What did you do to your Yanmar today?
   / What did you do to your Yanmar today? #51
I guess the tags there on the side of the loader don't reveal anything. Big bucket for sure. I don't think it is a vn loader. Does the loader valve have a float position? Just curious.
   / What did you do to your Yanmar today? #53
Loader made by Apple Implement Mfg.
   / What did you do to your Yanmar today? #54
Couldn't find anything on Apple loaders but it looks like a well made loader, I'm guessing fairly old just because of the two handle control valve and bucket size.
Yes it is a large bucket. I want to make a new one for mine as it is badly mis-shapen after too may pole/post/tree etc removals. I however will make it slightly narrower but larger in depth and height.
   / What did you do to your Yanmar today? #56
After working with this bucket for a while, I think I would like to try a slightly more narrow bucket as you say.
Let me know how your build goes.
After my little mishap with the range selector I decided to give my YM14 a birthday and see if I could work out why it is running so rough. I did degrease and pressure clean it whilst running and noticed it coughed when I sprayed water around the inlet neck and injectors. Broke out the brake clean and started spraying. Found an injector seat leak on No1 and a bad one on No2, maybe they were never put back when it was last pulled to bits? I will pull them out and see what condition they are in if there are any installed....
   / What did you do to your Yanmar today? #58
What do you mean maybe they were never put back? Is this inside the injector itself or the injector well in the head?
If it's the injector, I can send you the breakdown & rebuild directions from the John Deere 850 950 1050 service technician's manual.
Yeah between the injector and head. When I squirt some brakecleen down there it coughs and carries on so am guessing they were never replaced/installed.
I also changed oil and filter on the 1500 as I had all the stuff out. Will grease her up soon and adjust the brakes as they are not working really well ATM. First adjustment in about 8 years so not bad :thumbsup:
17" Wheel Simulator, Front & Rear w/Hub Cap, Ford F-250 Chrome, 1 Set, Item # RZCMWC-9506 (A59076)
17" Wheel...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A55973)
2012 Freightliner...
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
1986 VIM TACK TANKER TRAILER (A58214)
1986 VIM TACK...
2012 Ford F-550 Knapheide Service Truck with Liftgate (A56858)
2012 Ford F-550...
DEMCO SADDLE TANK MOUNTS (A52708)
DEMCO SADDLE TANK...
