Just had a big hole dug in my front yard
   / Just had a big hole dug in my front yard #111
Ok, now for the exotic stuff :D
Probably highest rated item on the spousal approval scale is the buried vehicle sensor for the driveway. It's a $250 thing that you burry beside the driveway that takes 12V DC and gives you contact closure when some big piece of metal moves within 10 feet of it. You connect it to your system and it makes a noise or says something when someone comes down the driveway.
I have two placed at two places on the driveway so I can tell if someone is coming or going. This can also be used to turn on outside lights when a car comes down the driveway. Stops most people dead in their tracks, and having the lights on is great for the home owner too.
Another fun one is the water detector. Same "12V, contact closure" device. 1st pix is a detector in the hole that the dish washer will go in. If it leaks, an automation system can do something about it. The 2nd pix is the same idea behind the refrigerator. I also have RJ-45 jacks to cat5e by all toilets, the washing machines, and hot water heaters (which are in pans with drains too).
cat5e to the kitchen ceiling and garage ceiling. You can put in heat detectors for fire alarm stuff. Cat5e for control panels for an alarm system in the master bedroom and by the garage door.
How is your cell phone service in the house? Low-E glass eats radio frequency signals. The open cell foam insulation (isocyonate?) also eats RF. The little $300 cell phone boosters need a 50 to 60' run of coax to the outside, preferably higher up in the air, to do their thing. A run to the attic would let you put an antenna up there and put the extender down in the house in the bad area. 50' run limit is not a problem if you plan it.
Lighting control is fun. Being overly frugal I cheap out and used relays. That way, a control system can turn on a light independent of the switch, but the switch still works no matter what state the controller or alarm system (be it broken or not yet installed). You can either put a relay across the contacts of a single switch or... what I did was from the switch that has the run to the light, I ran a 14-3 to a box in a closet I would have access to after everything was done and sealed up. In the 14-3, black was hot, white (with a piece of red tape on it so it won't be confused with neutral) was what used to go to the bulb, and red is the wire to the bulb. You wire nut the white and red, wire nut cap off the black, and everything works as it should. You also run a 18 gauge pair from the box to the central point. Then later you can put in a relay that can turn on the light even if it's a 2 way or N way light.
There are also after market ways to do lighting, but it cost about $130 per switch to change it out, and another $90 for the control box, and your control or alarm system has to know how to talk to the box.
Now think about the control system using the motion detectors, door switches, and driveway detector to turn on lights.
Run a cat5e outside to the north side of the house, in a protected area if possible. Then you can put in an outside temperature and humidity sensor. Enclosed is a plot from my logging system.
My septic system alarm circuit board had a space for relay. I added the relay and when I ran the power conduit to the control for the tank, I added a smaller low voltage conduit so I get contact closure if the system has any problems.
I have small current sensors that I can put in the breaker panel box on various circuits. These can be used for monitoring energy use, but also fun stuff like this: The flat cook top has a sensor. If it comes on between 11:00 PM and 6:00 AM, I hear about it. That means a cat has somehow unlocked it and turn on the stove. Have on on the oven. If it's on for more than 3 hours, I hear about it (in case someone forgot to turn it off). How about a sensor on the basement light circuit so if they are left on you can tell? So a conduit (1.5" or so) between the breaker box area and your low voltage area lets you add these as your imagination goes nuts.
I bought a water meter and put it in at the house. Have a hall effect sensor that I put on top of it where the actual meter used to be. Now I can record my water use. I can also tell if someone left the hose running.
The automation system can tell if the phone is off the hook. If it's too long, I hear about it. Caller ID is extracted from a ringing phone and sent to my cell phone as a text message. Calls are announced via the speakers in the house. So all phone stuff should be in the same low voltage wiring area.
I have antenas in the attic and an 18 gauge wire for power for amplifiers. Coax brings the antenna signal down. I have security cameras that go into modulators. I then mix those back into the cable for "off air" and it goes to TV sets so you can see the security cameras from any TV. If you do this, you'll want 3 coaxes to each possible TV site- two for satellite, one for off air and surveillance.
For all surveillance cameras, I have a coax, an 18 gauge for power, and a cat5e because sometime soon the old NTSC video cameras will all be Ethernet hi definition cameras.
On a 2nd floor window, I have a zoom camera that is focused down the driveway. We have a small 19" TV in the TV room that shows the main outside cameras. When a car comes, you can just look at the cameras and see what/who it is.
Temperature sensor in the attic. When attics catch fire, by the time the occupants find out it's too late. House also has a sprinkler system, that's a whole different topic not wiring related (except for the flow sensor...).
Not low voltage, but, I have a single 30 amp UPS in the basement in the low voltage room. It runs into a small 6 circuit panel. Certain outlet and cat5e boxes in the offices, kid computer area, box above the 'fridge, TV room, and master bedrooms feed off of the UPS. So now instead of 3-4 little ones there is one big one. The feed to the bedrooms is for grins now (no disruption of TV if power goes out while waiting for the generator) and down the road it might keep some silly machine that is keeping me alive going when the power goes out.
There are a few more really far out there things that are not available yet, but this should get you thinking.
Next: Earth to Pete, bring it back home for the rest of us :laughing:
   / Just had a big hole dug in my front yard #112
Back to earth:
So the OP is bringing a house up to code, making some changes, etc. So much like new construction time, money and sanity are at a premium. A retrofit job on a house if often so expensive and traumatic that it doesn't happen. But if you are already tearing down drywall, it's a great time to run wires.
Get the 3 types of wire (cat5e, 18 gauge, quad shield coax). All the crimpers for the cat5e and coax are available in box stores and on line. Spend $600 for 6 boxes of wire and then you can pull what you want when you can. You don't have to terminate any of it until you're ready to use it or there are aesthetic problems staring at boxes with no cover plates on them. If you're hyper-frugal you can just buy a box or two and do more pulls of the same color wire.
If you are doing any foundation or outside work, run conduit for buildings (power, low voltage, and water). See if you can run conduit out the driveway for that sensor. Note that you can use black PE pipe for this stuff. A 300' black PE run down the driveway is great for the driveway sensor. Every trench is an opportunity (see 1st pix). Don't forget the tape in each trench (see 2nd pix). You'd be amazed at how much stuff can end up in a trench (see 3rd pix). If you've got the outside of the house torn up, think about gutter drains too. I put in 4" smooth pvc that won't clog like the corrugated plastic stuff.
This is all good stuff. I'm really liking my soon to be done tractor garage having 100 amp service, water, house page, phone, security, lights, outlets, wifi hot spot and video surveillance.
Whenever a wire comes in from the outside, you'll need to put protection on it. Gas tube (like the telephone company uses) for low voltage, and spike protectors for AC. So where ever a conduit comes in from the outdoors, run a #6 bare copper wire for a ground point, and run that back to your breaker box. If you have the ground open, consider putting 100' or so of wire in there for a really good ground. I have 1200' of ground wire around the house and in trenches, but I also grounded my metal roof for lighting and as you may have guessed I'm no stranger to overkill.
Back to wiring. Put in what you can based on what you have access too. If you have that extra cat5e, you can use a pair on it for a speaker later. Find a spot in your basement for a 4x4 (or 4x8 if you can swing it) piece of 3.4" plywood. Bring your wires there. Put in small shelfs to hold stuff. I think there is enough here that you can find lots of wires you'll want to pull.
This is clearly a record post for me, but you, the OP, made the mistake of asking a geek to drone on. Whatever you do, I promise you three things:
1) You will not run all the wires you need.
2) You will run enough wires for some good stuff.
3) You will have a blast connecting it up over the years. I think I'll be about where I want to be in 1 to 1.5 years, for a total project time of 6 years on this house, and 12 years working on home automation.
This will all be better recorded in a few years with pictures from building my house. Dream, have fun, run wires.
Pete
   / Just had a big hole dug in my front yard #113
I dont know about others, but I am enjoying this thread... but then I fit into the "Geek" category rather well :D
Thanks
Aaron Z
A HUGE thanks to you for the time you put in to explaining all of that. That's exactly what I'm looking for. I'm sure my end result will be much closer to your "down to earth" explanations, but it's fun knowing what the possibilities are.
We just had the we're-over-budget-and-need-to-cut-some-costs talk last night, so I need to strike a balance between wants and needs.
Was I the only one that found myself humming the "Mission Impossible" theme about halfway through that post?
Update:
After a hiatus including a few weeks of travel for work and the requisite catching up afterwards, I'm back into the remodel. We also took some time to find another plumber. The last one up and disappeared on us for two weeks without any indication when he'd be back to finish, and he wouldn't return our calls. When my wife left the final message asking him to send us a bill because we were going to have to figure something else out, he finally called to tell us his wife had a baby. He wasn't too nice about it. I feel really bad for burning that bridge. If we'd have known, we'd have cut him some slack, but for all we knew he could have been dead. I think we have a pretty good guy as the replacement.
My wife took the kids to the in-laws for spring break leaving me to earn a living and work on the house. I cut a hole in the floor in which to put the subwater sump. I used this rotary hammer from Harbor Freight. I was pretty impressed with how it performed. The going was slow, as you can imagine; but it steadily ate away at the 6" or so of concrete until I had a nice, foot diameter hole to put the perforated bucket into.
I also did some framing between what will be the utility area and the playroom. I had to move a door in the bearing wall about 3 feet. I built a temporary wall to hold things up while I took out the old studs and put up the header and trimmers. I used the old studs from the wall I took out to fill in the old doorway. I got to use my new framing nailer. There's an art to using a framing nailer that I don't know yet. I'm catching on, though.
Now that I have the subwater sump in, the next step is to fill in the plumbing trench with concrete. Then I can move on to framing and installing the water supply lines.
We have made some more progress.
A neighboor came over with his son Friday after work. We got all of the old copper and galvanized water lines removed and new pex installed for the whole house. We worked from about 4:00 until about 10:00. I was pleased that we got it done in that amount of time. We ran new lines for two bathrooms, a kitchen, and a salon, plus the washer, dryer, two outside hydrants, and an icemaker. This also included moving the pump and pressure tank.
Saturday I took the old water heater and water lines out of the house. We also re-planted the lilac tree that they dug out when they put in the stairs. In the picture it looks like the bush is under the power line, but it's about a foot and a half to the other side of it.
The pictures below are the new home of the lilac bush, the inside of what will be the water utility closet, the Pex manifolds, and a shot of the framing and electrical from a previous post.
   / Just had a big hole dug in my front yard #117
Babies don't suddenly appear-:confused2: the lame plumber could have told you what was going on instead of vanishing like they all seem to do; then its you( the customer) who's the bad guy for trying to figure out what to do in their absence:laughing:- give yourself a break- you did nothing wrong- its all on him.:thumbsup:
You've moved on but not without being frustrated by yet another irresponsible tradesman. Keep on keepin on!:thumbsup:
Update:
   / Just had a big hole dug in my front yard #118
Oh yeah I almost forgot- to eepete, man you outdid yourself on that recent post to this thread!
You don't happen to wear an aluminum foil hat by any chance do you?:confused2::thumbsup:
Don't you worry about being around all that rf and electrical wherever you are in your house/barn? I mean they've studied stray voltage from transmission lines on livestock - I think your house qualifies as being close to the power consumed by a transmission tower or two!;)
   / Just had a big hole dug in my front yard #119
The remodel's looking great. If you're not careful it might actully look like part of the house when you're done.:D:thumbsup:
Probably not. The rest of the house is so old that this new stuff is going to look out of place.
Club Car Carryall 2 Electric Utility Cart (A55853)
Club Car Carryall...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2011 JACK COUNTY 130BBL VAC TRAILER (A55745)
2011 JACK COUNTY...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58214)
2014 MAGNUM...
2019 Troy-Bilt Pony 42X 42in Riding Mower (A55853)
2019 Troy-Bilt...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
iDrive TDS-2010H...
