running high gpm attachments out front?
   / running high gpm attachments out front?
I cannot afford a skid steer in this crap economy, so this looks like the way to go.
My biggest fear (other than purchase price) is backing into something and trashing the unit (backing into a tree while cutting brush).
Mind if I ask you some questions?
Is the unit really easy on/off or is it a knuckle buster?
Did you run the hoses to the front yourself?
I would think you'd have to run them just like I ran my 3rd function hoses so you can lift the FEL mounted attachment without worrying about popping a hydraulic line?
I thought the Michigan unit didn't offer a cooling package? or did I miss something?
   / running high gpm attachments out front? #22
Leon - I'm going to assume, though perhaps incorrectly, that since the fan is electrical, that the fan is thermostatically controlled. Thus avoiding the overly cooled issue. But your point is well taken - one should ask that question first.
Yes I would definetly pester them with this question as cold oil is an absolute no no!!!, The problem is loss in efficiency due to hose runs to and from the implement as well as available torque to the implement.
If grsthegreat could post a few close up good pictures of the unit he owns that would help folks a lot.
   / running high gpm attachments out front? #23
Have you thought about getting a front 3pt hitch and PTO?
   / running high gpm attachments out front? #25
Yes, i ran the hoses from underneath the cab up the arms and down to the bucket. I made my own mounting brackets for the hose to mount thru the winter. I remove the entire thing come spring. I could leave it on 24/7, but i really don't need it in the summer (for now??).
The hose kit comes with both front and rear quick connects so you can drop off the powersupply anytime you want as follows.
1. Lower unit onto self mounted adjustable skids.
2. Unhook 3 point hitch
3. Unhook Quick connect from 2 hoses (supply and return) at the hydraulic tank (about 10 seconds)
4. Remove hydraulic pump (this unit slips over drawbar and slips into splines. Then theirs a bolt on bracket that secures it. Loosen t bolts and slip it off, then remove pump...about 1 minute tops)
5. drive away
i have only a few pics.. ill get some more tomorrow and post them if youd like. These show the brackets before powder coated everything
   / running high gpm attachments out front? #26
OK, here's what I don't get. Why is it so much more to buy an assembled unit than to buy the pieces? Just looking at Surplus Center, I see that you can get a 9.74 ci motor with a splined shaft rated at 20.8 HP continuous for $225(Surplus Center - 9.74 cu in VON RUDEN MLHS160S4A HYD MOTOR .
A PTO mount pump that's 9.9 ci and rated for 21 gpm and 32 HP is $526(Surplus Center - 9.9 CU IN PRINCE HC-PTO-1AC PTO PUMP CI 540 RPM).
A 25 gallon reservoir is $227 (Surplus Center - 25 GALLON HYDRAULIC RESERVOIR)
Allow another $500 for hoses, fittings and a valve and you're out the door under $1500. With the pump and the motor having the same displacement you don't even really need a valve, they will spin at the same rate and you control the motor by controlling the PTO.
Am I missing something?
By the way I think this is a great idea and it's something I've given some thought to in the past.
* I realize this is only rated for 474 RPM continuous, 563 intermittent, so it's not quite right for this application, I just picked it as a quick illustration of what's available.
also.. my unit is 3,000 PSI. the pumps and equipment your specking out is 2,200 PSI. None of the pumps at surplus center will go 3,000 PSI. These eaton pumps are real spendy.
   / running high gpm attachments out front? #27
Oh, now you've done it! Just when I thought the PTO pump was the way to go. :laughing:
Looks exotic expensive, but very cool.
Doe the front PTO work from a gearbox mounted to the rear PTO? Or is the rear PTO left free for other implements?
   / running high gpm attachments out front? #29
The large horsepower units of which there about 6 manufacturers worldwide are connected to the front end of the crank shaft and or flywheel with a reversing gear set up and are installed with thier own control set up to be operated from the cab.
The Pronovost units are set up with thier own reversing gear box in the mounting frame and are driven off the Mid Point P.T.O., BUT saying that I see no reason you could not purchase an Erskine drive unit with a front mount as the gearing is reversed with a triple gear set up coming off the rear P.T.O. too.
BUT if you have a mid PTO or can add one on your mule(depending on cost of course you can use a Pronovost kit or buy the pronovost gearbox to reverse the Erskine proeller shaft for the implement. Its still less money than a hydraulic drive and has fewer parts AND the drive is direct from the Power Take Off with near zero losses in efficiency.
The front mounts off the crank shaft allow you to keep the rear Power Take Off free for other implements; The Erskine unit is a simple on and off to free up the rear Power Take Off so its a toss up as far as what one can do BUT it would allow you to run a heavy flail mower up front like the you you currently own and a Caroni four row grass finish mower behind you at the same time witha bit more fuel consumption.
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
Set 4- 12-16.5 tires/wheel for bobcat (A53421)
Set 4- 12-16.5...
2014 FREIGHTLINER CASCADIA SLEEPER (A54313)
2014 FREIGHTLINER...
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
2018 ASV Posi-Track RT120F (A47477)
2018 ASV...
2003 Mack CH613 T/A Day Cab Truck Tractor (A52377)
2003 Mack CH613...
