7018 Vs. 7018AC, Need Layman's translation please:
   / 7018 Vs. 7018AC, Need Layman's translation please: #41
Lack of penetration is the problem very clear in this picture. I see little
evidence of beveling. The yellow lines show the limit of penetration, does
not matter how much preheat, fancy super duper rod or post heat you use.
You have lack of fusion, it will fail.
Spoken like a true Chemical Engineer, (day job). :D
   / 7018 Vs. 7018AC, Need Layman's translation please: #42
Ron I was just going by the picture. But now I too believe they are mild steel, but you got to admit that's some nasty looking steel / break. :confused2:
It is a typical fatigue failure the material has been worked back and
forth thousands of time likely do to loose fittings. Each time the crack
widening and the surface getting micro peened, looks funky but just
plain old HR steel. See it in old Ag equipment all them time.
   / 7018 Vs. 7018AC, Need Layman's translation please: #44
Couldn't agree more!
But I'd still use 7018. With a double bevel. ;)
s.t.w.,
Thanks for the drawing, I was only 1 for 3 on proper technique.
I only had the bevel right, but I didn't have a gap at all so therefore my 'point' was non-existent.
UNUSED FUTURE 13" MINI GRAPPLE (A57193)
UNUSED FUTURE 13"...
HAMM HD120HV DOUBLE DRUM ROLLER (A52707)
HAMM HD120HV...
2017 Hino 268 Cab and Chassis Truck (A55852)
2017 Hino 268 Cab...
2025 68in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 68in Dual...
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
NEW Work Saver Skid Steer/Sub Compact Grapple (A53473)
NEW Work Saver...
