Amco Offset Disc
   / Amco Offset Disc
I believe that the 20 series Mahindra's came with breakaway couplers. :cool:
Brian,
These couplers are not stock. The BH had worn out one set of QDs, so I replaced with the style I have on my auger and grapple. If a hose breaks..........the remote has kicked to neutral, so not much should be lost.....right?
hugs, Brandi
   / Amco Offset Disc
Looks Good Brandi !!!!
One word of caution , over 26,000 lbs gross weight you need a CDL and D.O.T is cracking down.
Good luck and GOD bless !!
Not with farm tags. But over 20,000 pound trailers with farm tags, you need Class A non CDL or CDL. Since either requires a written test and driving test, I decided to go for a CDL. I have passed my CDL written test and this Friday, I take the driving test.
C-Ya
Scott
Not with farm tags. But over 20,001 pound trailers with farm tags, you need Class A non CDL or CDL. My trailer is rated up to 22,500 pounds. Since either requires a written test and driving test, I decided to go for a CDL. I have passed my CDL written test and this Friday, I take the driving test.
hugs, Brandi
   / Amco Offset Disc
That's looking good! Did you try resting the bucket on the neck of the trailer?it would increase your pin weight but it shouldn't be to bad. I checked it out today. On the north side of the creeks it looks surprisingly good! On the south side that I hadn't under rushed yet its another story!
Brett
Brett,
Thanks. I haul the loader on the neck of my 20 foot trailer. Only way it will fit with the BH.
Putting the loader over the neck of the 29 footer would throw the CG way forward and overgross the truck drive axle. It is just 160 pounds overweight on the truck.....according to my registration. But according to the data plate on the door, truck gvw is 11,500 pounds.
hugs, Brandi
   / Amco Offset Disc
I drilled 3 new holes in the wheel transport lock beam. I now can disc shallow if needed. Seems the cylinder leaks internally and the lock will allow about 3-4 inch penetration. Hopefully this is all that is needed for bermuda grass seed near treesl...........................which is almost all of my property.
I also installed all scrapers on front mainly for disc pan protection. It will take some time remaking all of these. I need to buy a gas ax and welder and this "after" project will need a lots of gas ax bending and shaping. I only have 11 wore out ones and need 22............11 left and 11 right hand.
hugs, Brandi
   / Amco Offset Disc #145
Brett,
hugs, Brandi
I gotcha. I registered my truck for 17k and trailer for 32k I think. It'll ever be anywhere near it but it was the same price. I think my truck is stickered for 12,200 on the jamb. It's always a numbers game. For what it's worth, if it was my set-up I'd run the bucket over the neck. Our camper is around 3k pin weight and we have literally thousands of miles with zero issues! Looking forward to seeing the setup soon!
Brett
   / Amco Offset Disc #146
Brian,
hugs, Brandi
First, I haven't looked at these since 1974 but the type I was referring to actually uncouple the QDs even under pressure without breaking anything. You have to bleed off the equipment side to re-connect but it is better than breaking 2 hoses or breaking the QD's. I am sure there are newer types available now, but they used to have a simple version that you had a short section of hose from tractor to the QDs, then a double QD frame bolted around the two couplings and was attached to the tractor. When the hitch broke, the hydraulic hoses simply pulled the collar back on the QD allowing the male end to pop out.
John Deere at the time had a patented special coupling with levers on the side that would pop loose when pulled and allowed unhooking and hooking up with the system under pressure. I would think that everyone would have this type now if you wanted them.
   / Amco Offset Disc
I'll have to visit my local friendly:rolleyes: JD dealer. He is only 6 miles from me.
hugs, Brandi
   / Amco Offset Disc
What can I tow behind the disc to help smooth out the dirt? I'm thinking a 6 or 8 inch very thick wall pipe about 10 foot long. Will this be enough to smooth it up? I would love to buy one of these Armstrong chain harrows.......http://www.armstrongag.com/Prodimages/ArmStrongAg CATALOG.pdf?#view=Fit But need to wait awhile for that purchase.
hugs, Brandi
   / Amco Offset Disc #149
How smooth or rough is your ground when you are done? How much smoothing needs to be done?
   / Amco Offset Disc #150
You might try chaining a log or a railroad tie behind your disk. I recall seeing several threads where people had done that in these forums.
   / Amco Offset Disc #151
A big piece of old chain link fence chained back from the disk helps but your turning radius gets bigger.
   / Amco Offset Disc
Sixdogs,
As it is, it is pretty smooth. I guess what I really need is a cultipacker. A cultipacker would come in real handy in seeding Bermuda grass. Just need something to go over it and knock off the high spots. Guess I will go buy a roll of chain link fence. Maybe disc, then drag fence, then cultipacker would be best?
hugs, Brandi
   / Amco Offset Disc
GreenWannabe,
A pole would work, but logs around here have too many limb knocks. A RR tie would work but. They wouldn't dig in.
hugs, Brandi
   / Amco Offset Disc
Ron,
Looks like I will go with chain link. Should the spreader bar for chain link be attached to one point on the disc or attached to two points on the disc? Guess I need to search Craigslist for some fence now.
hugs, Brandi
   / Amco Offset Disc #155
If you go with a "fence" type thing I would buy the commercially made chain harrow. They work great and do a much better job compared with a piece of fence. You can run them in two directions as well as upside down, depending on the finish you want. They distribute soil very well. The awkward part is you need a loader to load and unlload the thing.
There is also a drag type spike harrow that does a great job and either of these can be pulled behind the disc if the field is big enough so you can turn.
If you plan on packing the ground, a cultimulcher that has two packers with spring tines in the middle will do a much better job and leave a seedbed finish. A cultipacker, that has no tines in the middle, will show the tire tracks after the ground is packed because it lacks the ability to cultivate the ground after the tire tracks are left. There have been threads with photos on these topics.
Hope this helps.
   / Amco Offset Disc
It took a while, but I got the disc, tractor, and drag harrow loaded on the trailer. I put the drag harrow under the tractor, but didn't like it there. Only other place to put it is on top of the disc, which I didn't wanna do.
Anyway, I made it over to the seven acre hay patch and was comfronted with a white fenced narrow drive, beautiful house and huge barn/shop. To the right was a huge pond and buffalo...............YES........buffalo. The owner raises buffalo.
The hay patch was a triangle with a handful of huge trees in it. Very scenic. Pity I turned it into a sow's ear!
4-27-13 Seven Acre Triangle Patch...First Pass.jpg4-27-13 Hay Patch Looking Towards Neighbor's Pond.jpg4-27-13 First Pass by Neighbor's Pond.jpg
Just into the second pass, the owner came out and said it would take 3 passes. 4-27-13 Second Pass on Hay Patch.jpg
I was thinking 2 passes when I bid it. But I wanted to do right, good job. So I did 3 passes times 7 acres equaled 21 acres disc. Make that 28 acres including the final drag with the harrow. The Big RED Beast made me proud by pulling the disc and the disc even had some dirt "bulldozing" in front of the axle. So I cranked back on the leveling screw and put more weight on the rear. I pulled it all in 5th gear, but had to down shift to 4th in the low corner near the pond. The corner near the neighbor's pond had a ditch cutting across it and pulled mostly good thru it. The second pass had some wheel spinning and raising the disc slightly got me thru. The 6520 is at the bottom range of horsepower to use. If I had more hp, I would have finished way faster. But hey, it is all a learning curve. I need to move the rear disc over a little as the front disc is throwing to much dirt the rear disc is not smoothing out. So the disc has 4 bolt holes on each side and a huge center pivot bolt. So I move it counter clockwise one hole should reduce hp requirements and cure the furrow problem. I hesitate doing this as the bolts holding the gangs in position are "J" shaped bolts. Very special. I'm gonna see about buying new ones before I try to pivot the rear gang.
The discs on the right side of the disc really came out polished.
While the left side disc not so much in polish.
4-28-13 Barely Polished Left Front Disc.jpg4-28-13 Unpolished Left Front Disc.jpg
Twilight on the farm.................
Anyway, loading up after dark with me so hungry, dirty and wanting a bath (not to mention being whipped), I just dumped the drag harrow on top of the disc's new paint job and strapped it down. Way easier than tucking it up in a neat pile under the tractor. Gonna have to make a rack to go on top of the disc for the drag harrow. Really, I should have drove the tractor and disc to the hay patch, as it only was 15 miles on back roads.
While discing, I would kick the steering wheel forward and stand up here and there, but while pulling the harrow, knocking down ridges, I stood up the whole time. During all of this..........I kept thinking of my Dad while he was growing up on the farm........plowing and discing all day, just having the wind to cool him and his glass water jug that was wrapped in burlap and wetted to keep it cool. Yeah, I am stiff now, but can't wait to do it again. I have had 4 soaking hot baths since getting home Sunday night. In it's own therapeutic way.......it was all fun.
In three weeks, I go back to see the wonders of pasture rebirth and check out the baby buffalo calf!
hugs, Brandi
   / Amco Offset Disc #158
Brandi :
Thanks for update and progress report/pic's ! Really been lurking in background throughroly enjoying it. Continue to "Play safe".
:thumbsup:
Boone
   / Amco Offset Disc
Brandi :
:thumbsup:
Boone
Thanks Boone!
hugs, Brandi
   / Amco Offset Disc #160
Brandi, the next time that you disk, try running on the right side of what has been disked. You may need to start in the middle. Most guys will only do 10 passes or so and then move over and start again, but a lot of that depends on the property layout. You should find that the berms that you are now getting will pretty much go away.
2017 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59905)
2017 FREIGHTLINER...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
2010 Ford Fusion Sedan (A59231)
2010 Ford Fusion...
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
2008 Bobcat S250 Compact Wheel Loader Skid Steer (A59228)
2008 Bobcat S250...
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
