Zip ties on new Kubotas?! )0:
/ Zip ties on new Kubotas?! )0: #101
does that mean you have to be a believer in them? ;)
Repeat after me.... "One Nation, Under Zip Ties, Indivisible ...."
/ Zip ties on new Kubotas?! )0: #102
I know a little about cable tie and related mounts. The company I work for manufactures high end versions of cable ties among other things. Not however the common white or black ones found on most commercial products. Equipment costing hundreds of thousands of dollars use zip ties routinely as they are the best solution considering design/producibility/operation and safety. In some cases where they are used, the failure of the system could be catastrophic and maybe cause serious injury or death.
Here are a few pics of some nice cable tie work done by one of our customers.
/ Zip ties on new Kubotas?! )0: #103
one of the things I learned by this silly thread and reading things is that by leaving the "lump" out where you can get to it, nicely cut off flush of course, one can take off the zip tie by crushing the mechanism with a heavy pliers. Therefore no sharp edges near high voltage. Never knew you could do that.
/ Zip ties on new Kubotas?! )0: #104
View attachment 336573 View attachment 336574 View attachment 336572
Beautiful work. I love a well wired panel! Makes my life a little easier
Interesting with the exposed bus bars on the door with the circuit breakers (?). Looks like some relatively heavy DC (?) judging by the cable. Aviation related?
/ Zip ties on new Kubotas?! )0: #105
Actually this is offshore platform related. Got other pics from various projects but I didn't want to overdo it here... I might single handedly keep this thread going past its usefulness :ashamed: I am of course a believer in cable ties but there is a place for them and there is also wrong places for them. Most of us are used to cheap ties but there are some exotic ties out there and slick ways to secure systems using them.
/ Zip ties on new Kubotas?! )0: #106
/ Zip ties on new Kubotas?! )0: #107
Cool. No worries here with the pics.
/ Zip ties on new Kubotas?! )0: #108
That's a OEM tie for wiring... not a Wal-Mart variety WHITE plastic zip tie that will fail in 4 years from UV exposure. Apples and oranges. :stirthepot:
Plus it's simply keeping the wires and hoses together... virtually no load... it's not SECURING the hoses and cable to the car. :rolleyes:
If that would have been on a Ford I bet I would have got a different reply.
How do you know that the cable ties Kubota uses are not some super-duper UV resistant ties?
/ Zip ties on new Kubotas?! )0: #109
Tractor is in the dark, no sunlight (UV rays). Tractor is out of the garage and hood is closed and no UV rays in engine area. Pull tractor in the garage and raise hood and still no UV rays. Pull tractor out of the garage, rais ehood and instantly all white zip ties are destroyed and start crumbling.:eek: OK, so they don't crumble instantly from that one shot of UV rays that keeps coming up, how long before the aforementioned covered hood down tractor loses all white ties?
Now speaking of white ties, I have some strings of solar lights on my porch rails and they are held on with a few white ties in the direct sun to charge solar panel and seem to be showing no isgns of deterioration after many months. What's going on with that? Could they be UV resistant white ties? I also don't have the tool to cut the ends off and they are just hanging and so far no one has complained about my quality standards but maybe they are telling everyone else and not me.
Some of you guys crack me up. I to can't let this go but I give it a few pages before saying the same thing again and again and again, that covers me for at least 3 more pages unless some one givs me some answers or questions to my post.:cool2: :cool2: :cool2: :laughing: :laughing: :laughing:
/ Zip ties on new Kubotas?! )0: #110
In the OP picture, I'd say many people are reacting to the perceived cheapness and visual distraction of the white ties, and how their installation was left.
Lacking exotic zip tie installation guns (I've used them at work, but don't own one), you can properly install any zip tie by tensioning with pliers (I like long nose), then trimming the tail with a good quality flush cutting plier. Cut tails that are left long are usually found when you try to slide your hand past them; this type of plastic is stupid sharp when cut - I'd sooner have the original tail left on, like you did John T, than a sloppy cut done.
Buying quality UV black zip ties is a short cut to getting good quality ties, that are test rated for xy pounds load. There may be other quality flavours out there, but they are not easy to find today. One of the reasons the UV black were developed was for outdoor overhead line work - yes, if they can survive that level of UV, they are overkill (in the UV respect) for many personal apps, but I'm OK with that.
To filter out the junk made in Asia, I only buy made in USA (will take Canada too, just haven't found any yet) UV black zip ties. Even on my present budget, I don't mind paying for that level of consistency.
The 2000 multi coloured ties in a tube have their place - If I was heading to help setup snow fence at a volunteer event, I'd grab a tube of those - they only have to last a weekend or so. Amongst those 2000 there may be some OK quality ties, but I'm not interested in testing to find out..... I'd sooner just pay the premium for the good ones.
This is a bit like debating gear hose clamps.... some folks want cheap, other folks gladly pay for full stainless. As long as your stuff hangs together the way you want, it's all good :thumbsup:
Rgds, D.
Rgds, D.
Exactly. It's not perceived cheapness... It is cheap!
The fact that an OEM (Kubota) does this is pathetic. At least cut the darn things off properly and make them white.
As 4Shorts said... The Zero turn mowers have tons of these zip ties that are cut long. I saw a ZD326 that had at least 6 just above rear tire area. They look trashy. No pride in workmanship. Kubota has alway made a quality product... Maybe the US assembled stuff is where the problem lies with the zip ties. Bubba quality control just don't care.
/ Zip ties on new Kubotas?! )0: #115
One of the reasons zip ties were developed was to reduce the skill level needed to loom wiring. Proper MIL spec wire lacing is a bit of an art form - somebody had to be trained to do that, had to care about their work, and know that they were being closely watched - it was a different world.
Production zip tie guns are set to pull to a given torque, and cut in a specific manner. Beyond roughly placing the zip tie, basically no skill is required to operate the zip tie gun (enabling the use of that all important cheap labour).Chances are the body on the production line at Kubota is doing exactly what they are being told to do - volume/hour is mostly all that matters.
What would be worth doing is a clearly shot video of these lame zip ties on these new Kub's, and posting it to Youtube with an appropriate title - "Lame zip ties on a $15K Kubota tractor ?". TBN'ers alone could get the View Count going.... after enough hits, perhaps Kubota Marketing might pay attention.
Rgds, D.
/ Zip ties on new Kubotas?! )0: #116
good machinery should work well and perform above expectations.
great machinery looks good doing it...:thumbsup:
we could put much larger numbers on those "lame zip ties" post.
When the value hits $50k does it become even lamer?
How about at $300K, or even $2M, like a sixteen cylinder diesel generator.
I looked at the Ty-Rap website. It reminded me that most of the tie wraps we see are like the candy at the
check out counter, junk. We just need to search for the good stuff, and use the gazillion assortment tube we all have to
wrap our pc cables with.
I wonder if one could use a metal zip tie as a tiller shear pin...
now there's a test of one's metal....;)
/ Zip ties on new Kubotas?! )0: #117
They make stainless steel zip ties for high temp applications. I use them to secure asbestos type wrap to exhausts.
They work great but tear up your fingers.
Asbestos? Yikes! Thought they made exhaust wrap out of safe stuff now.
/ Zip ties on new Kubotas?! )0: #119
I can honestly promise you that whether your 'white ties' are UV resistant or not.............very few on this thread are gonna buy your porch............or lights............because you admitted to not cutting them off. And that poses a danger to every living being ;)
I mean.......you could potentially cause a severed foot on a bird...........or even a chipmunk :)
There was a guy here on TBN, that posted a picture of wire ties on his ROPS to keep the birds from pooping(can I type that?) on his seat..............I reported him to the ABCDEFG..................and I hope that nail him :laughing:
But on a lighter note............wait til spring.............dunno what it is about the winter months. But come spring, your ties will probably be broken. (I personally think it's a combination of the cold air temps.......and the heating of the sun).
/ Zip ties on new Kubotas?! )0: #120
I will report back in the spring how the ties (Harbor Freight cheapo's) are working or dead since this thread will still be active then. :laughing:
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A61307)
2021 Unverferth...
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A61306)
Bulk Lot of NEW...
UNUSED SDLANCH MINI EXCAVATOR RIPPER (A60432)
UNUSED SDLANCH...
UNUSED ZJG ZJ-08 MINI DIGGER (A60430)
UNUSED ZJG ZJ-08...
