Snow plowing over gravel.
   / Snow plowing over gravel. #21
Slitting the pipe was the easypart. I used a torch on a track to slit it straight. Dealing with the residual stresses in the pipe that made it twist up took some work. The welding was the easy part.
Wouldn't eliminating the "slit" and just welding the "mounting flange" to the radius, handle the snow load? .. maybe a reinforcement gusset on the back side, here and there. ??
Thats what i did. I had some channel approx. 2" web x 1/2" flange and welded 4 slotted tabs to the pipe to bolt to every other cutting edge mounting bolt. Ill get some pictures of it.
   / Snow plowing over gravel. #23
If you just want to try out the 'pipe' edge method, go to a plumbing supply shop and buy a lenght of black ABS pipe. You can use normal white PVC stuff, but it tends to crack real easy, especially cold. I use a 2" pipe, but it really depends on how far up from your replaceable cutting edge the bolts are that hold it on. The bolts that stick out the back is what helps to keep the pipe on. After getting the right size pipe, CAREFULLY slit the pipe on your table saw. Set the fence on the saw so the blade is about in the middle of the pipe, lower the blade down to cut only one side of the pipe, wear glasses, watch fingers, etc. After you get the pipe slit, cut it to the lenght of your blade. Raise the blade up off the floor. Then spread one end of the slit open with a big screwdriver [ or whatever ] and push it onto the end on the blade to start it. The pipe should be sized so it will fit over the ends of the bolt ends [ the ones with the nuts and lockwashers ], again, this is what holds it in place on most blades. Push the slit pipe on as far as you can, which probably won't be far, then drive it all the way onto the blade with a big dead blow hammer. [ You know, the 42oz orange one that you allways use. ] The ABS is not indestructable, but will last quite a while if you don't smash it into stuff. I have never tried it, but I would like to try some big industrial rubber hose some winter. That might last longer.
   / Snow plowing over gravel. #24
I just took this picture of my slit steel pipe on the blade of a Meyer FEL plow. The pipe was slit with a plasma cutter and was driven on from the end with a hammer.
The welding shop put steel "tabs" on the pipe and set screws which bite above the cutting edge on the blade. This is a bit different than we had talked about doing.....but it should work. I'm hoping this pipe will provide a skid-shoe effect.
The pic is not very good best...but the assembly is getting sand-blasted and painted now. More pics when its done and mounted to my tractor.
   / Snow plowing over gravel. #25
There are a lot of different ways to "skin this cat".
I chose to place the attachment plate deep into the pipe so that the weld would not take all the bending stress that it would have if had just welded the exterior of the pipe to the plate. The down side of my design/fab is that after 22 years, the pipe is getting worn down and I'll either have to remove the old pipe and replace it or get a bigger pipe and weld it on over the old one. But you know, 22+ years of winter use ain't bad for any device.
   / Snow plowing over gravel. #26
I must be missing something.What holds the plate wityh the pipe on to the plow?
   / Snow plowing over gravel. #27
i agree with dave,i do the same,leave the first snow fall on there and drive on it and leave it freeze and pack it down and then you have a good base.then you will not be pulling gravel.i have a 300 ft driveway that is gravel.
   / Snow plowing over gravel. #28
Yep....that method works good on SOME years. But if the ground isn't frozen before a big snowfall.....you will have a mess. Also...if you gravel is dry it can be an issue. Also, in some areas of the country the ground may thaw and freezes all winter long. Sod is a whole 'nother issue.
In short....no ONE method is best for everyone. ;)
Ours here in central Ohio will freeze and thaw all winter long.
   / Snow plowing over gravel. #30
Jerry.....I am a little skeptical about how that pipe was attached too. My welding shop concocted this arrangement after we talked about welding a nut on the outside of the slit pipe (for a jamb-nut). (There is a 1/4" x 1 1/2" strap about 18" from each end, with a jamb-nut which rests above the plow edge....if you look real close.)
He claims it is going to hold, and his advice is normally sound.....so I let it be good for now. BUT....I could not lift my plow to wiggle around on the tube to verify his point....so it's gonna have to wait till I mount the plow.
I have the plow at the sandblast and paint shop now......after-which I will mount it on my tractor. If it looks like holding the slit tube in place will be an issue.....I may revert back to my original intent and weld a nut on the outside of the tube. :thumbsup:
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
2006 Sterling Acterra Rollback Wrecker Truck (A59814)
2006 Sterling...
2014 International PayStar 5900i Flatbed Truck (A55973)
2014 International...
2022 CATERILLAR 303.5 CR EXCAVATOR (A60429)
2022 CATERILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
