Mosin-Nagant hex receiver
   / Mosin-Nagant hex receiver #41
   / Mosin-Nagant hex receiver #42
my 44 vkt m39 is on a 1917 tula receiver.. ;)
Yeah, it would be cool to be able to link it back to Imperial Russian manufacturer. Did they (the Finns) intentionally deface/remove Russian/Soviet markings like many captured Germany guns where. That weird marking on my receiver looks like it might have been something, and then ground down under Finnish 'remanufacture'
   / Mosin-Nagant hex receiver #44
the vkt i have still shows the imperial russian crest on the receiver, plus an AZF capture mark. ( AZF marking meaning the rifle was captured in WW1 by the Austrians from the Russians and then sold or given to the Finnish who used its receiver for this rifle )
on sako units you can find small buffed marks where they buffed out the imp russian crest. ;)
to find the original date I had to pull the action from the stock and look at the bottom of the tang.
I ready some where, about an Imperial Russian Mosin that had Austro-Hungarian artillery unit marks, that ended up in Finnish hands; imagine if that gun could talk.
Think about the life story of the STG-44's that popped up in Al-Nusra's slimy hands a couple months ago in Homs.
   / Mosin-Nagant hex receiver #46
I see some with civil guard marks too.
I'm always on the lookout for antique receiver models too. ;)
Tula / hex receivers are my favorite
   / Mosin-Nagant hex receiver #47
Wondering who is making ammo for those?
To research my own question, apparently privi partisan out of Serbia still makes 7.92 x 33. And it can be created from cut down 308 Winchester cases
Czechoslokia made MP-44/Stg-44 post war, so I assume large amounts of ammo where made for it at the time; I've also seen mention of its manufacturer in Egypt/UAR (United Arab Republic: united Egypt and Syria);
Hmmm, seems that AK rifles in semi auto only are made in 7.92x33 (8mm Kruz) in Pakistan, for civilian use because 7.62x39 is "military only";
As a side note I read about 8mm x 56mmR Mannlicher ammo used in India in .303 English rifles; because the .303 is a "military only" round
Edit: Look up AK 44 bore; pattern 44 rifle; seems they are using 8mm Kruz in standard Ak47 barrels will reamed chambers in the tribal territories
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
Trailmobile Van Trailer (A56438)
Trailmobile Van...
2015 CAT 950M Wheel Loader (A55272)
2015 CAT 950M...
2015 Ford Escape SUV (A59231)
2015 Ford Escape...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A55745)
2012 NORAM POWER...
Case IH MX270 Tractor (A59814)
Case IH MX270...
