New to the Group - Considering YM336
   / New to the Group - Considering YM336 #21
Well done, Hoye has Rops, but if your place is on the flat, I don't think I would spend the money. I have never had a tractor with Rops, and I don't have a level place on my place. I just plan ahead, and then go. My back yard, I have to keep the tractor in 4wd just to go down it, if I have it in 2wd will just slide down the hill. Spend your bucks wisely is all that I am saying.
   / New to the Group - Considering YM336 #22
Congrats on the purchase!
I can almost see getting rid of the disc but not the tiller since you have both. You can never have too many attachments.
Those things cost big bucks and can put money in your pocket hiring out to do yards and gardens Id keep it until you think it thru better just go till something I bet you keep it. :D
Tail wheels are easy to come by on bush hogs they are usually made out of compressed rubber flaps anyway and they look like heck even when new. They take a beating so always use a proper tail wheel btw.
   / New to the Group - Considering YM336 #23
I believe the ym336 is 33 engine horsepower and about 26.9 pto horsepower. If the tractor is in good condition I think that is a good price , especially considering all the equipment. :thumbsup:
Should be 33hp hince the name 336. Thats the way all the others are named. And cause its a US model thats engine rated HP to the us standard.
   / New to the Group - Considering YM336 #24
Thanks again guys.... Kenmac, When I check it out, I'll let you know what I find.
Wouldn't you believe that I found a JD 4120 will all the attachments AND a tandem trailer for 3K less than the Yanmar. I think at that price, it's either a mis-print, or GONE. If I get a reply back that it's still available, I'm jumping on that. Loader, BH, belly mower, box, blade, finish mower and a 2006 with 400 hrs. It's got to be a mis print.
Best,
Don
Sounds like a CL scam!
   / New to the Group - Considering YM336 #25
Where are you, id be interested in the tiller, maybe and possibly the BH as a fixer/backup.
Im in Upstate SC
Here are pics of the rear Hyd setup. Seems simple. Ask any questions needed. Thanks for all your input CD! - Don
You will love the powershift trany. -- YES I DO!
If you get it I would really like to see how they put the rear remotes in the system pics etc.
Photos below
I also have the sister/brother to that tractor. If everything checks out to be in good working cond., with all the equip. that would be a good price.I'm intrested in knowing where the HYD return line from the loader ties into the sump
Kenmac, Looks like a honkin line that is shared (FEL and rears) and all returns back to the main pump.
Hey Joe, Where did you get your cab / fab it?
Yep, compressed rubber just as described... It's pretty beat, so I may off it and get a nicer finish mower. Good call.
You sir are correct. 33HP unit. Starts and runs like a dream. 4WD drive works well (as well as diff lock - ask me how I know) so far so good with one minor issue below.
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
