Mosin-Nagant hex receiver
   / Mosin-Nagant hex receiver #41
   / Mosin-Nagant hex receiver #42
my 44 vkt m39 is on a 1917 tula receiver.. ;)
Yeah, it would be cool to be able to link it back to Imperial Russian manufacturer. Did they (the Finns) intentionally deface/remove Russian/Soviet markings like many captured Germany guns where. That weird marking on my receiver looks like it might have been something, and then ground down under Finnish 'remanufacture'
   / Mosin-Nagant hex receiver #44
the vkt i have still shows the imperial russian crest on the receiver, plus an AZF capture mark. ( AZF marking meaning the rifle was captured in WW1 by the Austrians from the Russians and then sold or given to the Finnish who used its receiver for this rifle )
on sako units you can find small buffed marks where they buffed out the imp russian crest. ;)
to find the original date I had to pull the action from the stock and look at the bottom of the tang.
I ready some where, about an Imperial Russian Mosin that had Austro-Hungarian artillery unit marks, that ended up in Finnish hands; imagine if that gun could talk.
Think about the life story of the STG-44's that popped up in Al-Nusra's slimy hands a couple months ago in Homs.
   / Mosin-Nagant hex receiver #46
I see some with civil guard marks too.
I'm always on the lookout for antique receiver models too. ;)
Tula / hex receivers are my favorite
   / Mosin-Nagant hex receiver #47
Wondering who is making ammo for those?
To research my own question, apparently privi partisan out of Serbia still makes 7.92 x 33. And it can be created from cut down 308 Winchester cases
Czechoslokia made MP-44/Stg-44 post war, so I assume large amounts of ammo where made for it at the time; I've also seen mention of its manufacturer in Egypt/UAR (United Arab Republic: united Egypt and Syria);
Hmmm, seems that AK rifles in semi auto only are made in 7.92x33 (8mm Kruz) in Pakistan, for civilian use because 7.62x39 is "military only";
As a side note I read about 8mm x 56mmR Mannlicher ammo used in India in .303 English rifles; because the .303 is a "military only" round
Edit: Look up AK 44 bore; pattern 44 rifle; seems they are using 8mm Kruz in standard Ak47 barrels will reamed chambers in the tribal territories
2019 GALYEAN...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
Forklift (A56857)
Forklift (A56857)
2003 PETERBUILT PB330 DUMP TRUCK (A60430)
2003 PETERBUILT...
2014 LOAD KING BELLY DUMP TRAILER (A58214)
2014 LOAD KING...
2013 Mack GU713 T/A A-Frame Gin Pole Truck (A60460)
2013 Mack GU713...
