roadhunter
Elite Member
It looks like if you want one, you're going to have to wait a few months... Reserve now, more stock arriving October, 3rd. Call 1-855-476-6455 to reserve.
The factory in China is making another batch!
So I went to Woodlands website and downloaded the operators manual. In there it says to remove stabilizing pin before using. So I went to the parts diagram and figured out what the stabilizing pin is for. The stump grinder is mounted on a swivel and if you try to chew through too much the grinder just swings back. So that means that you can't feed it too much. Therefore there should be no problems using this with a shuttle type tractor as long as it has a clutch.
I also wouldn't mind seeing a video of an actual owner using this grinder. If someone wants to send me this model of grinder I'll gladly post a video. Send me a pm for shipping info!
I'd love to buy one myself as I have a few stumps to take care of. $3000 with extra teeth, shipping and taxes is just a bit out of my budget range right now.
I could really use a stump grinder but those things can be very pricey. Some cost as much as a backhoe. I saw this one and it seems like it's made to get the job done and doesn't cost as much because it seems the design is much more commonsensical than the others I've seen for much more money. No gear box needed, no extra cylinders or hydraulics needed etc. Simply connect to 3pt and get to work. Has anyone here used one of these? If so, how was it?
WG24 Stump Grinder | Woodland Mills US
It's worked out magnificently. Two stumps, one about 12" and the other 24" on the same residential property took about 1/2 hour, including extensive root systems. They were both overgrown ewe shrubs that had been about 35 or 40' high. I think the "chat" on the Woodmills site is a robot. You have to get them on the phone. There was a one week delay in the arrival of my grinder. It actually shipped to Philadelphia from a New York City warehouse. I'm not sure what might be going on with that.
So here's my impression: The grinder arrived on a steel pallet with 2 x 4" steel tube runners. The cardboard box was framed with steel angle and slats. I used it with a 1025 FILB with a Curtis Cab that has 18 hp at the rear PTO. It mounted right up without need for any cutting of the PTO shaft that came with the grinder. It is VERY beefy and looks expensive compared to the junk available for rent at HD. The 1025 Deere will raise it 15" from the grade. It is designed to be pulled through a stump. It has 34 brazed carbide chips that remained razor sharp after grinding through buried roots and stumps. The little Deere did get bogged down from time to time in damp clay, but with a hand on the lift while pulling the grinder through, it was easy to avoid a stall by raising it slightly. I left the rear window on the cab and it was good that I did because it chucked wood chips at me. I pulled the sway turn buckles super tight and have Pat's hooks on the draft arms, so to detach the grinder, I had to loosen up everything again. The Deere would sway on Turf Tires, but nothing scary. The lift height and short wheelbase made it very easy to maneuver the grinder over the stump inches at a time and by hard steering, the grinder moved laterally atshallow angles quite nicely. I would take this arrangement over the side to side hydraulic grinder any time. Sitting sideways in the seat (had to remove the arms from the swivel seat because of the cab), with a gentle left foot on the hydrostatic forward pedal, steering with a suicide knob, it was actually fun watching the chips fly. When the tractor was level, the grinder actually pulled itself through the stump at the rate it liked, with just a little assist here and there on the pedal. No need for extra hoses or hydraulics.
Harbor Frieght sells diamond carbide saw blade sharpeners and wheels really cheap. Disassemble the sawblade frame from the grinder motor and you have a nice sharpener for the carbide bits.
It exceeds my expectations and 18 hp PTO does drive it acceptably.
Ken
update: I have a tracking number as of this morning. The grinder has already made multiple stops en route but it doesn't give an arrival date. It does say the package is 518 pounds.
update 2: The carrier says I'll have the grinder 10/24 (Monday).
However, if your continued research interferes with action you may never "pull the trigger" as they say here.You can never do to much research.
You're going to get those stumps one way or another. I have see this one and it does look like it would work.
A couple of things I've noticed. It would appear the tractor would need position control on the 3 point. I am leary of any attachments being directly coupled to the pto shaft. If the chipper suddenly stops, and there is no shear pin or gear box, the only place for that energy to go is straight to the tractors gear box.
Hopefully someone has one and offers some input...
Unboxing pics!Well, mine arrived today. Now if I can just get time to unbox it and use it...![]()
Unboxing pics!
Interesting. I wonder if the slip clutch needs to be adjusted down for your tractors hp so it doesn't stall the tractor. Looking forward to the pics.
