Backhoe Bucket Tooth Wear
   / Backhoe Bucket Tooth Wear #1
jinman
Rest in Peace
Texas - Wise County - Sunset
NHTC45D, NH LB75B, Ford Jubilee
My LB75B came with some nice single and double tiger-tooth teeth. In the first pictures below, you can see the condition of the teeth when delivered. I've put about 50 hours of digging in caliche and those teeth have lost their points as shown in pictures 3 and 4. Picture 5 is the relief trench I was digging in the caliche so I could break off big chunks like the one shown in picture 6. It worked really well and made the rest of the digging go quickly. Those big chunks easily break up into small football sized pieces when crushed with the bucket lip or backhoe teeth.
What I'm wondering is if anyone is as surprised as I am to see the kind of wear I am getting on these teeth? I've ordered spares that are supposed to arrive by UPS today. For digging in dirt the current teeth are fine. For caliche, the sharper and longer points sure do make digging easier. I've found a source for the twin point teeth for a little over $11 each when bought in sets of 5, and the single tooth models are a bit cheaper. However, spending $50 on teeth in 50 hours seems excessive. The caliche is very abrasive.
   / Backhoe Bucket Tooth Wear #2
Thats not bad wear at all, you may want to fab up or buy yourself a ripper.
As far as the cost thats a bargin. The teeth for my excavator are 78 bucks a piece. And in some conditions I have gone thur a set a day.
Thanks ddigger. I'm not sure what you mean by a ripper. Would that fit on the bucket/clamp-on or be something where I'd have to remove the bucket? I found a rock bucket, but it has similar teeth and I'd rather have the flat cutting edge for most jobs. A hammer on the backhoe would also be very nice, but I just can't justify the cost of adding one at this point. If I had a big scarifier tooth that I could bolt onto the bucket I'd bet I could bust up some caliche pretty well with that.
I also was surprised at the price of the teeth. I've seen them for between $17 and $20, so a little over $11 was a bargain. I only bought one set until I can evaluate their quality. I'm guessing I already know the country of origin.:rolleyes:
   / Backhoe Bucket Tooth Wear #4
There is a pocket welded either on the back or many times on the inside of the bucket with a hole in the bottem so you can slip a single shank ripper into the pocket and secure with a pin, when a ripper is needed. Here is an example of a external rear mount.
That looks super handy. I did a search online and found several installations that were similar. I have a quick attach on my bucket, so finding one that will work with that may be a little harder, but I can see one of those in my future for working in caliche and popping big rocks up. Thanks for the info.:thumbsup:
I received my shipments of replacement bucket teeth from both suppliers on the same UPS delivery truck. Both orders were placed on the 17th and delivered on the 20th via UPS Ground. The shipment from Ag Industrial (agindustrial.com) for 6 teeth was $34.19 and the teeth were $17.35 each with no mounting hardware. The shipment from Romac Industrial Parts (romacindustrialparts.com) was for 8 pieces and $21.50 with the teeth being $11.90 each including the mounting pins. On the surface, it looks like Romac is the better deal.
I've taken pictures of the parts supplied below. Ag-Industrial is at the top and the shiny one at the bottom is Romac. Romac has an oblong mounting hole and may allow the tooth some movement on the bucket stub. They both look to have identical mounting stub sizes. The Ag-Industrial part has "China" stamped inside the mounting flange, but no such stamping is found on the Romac part.
I'll install a combination of these on my bucket and see how they do with use, but if all is equal, it now appears the Romac part is the better deal. Stay tuned. . . .:)
   / Backhoe Bucket Tooth Wear #7
For hard digging I bought an 18" trenching bucket with three teeth. I replaced the worn teeth with new Tiger teeth like you have. Less teeth means more digging force per tooth. A narrower trench means less resistance to overcome. The relief trench is a good Idea, and then digging out the large chunks. When you get a large area close to grade, put the 24" bucket on to finish with. The idea of the quick coupler and various buckets is to use the correct tool for the job. The savings on teeth, wear/tear on tractor, fuel, and time should easily pay for the bucket. Plus the 18" bucket is a nice width for water,sewer, and electric lines.
   / Backhoe Bucket Tooth Wear #8
As said earlier, that's not bad wear. We have glacial till here which can really wear teeth. I've watched a 300 Kamatsu with a 24" bucket stand on it's heels while scraping 1/2" -1" of material and smoke coming from the teeth. BTW, they had tiger teeth on that 24" bucket. We had to auger some street light bases in the same area and were going through teeth on the auger every 3-4 hours.
As for using a ripper, how about getting a ripper for a box blade and fabbing up a mount to fit it on your quick disconnect? Should be pretty straight forward to make and not that expensive.
   / Backhoe Bucket Tooth Wear #9
Love to help you with this one. Where I am, it's all rock buckets and hammers, and we break the hammers.
I think I get your inference. I should quit whining like a mamby pamby and be happy I have it so easy, huh?:laughing: I suspect there's a bit of truth in that.:D
   / Backhoe Bucket Tooth Wear #11
Oh, no inference was being made. I felt bad I had no advice for abrasive wear. I can't imagine wearing out teeth in 50 hours, seems kinda fast. It's interesting to see what happens to similar machines, when they end up all over the country. What works in one place, won't work elsewhere. That's why they offer sooo many bucket/tooth options, rippers and hammers.
   / Backhoe Bucket Tooth Wear #12
No inference here. Just a lot of empathy and experiance being related to make it so you don't feel so bad about the hard ground and quick wear.:thumbsup:
Hang in there Jim. You're doing a great job on a great project. Looking forward to more updates as it comes along.:thumbsup:
   / Backhoe Bucket Tooth Wear #13
Jim,
I also am interested in your new purchase. I am fixin' to buy replacement teeth for my 24 inch bucket.
hugs, Brandi
Jim,
hugs, Brandi
Brandi, depending on your bucket's tooth style, you might be able to find cheap replacements on eBay. I'm just not sure what style Mahindra uses.
That brings up another PET PEEVE about my New Holland. I have both the Operator's Manual and the Maintenance Manual for my LB75B. Neither one of those addresses replacing bucket teeth. You'd think something requiring frequent maintenance would be addressed. If you don't replace your teeth when they are worn out, you can have cupping of the bucket's cutting edge between the teeth and you also can wear out the bucket stub and have to have the old one cut off and a new one welded on. Also, what are the different tooth styles and methods for attaching the teeth? On my bucket, if you look at the photo in the first post, you'll see that the previous owner just bolted the teeth onto the stub. From what I can determine, this is not the original configuration, but I have no documented proof of what it should be.:confused: Wacky!:(
   / Backhoe Bucket Tooth Wear #15
I suspect that you would need to find paperwork/manuals for the bucket to find that info.
   / Backhoe Bucket Tooth Wear #16
Jinman, if you go to the parts pages, there are umpteen different bucket/tooth options. You'd need a separate manual just on the buckets and teeth. Many dealers don't use the NH bh buckets, preferring to sell something heavier, such as a Geith.
Your teeth should be retained with pins, unless your abraso-soil :^) got into the holes and enlarged them, then the only option is bolts or weld the teeth on
   / Backhoe Bucket Tooth Wear #17
Try going to a Welding supply or Tractor Supply and buy some (Hard Surfacing Rod) expencive but worth it. Ask the sales person about the weld patterns you should do he will sdvise you.You see this done on the sides and bottom of most all heavy equiptment buckets.
   / Backhoe Bucket Tooth Wear #18
Jim,
My BH's parts manual has a good break down on the buckets, teeth, and wear strips. I plan on pricing teeth with Mahindra (Bradco) this week. But if, like all Bradco prices,the price is too high, I will try the place you purchased from. My teeth are blunt and square when new and the teeth now have rounded "smooth" corners.
You can make a "slip" on ripper like I plan to make a slip on grader blade. Get a box blade ripper and weld a "glove" onto it to slip over two center teeth. Then weld a short chain to it and secure the chain around the back side of the bucket to a welded hook secured with a large clevis pin.
hugs, Brandi
   / Backhoe Bucket Tooth Wear #19
Jim,
hugs, Brandi
That's a good idea. Wish I'd thought of it.:laughing: I see the scraper blades all the time, but never thought about doing it for a ripper.
   / Backhoe Bucket Tooth Wear #20
Cyril,
Your welcome. I tried a grader blade mock up with treated 2x8s with the chain and a short cable choker. It worked great.:thumbsup: I tried 6 feet for the blade, but when working close to trees, the trees won over the wooden grader blade when I was not being careful in my turning around.:eek:
I think the "glove" ripper will work if you make the glove "sides" long enough on top and bottom of the bucket.
hugs, Brandi
2020 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A60429)
2020 PRINOTH...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
PALLETS OF HEAVYEQUIPMENT (A58214)
PALLETS OF...
2009 Ford F-150 Crew Cab Pickup Truck (A59230)
2009 Ford F-150...
2005 John Deere 7420 (A60462)
2005 John Deere...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A61307)
2012 MACK Tender...
