Why are deck over trailers (usually) only rated for 10k?
   / Why are deck over trailers (usually) only rated for 10k? #11
I highly doubt that 2" ball coupler (or the ball itself) is rated anywhere near 15K#. If either component is rated for less, hauling more presents a liability problem in the event of failure.
What do you think the pintle part of my truck hitch is comprised of? A ball (2 5/16" I think) and a clamp over top to close the loop.
The other trailer may be a 2 5/16" and not 2", but still. The style of hitch should not indicate whether the trailer is a bumper pull or not heavy duty.
   / Why are deck over trailers (usually) only rated for 10k? #12
The highest rated 2" ball I have seen is around 7,500lb. I have seen pintle hitches rated at 100,000lb. The ball hitch pintle combo you are talking about is designed to be handy for people moving light trailers with different hitch styles. This is the hitch I have on my dump truck. 50-Ton Pintle Hook, 6-Hole Pattern (PH50) | Welcome to Buyers Products Company It is rated for a 100k trailer and a 20k tongue weight.
A hitch doesn't always dictate the strength of a trailer but when a trailer has a 2" ball you know it can't be good for much more than 7,500 lb and when you see a trailer with a heavy pintle ring it just might be stout enough for a bull dozer.
   / Why are deck over trailers (usually) only rated for 10k? #13
This is the hitch I have on my pickup. It is overkill for sure but it is what I have. 30-Ton Pintle Hook (PH30) | Welcome to Buyers Products Company Note it is rated for 60k gross and 15k tongue.
This is similar to what you said you have - HITCH,COMBINATION,RECEIVER MOUNT,6TON,2-5/1 (RM62516) | Welcome to Buyers Products Company note it is only rated for 12,000 lb gross and 2,000 lb tongue.
   / Why are deck over trailers (usually) only rated for 10k? #14
Why does the connection matter? The equipment trailers I use for work can carry up to 15K, one is a 2" ball hitch, one is a pintle. Dont think one being a pintle automatically makes it heavier duty.
Pretty scary that you are selling trailers.
   / Why are deck over trailers (usually) only rated for 10k? #17
Care to explain? I was simply pointing out to another poster that if you see 10K trailers, and one has a pintle and one with a ball that does not automatically make one more heavy duty than the other.
However, I do appreciate your concern on my ability to sell trailers. :rolleyes:
   / Why are deck over trailers (usually) only rated for 10k? #18
Care to explain? I was simply pointing out to another poster that if you see 10K trailers, and one has a pintle and one with a ball that does not automatically make one more heavy duty than the other. However, I do appreciate your concern on my ability to sell trailers. :rolleyes:
I think the concern is you think a 15k trailer can be pulled with a 2" ball. We all make mistakes when we post but if you sale trailers the weight limit on hitch setups should be common knowledge for you.
   / Why are deck over trailers (usually) only rated for 10k? #19
   / Why are deck over trailers (usually) only rated for 10k? #20
I corrected myself in a later post, it is a 2 5/16" ball.
Also, its "sell" not "sale".
PJ  32 FLATBED GOOSENECK (A58214)
PJ 32 FLATBED...
Kubota B2301 (A53317)
2010 Club Car Electric Cart (A56859)
2010 Club Car...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
E-Z Trail 20' Head Cart (A59814)
E-Z Trail 20' Head...
2017 FORD TRANSIT 250 CARGO VAN (A59575)
2017 FORD TRANSIT...
