Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundation
   / Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundation #41
Hmmmm......as much as I want to do it...I cannot use "used" tin on any of my projects...except the chicken coop;)
I know what you are saying. I'm planning on the tin being a temporary measure at best. I need something to keep the structure dry while I finish it. I hope I can find a deal on new tin sometime this summer so I can replace the old used stuff and do it right.
I'm paying for this shed out of my own little tractor/hobby budget. I'm building it as the money comes in for one piece at a time.
Progress report: I got the last concrete anchor bolt cemented in tonight. I assume that I did a good job on it. It was kind of dark by the time I got done. I'm planning on taking the trailer to work tomorrow so I can pick up the treated sill boards and the floor joists on the way home.
I spent another $170 today on boards for the sill plate and sub floor.
The sill plate is in.
For the base plate on the doorway, I left about a half inch of the rebar sticking out above the treated board. I put 1/2" washers over the rebar and then mushroomed the heads with a maul.
   / Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundation #45
That will work and way cheaper that threaded bolts:thumbsup:
I spent another $28.56 today for joist hangers and a 2X12 for stair stringers. I didn't make any progress on the build, though. Summer is coming and the grass is getting dry. I had to get the irrigation pump primed and ready to irrigate.
I cut stair stringers tonight. They turned out okay for my first attempt. These will be for the stairs going down into the basement level. I figured it will be easier to install the stairs now before I get the floor joists all in. I also anticipate that I'll do a bit of running up and down these stairs as I put the floor joists in.
The stairs into the cellar are done.
I used old concrete forms for the treads because I'm cheap. But, if anyone asks I'm telling them it's because I wanted the stairs to match the color of the block and the cement floor.
Next Step = Phase 3: Framing.
Hopefully I get some time tonight to start framing the subfloor.
   / Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundation #49
I used old concrete forms for the treads because I'm cheap. But, if anyone asks.....
I was reminded of Dirk Pitt, a character created by the novelist Clive Cussler. Pitt was always "Macgyverish" (thinking outside the box, creating something from nothing) and quoted as saying "Any port in a storm". So anytime I make do with what I have or is readily available - I always think of that quote!
Looks great!!
Looks great!!
Thanks for the encouragement. I think this whole project is going to be a master's thesis in making do with what I have.
2011 Western Star Trucks 4900 Tri Axle Truck, VIN # 5KJNALDR4BPBA7822 (A54865)
2011 Western Star...
Mini Standing Fire Pit (A55758)
Mini Standing Fire...
2015 Freightliner 122SD Day Cab Truck, VIN # 3AKJGND64FDGH1772 (A54865)
2015 Freightliner...
Killbros 375 Gravity Wagon (A50775)
Killbros 375...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A55302)
2019 Krause...
