JBarnes6767
- Joined
 - May 18, 2010
- Messages
 - 5
Unfortunately I found this posting and many like it all over the web on how the John Deere 2210 and 2305 has had catastrophic rear PTO failures and problems.  The reason I am here and writing this is to join the increasing number of dissatisfied consumers of this tractor.  Same situation as listed here, tilling and hit rock, slip clutch did not disengage for one of many reasons (load not significant enough, froze up, etc...) rear PTO housing completely destroyed.  Took immediately to local Koenig John Deere dealer where purchased 3 years prior, only to find out 2 days later, they have seen this exact problem before and my bill is over $6000.  $3300 of which is just parts. And wait, it gets worse.  Service manager at this dealership tells me this is a known problem and JD has since "beefed up" this transmission housing to prevent this problem.  I was in shock!  I took my broke 2305 back home to evaluate it myself because i couldnt believe they were correct.  After 45 minutes of removing parts to get into the rear transmission, my nightmare came true.  The thin, badly engineered cast aluminum housing gave way.  How JD ever expected the already brittle cast aluminum metal(only 1/8-1/4" thick on outer wall) to withstand any torque at 540 RPM under a load is insane.  And the kicker of all this is, their redesign of this is the only parts offered, so the remaining pieces i could have salvaged that were not destroyed are trash, and i have to completely replace ever part in the rear housing on my dime.  This tractor is warrantied for 36 months on the drivetrain or 2000 hours.  Of course my tractor is 6 months out of warranty and has less than 300 hours of total run time, of which only a few hours of use on the rear PTO.  A supervisor from JD is supposedly going to get back with me in the next 48 hours to discuss, but my hopes are dwendling of getting them to help  I will keep you posted as to how they handle this situation.  If it turns out to be negative support from John Deere in helping owners of the 2210 and 2305 to repair their machines, i would like to know if any other members on here are interested in joining my lead in a class action lawsuit against them.  Thanks
