Test drove new 3.5l TT Ford
   / Test drove new 3.5l TT Ford #71
If I was plowing commercially then I would agree but since its only going to be for maybe 5 houses every snow fall and the occasional job site where we are working the 250 would be fine. Were in an area that is basically protected from the severe snows and only get a couple real heavy snows each year and the rest is just light snows of a couple inches.
F-350 SRW is the best keep secret out there. You can go from 10,000# GVWR to 11,500# GVWR for only $600. That is pennies when you are talking about a $40,000 truck. You get more payload, larger wheels for more ground clearance, and the ability to handle more pin/tongue weight. I can not tell you how many times I see people putting larger springs or air bags trying to make a 3/4 ton into a 1 ton.
My :2cents:
Chris
   / Test drove new 3.5l TT Ford #72
My :2cents:
Chris
We have never exceeded the capacity of the 250 and I don't see things changing much. I will inquire about it though when I sit down with the dealer in the future.
   / Test drove new 3.5l TT Ford #73
My :2cents:
Chris
Not as bad as trying to make a 3/4 ton out of a 1/2 ton.
I agree that on the surface, there is so little difference between the two that why not go with a 1 ton. However in some locales, the 3/4 ton keeps the vehicle within what is classed as a "light duty" truck. Can make a difference when licensing, insuring, getting a tow, emissions testing, etc.
Air bags serve a purpose other than trying to "make a 1 ton" out of a 3/4 ton, which isn't the real reason. Air bags improve ride and act as load-levelling devices to keep the truck from squatting when carrying a heavy load. A 1 ton would just as likely require them under similar circumstances.
   / Test drove new 3.5l TT Ford #74
Quite honestly, I don't know why people order a three quarter ton truck over a one ton. By the time you add the extra weight, the payload often equals a half ton.
   / Test drove new 3.5l TT Ford #75
speaking of 3/4 out of a half ton. I head a buddy mention a hd half ton he had.. had the axles of like a 3/4 ton.. ie.. more bolts.
is this a commonly available option to get on a half ton truck?
soundguy
   / Test drove new 3.5l TT Ford #76
soundguy
They made a heavy half option. I had one on a F-150. It was a 7,700# GVWR. GM also made a 1500HD.
Chris
   / Test drove new 3.5l TT Ford #77
Do some checking on this but Dodge had 8 bolt wheels on their half ton Ram Mega Cab truck a few years back.
I want to know if I'm right or wrong on this:confused:
   / Test drove new 3.5l TT Ford #78
interesting... can't wait to see what turns up on this.
watching eagerly.. :)
soundguy
   / Test drove new 3.5l TT Ford #79
DMACE do your comments mean you're NOT going to buy a new Ford???:D
   / Test drove new 3.5l TT Ford #80
Correct, RAM 1500 Mega Cab's had the 2500 suspension/drivetrain. Now the Mega Cab is only a 2500 option and the 1500 has a full size Crew Cab.
Your powers of deduction are amazing...
20' Sea Container (A50774)
20' Sea Container...
2008 JLG 450AJ SERIES II TELESCOPIC MANLIFT (A51242)
2008 JLG 450AJ...
(INOP) JOHN DEERE 5303 TRACTOR (A51243)
(INOP) JOHN DEERE...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
Year: 2009 Make: Volkswagen Model: Jetta Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 (A51694)
Year: 2009 Make...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
