Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundation
   / Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundation #41
Hmmmm......as much as I want to do it...I cannot use "used" tin on any of my projects...except the chicken coop;)
I know what you are saying. I'm planning on the tin being a temporary measure at best. I need something to keep the structure dry while I finish it. I hope I can find a deal on new tin sometime this summer so I can replace the old used stuff and do it right.
I'm paying for this shed out of my own little tractor/hobby budget. I'm building it as the money comes in for one piece at a time.
Progress report: I got the last concrete anchor bolt cemented in tonight. I assume that I did a good job on it. It was kind of dark by the time I got done. I'm planning on taking the trailer to work tomorrow so I can pick up the treated sill boards and the floor joists on the way home.
I spent another $170 today on boards for the sill plate and sub floor.
The sill plate is in.
For the base plate on the doorway, I left about a half inch of the rebar sticking out above the treated board. I put 1/2" washers over the rebar and then mushroomed the heads with a maul.
   / Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundation #45
That will work and way cheaper that threaded bolts:thumbsup:
I spent another $28.56 today for joist hangers and a 2X12 for stair stringers. I didn't make any progress on the build, though. Summer is coming and the grass is getting dry. I had to get the irrigation pump primed and ready to irrigate.
I cut stair stringers tonight. They turned out okay for my first attempt. These will be for the stairs going down into the basement level. I figured it will be easier to install the stairs now before I get the floor joists all in. I also anticipate that I'll do a bit of running up and down these stairs as I put the floor joists in.
The stairs into the cellar are done.
I used old concrete forms for the treads because I'm cheap. But, if anyone asks I'm telling them it's because I wanted the stairs to match the color of the block and the cement floor.
Next Step = Phase 3: Framing.
Hopefully I get some time tonight to start framing the subfloor.
   / Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundation #49
I used old concrete forms for the treads because I'm cheap. But, if anyone asks.....
I was reminded of Dirk Pitt, a character created by the novelist Clive Cussler. Pitt was always "Macgyverish" (thinking outside the box, creating something from nothing) and quoted as saying "Any port in a storm". So anytime I make do with what I have or is readily available - I always think of that quote!
Looks great!!
Looks great!!
Thanks for the encouragement. I think this whole project is going to be a master's thesis in making do with what I have.
(4) ELECTRIC MOTORS (A54757)
(4) ELECTRIC...
1969 Lincoln Continental Mark III (A55758)
1969 Lincoln...
MD ELECTRIC GOLF CART WITH BATTERY CHARGER (A53424)
MD ELECTRIC GOLF...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2003 CATERPILLAR 836G LANDFILL COMPACTOR (A51406)
2003 CATERPILLAR...
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51692)
2014 International...
