What did you do to your Yanmar today?
   / What did you do to your Yanmar today? #51
I guess the tags there on the side of the loader don't reveal anything. Big bucket for sure. I don't think it is a vn loader. Does the loader valve have a float position? Just curious.
   / What did you do to your Yanmar today? #53
Loader made by Apple Implement Mfg.
   / What did you do to your Yanmar today? #54
Couldn't find anything on Apple loaders but it looks like a well made loader, I'm guessing fairly old just because of the two handle control valve and bucket size.
Yes it is a large bucket. I want to make a new one for mine as it is badly mis-shapen after too may pole/post/tree etc removals. I however will make it slightly narrower but larger in depth and height.
   / What did you do to your Yanmar today? #56
After working with this bucket for a while, I think I would like to try a slightly more narrow bucket as you say.
Let me know how your build goes.
After my little mishap with the range selector I decided to give my YM14 a birthday and see if I could work out why it is running so rough. I did degrease and pressure clean it whilst running and noticed it coughed when I sprayed water around the inlet neck and injectors. Broke out the brake clean and started spraying. Found an injector seat leak on No1 and a bad one on No2, maybe they were never put back when it was last pulled to bits? I will pull them out and see what condition they are in if there are any installed....
   / What did you do to your Yanmar today? #58
What do you mean maybe they were never put back? Is this inside the injector itself or the injector well in the head?
If it's the injector, I can send you the breakdown & rebuild directions from the John Deere 850 950 1050 service technician's manual.
Yeah between the injector and head. When I squirt some brakecleen down there it coughs and carries on so am guessing they were never replaced/installed.
I also changed oil and filter on the 1500 as I had all the stuff out. Will grease her up soon and adjust the brakes as they are not working really well ATM. First adjustment in about 8 years so not bad :thumbsup:
2011 John Deere 5085 70HP Utility Tractor (A55973)
2011 John Deere...
12ft x 20ft Steel Carport (New/Unused) (A59225)
12ft x 20ft Steel...
2017 Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A55973)
2017 Gravely...
GRILL GUARD & POOL LADDER (A58374)
GRILL GUARD & POOL...
2015 Ford F-350 Cab and Chassis Truck (A56858)
2015 Ford F-350...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
