Buying Advice Ballast Box vs Wheel Weights vs Filled Tires
   / Ballast Box vs Wheel Weights vs Filled Tires #61
I don't have numbers for tractors other than those that I own.
I have figured out the front axle loads for each one with the loader at it's max, allowing for a reasonable percentage of the tractor's own weight, the loader frame itself, the fact that the load is cantilevered out in front, etc and every one of them comes in WELL UNDER the front axle rating, i.e. I don't see any NEED to relive the front axles of their load.
My "SUSPICION" is that the belief that there is a need to relieve the front axle of part of it's load may be a hang-over from when FELs were a new thing and tractor designs lagged the need for sturdy front ends. Not suggesting that it goes back as far as tricycle fronts ends, but maybe to before when tractors became the Swiss Army knife with loader, back hoe, mower... and forklift duties.
I have a minor problem believing that it is a GOOD thing to add, say 1,000 lbs to the rear of a tractor to get somewhere in the order of 375 lbs reduction in front axle load to reduce wear and tear / prolong service life.
That 1,000 lbs burdens the rest of the tractor, whether there is anything in the bucket or not, so if you have a worry about wear and tear consider the empty trips TO the pile/stack as well.
OTOH, tire ballast isn't "carried", but that is a whole 'nother fun argument we've visited a few times (-:
Are you missing the point about keeping the rear end of the tractor on the ground? Several of us have said the bigger issue is keeping the rear tires down...
   / Ballast Box vs Wheel Weights vs Filled Tires #62
I'm new to all of this (8 hours seat time, Kubota L3940 4WDHST), but I did do some testing with the FEL, scooping hard dirt from a pile. I tried it without the 6 foot brush hog attached to the rear, and I tried it without. Both in standard drive, and 4WD (which is really 3WD select, but that's another thread:D). Hands down, having the weight on the rear and using 3/4 wheel drive, I could grab much more dirt because the tractor would go forward more readily, and further before getting wheelslip.
I also like the very compact nature of the factory ballast box, and I simply don't have time to fab something up. If I did, I would do so. For me, it makes more sense to purchase the solution.
Filled tires - again, as a newbie I was completely unsure about this after reading a billion threads here about it. So I chose not to go that route until I get more time with the tractor. I admit that I don't like the idea, because of the flat tire hassle, corrosion, etc. I did order a factory front weight bar, but no weights. Again, I need to see what my real world need will be.
I do know that with the FEL on the front and the 6 foot brush hog on the back, my tractor is a land yacht, which makes for quite an adventure when hogging through some of the thicker places with trees, as well as hogging the pasture near the fenced corners.
Weak front axle?? They all are.
Big Al
   / Ballast Box vs Wheel Weights vs Filled Tires #63
Big Al
Heck, I have been driving tractors for over fifty years and I still wrestle with the whole filled tires/wheel weights issue, so don't feel bad. We filled ours on the M8540 for added stability in our hills on side slopes. On our flat land farm, I think we only have one with fluid.
I strongly suggest/advise taking the FEL off while bush hogging if possible. It is hard to imagine not only the maneuverability, but ride comfort. The FEL on these models will take only a few minutes. We can have ours off in under five minutes.
   / Ballast Box vs Wheel Weights vs Filled Tires #64
No, I think Reg gets it completely. He's just commenting about those saying their front axle needs relief. I agree with Reg, don't see much gain in adding weight stress to the rear of the tractor in an attempt to relieve weight stress on the front.
Now, in TripleR's case I also agree with him. He says he can't fully use his FEL without ballast on the rear, even with filled/weighted tires.
In regards to filled tires or wheel weights, that creates what we call in the Jeep world "unsprung weight". That's the most efficient form of weight gain and does the most to lower Center of Gravity and create stability. Sometimes Jeepers will purposely use heavy wheel/tire combinations to do just that. I went from a set of light radial tires to a set of heavy 6ply Super Swamper TSLs and noticed a dramatic difference in stability. Same thing happens when fluid/weights are added. The gain is maximized because it's unsprung and always pushing down on the tire. A 3pt attachment in the wrong situation will magnify the tipping fear.
I use filled tires in my tractors. I would use wheel weights if I could find a set that were cost effective. In the case of my L4400, filled tires almost perfectly match my loaders lift ability. The tractor is very stable in everything except stupidly steep situations without 3pt ballast. I also don't think my loader will lift a load heavier than the capacity of my front axle so no worries there.
   / Ballast Box vs Wheel Weights vs Filled Tires #65
But don't forget, the rear of a tractor is designed to carry much, much more weight than the front. In smaller tractors, where the front axles seem to be even more "fragile", the rear can still take the weight.
Agree on the unsprung weigt comment... although in a tractor, the WHOLE tractor is unsprung weight. (Not a Jeep thing.)
I don't have weighted tires -- I prefer to use my ballast box. But you're right, running with a 3ph ballast box up high can really change the center of gravity - and not to the good!
   / Ballast Box vs Wheel Weights vs Filled Tires #66
For clarity, unsprung weight is weight carried by the tire/wheel combination with no additional weight stress on the drivetrain, i.e., wheelbearings, axle shaft if so designed and suspension if so designed. So in fact, unsprung weight applies to tractors as well. The weight of the tractor's tire/wheel combinations are not applying stress to those components and is commonly called "unsprung weight". This is what Reg was getting at when he said you add somewhere around 1000lbs to the stress on the rear mechanicals to relieve somewhere around 375lbs from the front mechanicals. Not a very good payoff unless you are in the situation that TripleR describes with his tractor.
   / Ballast Box vs Wheel Weights vs Filled Tires #67
This is an interesting thread. I am probably influenced by my background and what I see out by my house all the time, but the issue of too much weight on the front axle has never been one of my concerns. Like I have said previously, it takes two kids and a trained monkey to get the FEL off our 86 MF 375, so it has rarely been off and we have never had any problems with the front axle components in spite of some really heavy use. Our 98 CX80 FEL was a POS and about the only time it was off when it fell of:eek:
Our Kubotas are very different animals.
I realize this is not an apples to apples comparison, but this picture is what all the tractors around here look like and I rarely see anything on the 3-point. I have never seen anyone take weights off when the put a FEL on.
   / Ballast Box vs Wheel Weights vs Filled Tires #68
My point was on a tractor there is no suspension... so the entire tractor is unprung weight. Only where there is a suspension is there "sprung" and "unsprung" weight. Where there is no suspension, there is only unsprung weight. My other point was that unsprung weight is a term not invented by nor used specifically by Jeep owners.... which this comment kind of suggested: "... that creates what we call in the Jeep world "unsprung weight" " I say this not to be a jerk, but to help others who may be trying to understand some of this. Often these threads take a life of their own...
Also, I would say adding weight to the rear mechanicals is not an issue. That is the working end of the tractor. A couple thousand pounds of dead weight does not begin to compare the forces from say a ground engaging implement.
   / Ballast Box vs Wheel Weights vs Filled Tires #69
Stability - yes, if the speed is low and/or the terrain is smooth. OTOH, Handling/stability over bumps at some speed will become increasingly dangerous as unsprung weight increases. On an on/off road jeep Id be worried.
larry
   / Ballast Box vs Wheel Weights vs Filled Tires #70
Roger on that TR. I kept it on initially because I was unsure of how things would feel on 'the hills', and wanted to keep the bucket low. I have 3 very small 'hills' (more like ramps) that I have to mow, but they are fairly steep, and I don't cross mow, only straight up and straight down. I will have some time this coming weekend to take the FEL off and check out the difference in feel. I reckon some front weights are in the future sooner than I thought...
Big Al
   / Ballast Box vs Wheel Weights vs Filled Tires #71
I bow to your obvious superior intelligence. So it doesn't matter where you add the weight since it's all the same on a tractor because it has no springs. Stack it on the hood if you can get it to stay there..... ;)
   / Ballast Box vs Wheel Weights vs Filled Tires #72
I don't think ovrszd was saying that the term "unsprung weight" was a Jeep term at all, he is just familiar with the term from that context.
You are right, a tractor that has no suspension is ALL unsprung weight. Most tractors have at least one walking axle so there is again some room for debate. However, the correlation between the term used for a Jeep and what the point is about lowering centre of gravity seems to have been lost in the debate.
Regardless if a tractor is all or mostly or partially "unsprung weight" placing weight in or on the wheels/tires is the lowest practical place to add weight in order to afford the lowest centre of gravity for the unit overall. Keeping centre of gravity low is key to stability as has been pointed out earlier, especially when you're adding weight by lifting a load in your FEL. Carry that load a little too high and your centre of gravity goes upward dramatically...this is VERY unsafe.
And yes, WHERE you add weight is critical in terms of stability control. If all you are looking for is an unstable tractor with great traction then by all means, stack weight on top of the hood. I believe the key is to provide traction weight by at LEAST not making the tractor MORE unstable and if possible make it even MORE stable by way of lowering the centre of gravity.
   / Ballast Box vs Wheel Weights vs Filled Tires #73
A little sensitive are we? I see you don't like anyone clarifying points...
Who said it does not matter where the weight goes? In an earlier post I even said that if a ballast box is up too high it can really change the center of gravity.
If you read the entire post you would realize we agree more than you think.
   / Ballast Box vs Wheel Weights vs Filled Tires #74
Big Al
I have some similar situations on my properties and like you, when mowing these hills have my FEL on for counterweight. I tried them without and :eek:
The old saying, "Just because it can be done doesn't mean it should be done". I will also be adding weights to the front of my tractors as soon as I figure out which route to go.
My son is a pretty good welder and fabricator, so this winter, we will be looking at some way to add some railroad track sections if we can figure it out. As a last resort, I will buy factory weights.
We use a pull type bush hog, Woods DS1260, on our M8540, so we haven't had any issues with weight transfer on it, but we have only had it a few months and leave the FEL on much of the time as a "feeler".
I just got an e-mail from the dealer about the specifics of getting loaded rear tires when I buy the tractor. Here's what he said:
"We load tires with a product called Rim Guard. It is made out of Beet Juice and other natural products and is environmentally friendly. It weighs 10.7 pounds per gallon and does not freeze. To load the R4 Industrial tires would add 430 pounds to the back of your tractor and cost $157.00. We load tires at cost not making any profit on it because we feel a tractor is safer with the rear tires loaded."
I've decided to go the route of the loaded tires and the B8160 ballast box. Yes, it's gonna be a mess if those tires get a puncture and start bleeding beet juice all over the place, but for an additional $157 for both rear tires, it just seems ridiculous to pass it up. Plus, the dealership is just 4 miles away if I ever have a problem.
Update: I just discovered that Rim Guard is made from an agricultural byproduct of sugar beets (white flesh), not red beets. So no bloody stain if you ever get a leak.
John
   / Ballast Box vs Wheel Weights vs Filled Tires #76
I just got an e-mail from the dealer about the specifics of getting loaded rear tires from them. Here's what he said:
I've decided to go the route of the loaded tires and the ballast box. Yes, it's gonna be a mess if those tires get a puncture and start bleeding beet juice all over the place, but for an additional $157 for both rear tires, it just seems ridiculous to pass it up.
John
I'd love to have the tires on my BX25 loaded too. I've had the tractor about 4 days and found a nail in one rear yesterday. :( I plugged it myself in about 5 minutes. I guess it would have been a different story had there been fluid in them. It's still a tough call.
   / Ballast Box vs Wheel Weights vs Filled Tires #77
John
With Rim Guard, it will be a "mess", but it won't hurt your lawn or anything else. It sure seems like a good deal financially. There was only a $5 difference on my BX between loaded and wheel weights, so I went with weights.
   / Ballast Box vs Wheel Weights vs Filled Tires #78
How heavy are the wheel weights?
   / Ballast Box vs Wheel Weights vs Filled Tires #79
ovrszd I get what you're saying. Even though there are not springs like a Jeep would have weight in your tires or mounted on the wheels is weight that the axles and bearing will not see where as weight on the 3pt hitch is transferred through the rear diff, through the bearings, and the axle flanges to the wheels.
   / Ballast Box vs Wheel Weights vs Filled Tires #80
2010 KMC 3376 Peanut Combine (A56438)
2010 KMC 3376...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56438)
2023 Kubota...
2012 INTERNATIONAL PROSTAR+ (A58214)
2012 INTERNATIONAL...
2016 FREIGHTLINER CASCADIA TANDEM AXL MID ROOF SLEEPER TRUCK (A59905)
2016 FREIGHTLINER...
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
PJ  32 FLATBED GOOSENECK (A58214)
PJ 32 FLATBED...
