Zip ties on new Kubotas?! )0:
/ Zip ties on new Kubotas?! )0: #81
8" Plastic Cable Zip Ties 100-Pack (Black) - Amazon.com
about the cheapest ones I can find, under two cents each.
Cable Tie Accessories, Cable Ties, Wire Tie Tool, Wiring Accessories - Cable Ties Express
a whole website devoted to zip ties :cool2:
In addition to nylon, UV nylon and heat stabilized nylon, Tefzel Fluoropolymer and Halar intermediate ties are also available.
now we're talking. Ok, who knows, without looking it up, what Tefzel is? I sure don't. Halar?
looks like we all need an education on what these ties are made of, and how to identify the construction.
Now that's the best I can do, should be good for another five pages...:D
http://tnblnx3.tnb.com/emAlbum/albums/Ty-Rap/tr_material_selection.pdf
so this means we should ask for weather resistant 6.6 nylon?
/ Zip ties on new Kubotas?! )0: #82
A cable tie tensioning device or tool may be used to apply a cable tie with a specific degree of tension. The tool may cut off the extra tail flush with the head in order to avoid a sharp edge which might otherwise cause injury.
In order to increase resistance to ultraviolet light in outdoor applications, a specific grade of nylon containing a minimum of 2% carbon black is used to protect the polymer chains and extend the cable tie's service life.[2] Blue cable ties are supplied to the food industry and contain a metal additive so they can be detected by industrial metal detectors. Cable ties made of ETFE (Tefzel) are used in radiation-rich environments. Red cable ties made of ECTFE (Halar) are used for plenum cabling.
Stainless steel cable ties are also available for flameproof applications—coated stainless ties are available to prevent galvanic attack from dissimilar metals (e.g. zinc-coated cable tray).
Cable ties can be used as makeshift handcuffs. Specially constructed physical restraints called PlastiCuffs, based on the cable tie design, are used by police and military to restrain prisoners.[citation needed] Cable ties are also commonly used to prevent hubcaps (also known as wheel trims) from falling off a moving vehicle, and some are sold specifically for this purpose.
/ Zip ties on new Kubotas?! )0: #83
You really don't want a Rabbi for a Bar Mitzvah on the ties, you want a Mohel to
do a Bris.:D
Looked at one F3080 yesterday and didn't see any white ties. I'd still order another one even if I did because they are the finest mowing machine made and they (the entire mower, engine, seat and mowing deck) only cost around what some people pay to have a motor rebuilt on a boat.:laughing: But I know they will not fly over the water with water spray flying into your face, they just mow great and it's years or hours and hours before their engine ever has to be rebuilt.:) GO TIES PAGES!!!!!!!!!!!!!!:cool2:
Where's F3080's made?
/ Zip ties on new Kubotas?! )0: #85
I dont get the big deal on cable ties. Ive installed literally thousands of them. A great product. My BX has white ones too. And their tails are the same length as everybody eases here and cut square, to me that means it's "by design" and done by machine. They arent near as sharp as ones hand cut with regular diagonal pliers which can be a pain, I agree. My only issue with what Kubota has done is use the white ones. Generally they are not UV resistant and besides that, they stand out like a sore thumb.
I still dont get all the ranting in this thread, they're only cable ties:rolleyes: In this case (securing loom) they are the best, least complicated and least expensive solution.
/ Zip ties on new Kubotas?! )0: #86
I couldn't agree more.
Brian
They are a band aid lazy solution on for a mass produced machine. The engineers should have designed mounts for the wires... like most manufactures do.
There's nothing wrong with zip ties. But they shouldn't be used like this on a production vehicle. Open the hood on a Toyota and tell me how many zip ties you see. :rolleyes:
/ Zip ties on new Kubotas?! )0: #88
Not a bandaid nor lazy.
There are many times you need to secure cables and there is nothing there to secure them to besides another bundle.
The best solution is a cable tie.
Lots of manufacturers use cable ties in some form. That includes toyota and Lexus. What do you think keeps those big fat looms of wire in place? Pixie dust?:rolleyes:
/ Zip ties on new Kubotas?! )0: #89
I made a list of pros and cons for zip ties and wire holders so you can see why Kubota uses what they do.
Pro's of Zip Ties
inexpensive
Easy to install
Easy to uninstall
Strong
Can be bought anywhere, not a speciality item
Cons of Zip Ties
Can be sharp if not properly trimmed
May not look as nice as a wire holder
Pros of wire holders
Look more professional
Easy to install
Cons of wire holders
Higher cost
May break when removed, some are about a one time use
Not as readily available
Some can be sharp
Sent from my Samsung SPH-L710 using TractorByNet
Wrong... The looms are secured with clips that lock into holes in the body, etc. trust me I know. Most manufactures don't have time to fumble around with zip ties. Line speed and part count is just too high. Plus install can have quality issues (not tight, too tight, missing, not cut, etc)
Zip ties are a fine solution on custom equipment, etc. if done properly. But on mass produced machinery there's much better option out there. And that's why Kubota shouldn't use them!
/ Zip ties on new Kubotas?! )0: #92
:thumbsup::thumbsup:
/ Zip ties on new Kubotas?! )0: #93
Correct, there are mostly mounting holes with "permanent" ties , however the part that actually wraps around the wire is a Cable tie of sorts. As I said "Lots of manufacturers use cable ties in some form". There are also lots of traditional, single use cable ties found in autos too.
I dont agree that "Kubota shouldn't use them!". Look at a tractor engine compartment and compare it to the engine compartment of a car. There are lots of places where you can use a mounted tie in a car (wheel wells, rad supports, firewalls etc..) and run the wires to suit, a tractor doesnt have a completely enclosed engine bay on which to mount a permanent tie meaning that looms have to be self supporting or bundled together in free air with cable ties for support and chafing resistance.
/ Zip ties on new Kubotas?! )0: #94
Look at what I found on a 1987 Firebird.
/ Zip ties on new Kubotas?! )0: #95
Is that a cable tie of sorts? On a car? Shocking!!! Obviously Pointiac knows not what they do ;)
/ Zip ties on new Kubotas?! )0: #96
PapaPerk wants things done right the first time. He clearly has worked on industrial machinery where zip ties would be laughed at unless they were metal. The operating environment is too harsh for anything else, heat, chemicals, whatever. Applying "industrial" practices in a mass produced
product would make sense if it saved the builder money. Otherwise, are they building for the length of the warranty, five years, fifty years?
I've worked on the fifty year stuff, most of us have. Now I know the John Deere B I grew up with did not have plastic ties. Maybe they weren't invented then...:eek: and the wiring ran through metal conduits and little "fingers" or a fabric loom.
When a plastic tie is used in a moderate environment where its failure would not damage anything, then fine with me. Sort of like using duct tape on HVAC work. Yeah, you can weld every joint, but do you need to?...
But if it's "mission critical" or involves high amperage or flammable liquids, particularly if they are unavoidably near an exhaust
manifold, for example, well NO. That's what good engineering should provide for, and the bean counters have to stay away. Having owned a boat,
I am very sensitive to chafing gear. On machinery too, all that wiring running next to things. Is it vibrating? Hot?
Like all things, it's about using the right tool. Maybe not the best tool, but for a corporate entity making huge amounts of machinery,
using an adequate long life solution that saves money is likely good business practice.
Lastly, does SAE or some governing body make recommendations about the use of these in industrial practices or I suppose any practice at all?
With the right spec plastic, there is probably little you can't do with a zip tie.
That's a OEM tie for wiring... not a Wal-Mart variety WHITE plastic zip tie that will fail in 4 years from UV exposure. Apples and oranges. :stirthepot:
Plus it's simply keeping the wires and hoses together... virtually no load... it's not SECURING the hoses and cable to the car. :rolleyes:
Yeah seriously.... guess that's why there's so many new Pontiacs at the dealerships these days. :D:laughing:
/ Zip ties on new Kubotas?! )0: #99
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
2013 Ram 5500 Chassis Service Truck, VIN # 3C7WRNALXDG552597 (A61165)
2013 Ram 5500...
UNUSED FUTURE FT-ZDQ160 110V CONCRETE VIBRATOR (A60432)
UNUSED FUTURE...
FORD 4600 TRACTOR (A60430)
FORD 4600 TRACTOR...
BOBCAT T300 SKID STEER (A60429)
BOBCAT T300 SKID...
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
