What did you do to your Yanmar today?
   / What did you do to your Yanmar today? #51
I guess the tags there on the side of the loader don't reveal anything. Big bucket for sure. I don't think it is a vn loader. Does the loader valve have a float position? Just curious.
   / What did you do to your Yanmar today? #53
Loader made by Apple Implement Mfg.
   / What did you do to your Yanmar today? #54
Couldn't find anything on Apple loaders but it looks like a well made loader, I'm guessing fairly old just because of the two handle control valve and bucket size.
Yes it is a large bucket. I want to make a new one for mine as it is badly mis-shapen after too may pole/post/tree etc removals. I however will make it slightly narrower but larger in depth and height.
   / What did you do to your Yanmar today? #56
After working with this bucket for a while, I think I would like to try a slightly more narrow bucket as you say.
Let me know how your build goes.
After my little mishap with the range selector I decided to give my YM14 a birthday and see if I could work out why it is running so rough. I did degrease and pressure clean it whilst running and noticed it coughed when I sprayed water around the inlet neck and injectors. Broke out the brake clean and started spraying. Found an injector seat leak on No1 and a bad one on No2, maybe they were never put back when it was last pulled to bits? I will pull them out and see what condition they are in if there are any installed....
   / What did you do to your Yanmar today? #58
What do you mean maybe they were never put back? Is this inside the injector itself or the injector well in the head?
If it's the injector, I can send you the breakdown & rebuild directions from the John Deere 850 950 1050 service technician's manual.
Yeah between the injector and head. When I squirt some brakecleen down there it coughs and carries on so am guessing they were never replaced/installed.
I also changed oil and filter on the 1500 as I had all the stuff out. Will grease her up soon and adjust the brakes as they are not working really well ATM. First adjustment in about 8 years so not bad :thumbsup:
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
E-Z TRAIL S10 GRAIN CART (A52708)
E-Z TRAIL S10...
Cushman Electric Cart (A55853)
Cushman Electric...
2022 Caterpillar 289D3 Compact Track Loader Skid Steer (A55973)
2022 Caterpillar...
2024 JOHN DEERE 50 P-TIER EXCAVATOR (A52709)
2024 JOHN DEERE 50...
19015 (A55788)
19015 (A55788)
