick black plastic. They
are scratched up, but not broken. I may do some touchup painting of
the gouges....we will see. I imagine these fenders must be several
hundred $ each.
   / John Deere 4300 complete rebuild #353
in these new parts.
hundred $ each.
If you know someone in an auto body shop, talk to them about the filler they use to fill in the deep gouges prior to painting in the new plastic auto front and rear bumpers. Sands down smooth and with paint gives that like new look.
   / John Deere 4300 complete rebuild #354
I probbably should not admit this, but I will... I've used the dupont polishing compounds on mine with a commercial polisher, just like you would with a clear coat after you wet sand it. The shine came right back on mine and the compound did not stick to the plastic. I did keep it moving though so it would not get warm.
Wayne
   / John Deere 4300 complete rebuild #355
Wow, that 4300 is looking great. This has been one of my favorite threads and it is amazing how much different the finished product looks to the old one. Two different worlds.
I also used the Dupont white polishing compound first, and it worked well.
I didn't want to bother getting out my electric buffer, so I tried my
bench-mounted buffer, which is primarily used for metals. Your way is better,
Wayne. And using the polish by hand got boring.
I went to look at some of the rental 4300s yesterday. I was wondering
why the mounting position of my floor pan keeps my GO pedals from
completely articulating. It sure seems that the pan needs another 1/2"
or so of height off the mounting points...at least on the right side.
Well, look at this: it looks like another rental tractor option from JD.
Under-floor armor to protect the hyd hardlines. My tractor has endured
some impacts there.
BTW, this tractor has 2709 hours on it!
   / John Deere 4300 complete rebuild #358
some impacts there.
JD did in fact have a "rental upgrade kit" for those machines...
Yes, we talked about it when I posted pix of the hood armor. I wonder:
does one rental upgrade option include all the bits and pieces? In addition
to the hood armor, I discovered some rental options to the range
shifter mechanism. There are probably others.
The under-floor armor looks very desirable.
   / John Deere 4300 complete rebuild #360
Good question...to my knowledge it's the hood armor, C-range lockout, and the stuff under the machine.
12V Diesel Fuel Transfer Pump (New/Unused) (A59225)
12V Diesel Fuel...
Set of 4 12-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 12-16.5...
Mini-Excavator Heavy Duty Grapple Attachment (New/Unused) (A59225)
Mini-Excavator...
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2015 FREIGHTLINER...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Fuel Transfer...
