Wider front tires M7040 Kubota
   / Wider front tires M7040 Kubota #1
KenBike
Wakeman, oh
Kubota M7040
My front tires are the stock 9.5 24 R1's and want to install wider tires for less compaction and wider front stance.
Willing to swap rims so if you have made this conversion or source please devise.
I use it for my small hay operation.
   / Wider front tires M7040 Kubota #2
Welcome to TBN from Ea WA state. I have seen threads on TBN discussing this subject. Enter "7040 tires" or "7040 tire swap" or the like to find these threads.
   / Wider front tires M7040 Kubota #3
I just got a M7060 with wide tires when I go to my shop tonight I'll let you know the size
   / Wider front tires M7040 Kubota #4
Check the back tire sizes also. There could be a difference in overall height of your rears and his which could throw the ratio out of whack for the 4 WD. He has to keep the same rolling circumference on the front tire as he has now.
   / Wider front tires M7040 Kubota #5
   / Wider front tires M7040 Kubota #6
You could get by with a little bit less in rolling distance but I wouldn't go more as the fronts are already pulling the backs along by about 5% as per design. SO the fronts are always spinning a bit faster than the rears which does cause a bit of excess wear. I noticed this on both my tractors and I rarely get them on the asphalt (2 WD always on hard surfaces)so all the wear is from grass and dirt spinning.
   / Wider front tires M7040 Kubota #7
In addition, you could consider radials along with wider. I put radials on my JD 5520 (18.4x34 and 12.4x24 equiv) and the compaction difference is considerable. I have mowed the lawn with it and not left marks beyond the grass.
   / Wider front tires M7040 Kubota #8
NO!!! In 4WD you either have lead or lag. Lead is the front turning further than the back and lag is when they turn less. It is ok for the front to "pull" along faster than the rear, but to have them slower you create quite a bind on the drivetrain. The front even in vehicles will usually have lead. When turning, the front tires have to travel farther anyway. So if they were set at the exact same, you would bind the drivetrain anytime you turned.
I checking on a purchasing tires and rims the same size as Canadian dealers sell locally. My stock 9.5 24 tires are 41.5" Dia. and the metrics in Canada are 41.2" Dia. Hopefully this works out and saves me a trip across the border.
   / Wider front tires M7040 Kubota #10
I hope you have done the math on the rolling circumference match--just to be safe-- so the fronts are compatible with the rears. Get it wrong and you will screw up the front axle about the same time you chew up the front tires. An easy way is to go with the tire combinations Kubota suggests--and they have LOTS of combos to choose from. Kubota is famous for that. Check the website or the whole goods books at the dealer.
   / Wider front tires M7040 Kubota #11
Canadian sold M7040/7060 come with 320x20 tires which is a 12.4 x 20 tire. This is not an option in the USA, so I looked into doing it on my own, the cost was $2800 mostly due to the rims. This is the biggest reason I would not buy this tractor. The rear tires stays the same.
11.2 x24 is too tall and will damage the axel/trans once the tractor gets 800 or so hrs on it. I needed the floatation bigger front tires give.
   / Wider front tires M7040 Kubota #12
I'm pushing 750hrs with the larger tires will see,almost to the 800hr mark.
   / Wider front tires M7040 Kubota #14
   / Wider front tires M7040 Kubota #15
If Kubota thought they could put bigger tires on the tractor don't you think they would do it from the factory?
I met one of their engineers at a dealership when I was looking at the 7040 and spoke of bigger tires on the front and his suggestion - get the 8540. You will have problems it is just a matter of time if you exceed the 5% difference in the rolling circumference.
I agree that is why I am getting the wider tire with the same diameter as the stock 9.5 24. Do you think Kubota would sell a wider front tire in Canada just to tear the front axel up?
   / Wider front tires M7040 Kubota #17
No, I do not think Kubota would sell a wider front tire in Canada just to tear the front axel up. The 12.2 x20 is same rolling circumference as the 9.5 x 24. I wish it was a option here in the USA.
I found Miller tire who has a ad on the site can supply tires and rims in the wider size. They have a manufacturer custom build the rims in about 3weeks after order. If all goes ok should have the new setup by early December.
   / Wider front tires M7040 Kubota #19
I think Gary understands this. He is simply making a statement that more revolutions and added drive train engagement cause a bit more wear for which he is absolutely correct.
   / Wider front tires M7040 Kubota #20
Which tire is Miller offering you in 12.2-20 and price? I'm not finding anything close on their site and the 9.5 cookie cutters have got to go. They're tearing my place up and starting to really irritate me.
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56438)
Kuhns AE10 Small...
Year: 2014 Make: Acura Model: MDX Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 183,948 Plate: (A59231)
Year: 2014 Make...
BOMAG BW213 SMOOTH DRUM ROLLER (A58214)
BOMAG BW213 SMOOTH...
2461 (A58376)
2461 (A58376)
CAT 777B ARTICULATED DUMP TRUCK (A58214)
CAT 777B...
2007 Western Star 4900 (A56438)
2007 Western Star...
