Tires for 7K car hauler
   / Tires for 7K car hauler #22
We have started skipping the "trailer" rated tires. They are so low end they aren't even rated to carry persons. We have stepped up to the Michelin D or E truck tires. Once we did that the failures and carcass rot stopped.
The E range stuff we have is all 16" rims. From memory 15" rims have a few D range choices. I don't think LT tires are a good choice for a 7k axle though. In fact I don't recall seeing a 7k axle with anything less than a 8 lug 16" wheel. That's a 14k tandem axle trailer-which is a custom cargo/car hauler.
OP doesn't state if this is tandem or single axle. If it's tandem axle that's 3.5k per axle or 1.75k per tire. This is about max for C range.
I am a little confused by these two posts. I have a trailer with 16'' wheel so that is why I am asking. I've thought about LT tires for it when the time comes.
   / Tires for 7K car hauler #23
Trailer tires are not regulated like automobile tires. There are several problems with trailer tires. 1. Most are only speed rated for 65MPH. Most states have interstate speeds higher than that. 2. Most trailer just have barely enough tire. If you buy a 10k trailer it will come with load range D tires. Load range D tires are good for 2540. So 4 tires at 2540 are good for 10,160. Then if your trailer is not sitting level you will have one axle overloaded and could have a blow out. If load the trailer to max capacity and get to flying down the interstate you are asking for problems. That is why I recommended for the OP to get load range E tires for his 7k trailer. Then if you look at truck tires, an 8,000lb 3/4 ton will have load range E tires that are good for 3400 each or 13600 all together. A new 3/4 ton with have a gross weight around 10,000, so it has a little extra tire on it unlike trailers.
   / Tires for 7K car hauler #24
Carlisle/ goodyear is what uhaul uses.
If you look at the tires they use they are built especially for Uhaul. We as consumers can't buy them.
The Carlisle and Goodyear Marathon trailer tires I have had were JUNK!
   / Tires for 7K car hauler #25
I have some Kenda Load Star tires on 3500lb trailer that are 11 years old now. It doesn't get used often (probably hasn't been on the highway in the last 4 years) nor does it go very far when it does. A few weeks ago I took a look at them and they don't have any dry rot. This trailer sits in the sun all day long. When I do replace them I'm going to buy another set.
As for using truck tires on a dual axle trailer, I would be careful. Trailer tires are rounded on the tread surface so when the trailer makes a sharp turn it helps reduce the resistance from the tires sliding sideways. Car/ truck tires are designed for just the ooposite. They are designed to provide traction to prevent your car/ truck from sliding sideways. So if you are trying to back your trailer into a tight spot with a load on it you could do damage to the tire or the trailer because of the added force. Lots of people do it.
   / Tires for 7K car hauler #26
Ok thanks for asking me to clarify.
We have several trailers and have had and seen blowouts. The "easy" ones occur around town with a load from the quarry. The ones that are a bummer occur on some vacation or out of town. We tried early replacement and extra maintenance of "trailer" tires and finally ditched the trailer tires in favor of normal vehicle rated tires.
On our bigger stuff like the cargo trailer with tandem 7k axles we use the same tires that go on the 3/4 or 1 ton trucks- Michelin. Those are load range E.
On the lighter stuff we use load range D tires.
Some of my confusion was with regards to the 7k trailer description from the OP. I thought that was per axle or a single axle. So my initial comments were made with that understanding. Then as the thread went on I realized it was two 3.5k axles- lighter duty. Therefore the load range D would work.
So bottom line- I have had great success with LT rated tires. The upfront cost is offset by increased lifespan and decreased failure rate. Plus the peace of mind on a long trip is worth something to me.
Good info, thanks to all. I'm going to look into P- or LT- metrics with the needed load rating and compare to the preferred ST brands mentioned.
I could have been more clear, trailer has 2- 3500lb axles with 205/75R15 tires. Not sure I'm gonna find LT 's in that size.
   / Tires for 7K car hauler #28
The subject says "7k car hauler". That's two 3500lb axles, which usually means 15" wheels, and either 215 or 225 size tires.
My experience is this: Bias ply trailer tires are durable and great for short hauls around town. However, they are VERY picky about alignment, and I've had them wear quickly (less than 5000mi) on a single axle boat trailer that didn't wear radial tires at all. For longer runs like the OP is suggesting, and especially for a two axle trailer, I'd recommend sticking with radials for best wear.
I am done with TL (trailer use only) tires for any trailer I plan to keep and use. They are generally made as cheaply as possible no matter what brand you buy, and unless you use Load Range D or E 15" trailer tires, they are NOT better in any way than normal (P-rated) tires. Even going with a name brand trailer tires (Goodyear, Marathon) has not worked out well for my friends and I.
We now use P215 or P225/75R15 tires on all of our car and boat trailers, and LT rated tires on heavier trailers with 16" wheels. The exception is one set of Goodyear G614's that I have on my Gooseneck. The G614's are Load Range G, and I bought them with low miles off CL for $100 each. They are over $300 each new, and are really heavy tires that wear like iron and hold up GREAT, particularly when used well under capacity in lieu of a LR E tire. (Not helpful to OP, but perhaps to others...)
We've experienced no tire failure problems with the non-trailer rated tires, even on tires that are 10+ years old. In my experience, and by most mfg's recommendation, trailer tires that are 5 years old should be replaced. They may be fine for around town, but I certainly wouldn't take them on a longer trip... The last set of P-rated tires we had on the car hauler were P215/75R15 Goodyear RT/S's that were bought off CL as a take-off set of wheels and tires from a new (at the time) Jeep Wrangler. (~2000MY) They lasted 15 years before weather checking and wear prompted their replacement about two years ago. We replaced them with P225/75R15 Cooper Discoverer H/T's. No issues so far.
My experiences as well.
   / Tires for 7K car hauler #29
No way any reputable tire shop will put P tires on around here. Sidewall strength is just not there.
It was common practice to use LT tires also around here but no more. They will not mount them either.
It all comes down to liability. With the Greenball and Maxxis trailer tires going one load range higher than needed we have had zero failures in the last 15 plus years and about 300,000 miles. We do change them out every 5 to 6 years.
   / Tires for 7K car hauler #30
I've posted this over-pressure info in another thread, but came across this tonight - it lists Goodyear's bulletin #:
I won't tow with ST tires much faster than 65 mph, and if I lived in the SouthWest, maybe not even that high...
Another important distinction between LT and ST tires is their speed ratings something a lot of RVers tend to overlook. Goodyear, maker of Marathon trailer tires, states in its bulletin PSB 2011-13: Industry standards dictate that tires with the ST designation are speed rated at 65 mph under normal inflation and load conditions. Based on these industry standards, if tires with the ST designation are used at speeds between 66 and 75 mph, it is necessary to increase the cold-inflation pressure by 10 psi above the recommended pressure for the rated maximum load. Increasing the inflation pressure by 10 psi does not provide any additional load-carrying capacity.
"Do not exceed the maximum pressure for the wheel. If the maximum pressure for the wheel prohibits the increase of air pressure, then the maximum speed must be restricted to 65 mph. The cold-inflation pressure must not exceed 10 psi beyond the inflation specified for the maximum load of the tire."
RV Tires 1�1
Rgds, D.
   / Tires for 7K car hauler #31
Are you saying that ST tires that have L and M speed ratings are miss labeled? I find it hard to believe they could advertise a speed rating that is only achievable by inflating the tire over the advertised max inflation.
   / Tires for 7K car hauler #32
I first came across that info on Tire Rack, and posted it in another thread quite a while ago, Just reposted here as a PSA, and to cite the Goodyear document #.
Personally, I don't tow with ST > 65mph. I'm not familiar with L or M ratings, so can't comment.
To me, this consideration shows how under-engineered ST tires are for sustained high speed.
Rgds, D.
   / Tires for 7K car hauler #33
It all comes down to liability. .
I wish the authorities that have created these Liability fears put even 40% of that enforcement energy into keeping the garbage ST tires out of our countries - those products are way more of a danger than LT tires.
Rgds, D.
   / Tires for 7K car hauler #34
My Maxxis tires are speed rated. Can't remember to what speed, but I recall that it is faster than I will ever tow. I will tow a full load or a camper at 80 mph plus when I feel that it is safe to do so. My truck is well maintained and my brakes and tires on trailer and truck are properly inflated and working properly.
I towed my camper on Power King radial tires at 80-90+ mph for a 16 hour day from Colorado Springs to just inside the Tennessee border one day in July 2015. No excess heat in the tires every time I stopped and no issues. Properly inflated radial tires in good condition and of good quality can handle speed and weight.
Buy good stuff and use it.
   / Tires for 7K car hauler #35
Rgds, D.
I agree.
   / Tires for 7K car hauler #36
RV Tires 1�1
Rgds, D.
In the above RV Tires 101 link, I saw it mentioned car tire have a max pressure for a max load. But I was told on trailer tires to always run max pressure all the time. Does everyone do that? Jon
   / Tires for 7K car hauler #37
In winter months I run 75 psi if they call for 80 max . Adjust if necessary in the summer months. Same for the truck.
   / Tires for 7K car hauler #38
We do on all of our trailers at work as do I on my 3 personal trailers.
Have not had a failure in 10 years since my last set of Marathons. I now only run Greenballs, Maxxis, and Kenda.
The Kenda came on our latest trailer. So far so good with about 3000 miles since October.
   / Tires for 7K car hauler #39
Last year I "switched" over to Carlisle Radial Trail HD tires on my 21' enclosed and 14K Gooseneck trailers. I got rid of the Marathons and the "China bomb" Mission's that came with my Gooseneck. I am really happy with these tires and they seem to be getting good reviews as well. I will be going to these on my two horse trailers and my fishing boat soon as well. My aluminum car hauler came with Westlake's we'll see how they do (they get decent reviews also).
   / Tires for 7K car hauler #40
I can tell you who I won't buy from again. I bought 5 new tires and wheels from Camper Trailer Supply off amazon. They pictured the freestar brand radial and sent some other brand bias ply tire. I haven't had any problems with the tires they sent but they misrepresented the product for sale and would not do anything to correct. Argued with me and said the photo just showed a wheel and tire and it didn't mean I would get what was shown in the picture.
Caterpillar 928G Articulated Wheel Loader (A59228)
Caterpillar 928G...
SWICT 84" SKID STEER BUCKET (A60430)
SWICT 84" SKID...
Kubota SVL 97-2 (A53317)
Kubota SVL 97-2...
TEST YOUR BID BUTTON! (A60432)
TEST YOUR BID...
2015 Chevrolet Tahoe SUV (A59231)
2015 Chevrolet...
2017 KOMATSU HM400-5 OFF ROAD WATER TRUCK (A60429)
2017 KOMATSU...
