1969 JD 1020 diesel
   / 1969 JD 1020 diesel
I was able to get the new rod bushings pressed in and reamed out properly. I was then able to assemble the pistons to the rods that had new bearings and bushings installed.
With the liners already in place, I cleaned the crank and sump pump screen as well as the oil pan and block mating surface.
With the help of a friend, we went about installing the pistons into each liner. As ovrszd mentioned I purchased a 3-5" piston ring compressor from my Napa and followed the youtube video I posted above.
After making a mistake, and after all three pistons were installed, connected to the crank and properly torqued, we had to take them back out because we placed the piston ring openings/gaps 180 degrees opposite of one another but directly over the wrist pin opening!!!
I read and reread about how this is a no no. So we had to go about correcting that.
After getting the pistons reinstalled, rod cap bolts torqued (45 ft lbs), we then cleaned the deck and head again, and again, before we placed the HG.
I read and reread about this subject as well. The manual states you should place a thin film of permatex #3 on the gasket before placement. I read and reread that with clean surfaces, you shouldn't place/have to place anything on a HG. I didn't use anything for the install???? :confused3:
We went about installing all the head bolts into the block, in the exact same holes they came out of. We then torqued (110 ft lbs) them down per the manual's specific order and to the correct torque spec.
So now we went about getting the rocker arm (30 ft lbs), push rods installed. We then found out (read in the manual) about the flywheel timing hole, and going about setting the proper valve clearance tolerance. We were able to ensure each intake and exhaust valve was set properly with feeler gauges. It took us awhile to figure out what the manual was stating, just because we don't know what the **** we are doing. :thumbsup:
Then we placed the new injectors into the head, cleaned the rocker arm cover and head mating surfaces for the new gasket, and started to go about re-connected the water pump, fuel lines, alternator, drive belt, radiator, intake and exhaust plumbing, etc. While using new gaskets for items that needed them while going about the re-installing process. I flushed the radiator for good measure and blew it out through the fins with some compressed air as well.
Finally, we have it all set up, refilling the coolant, removed the oil filter and put on a new one, and ready to fill the motor with oil......and my friend says " Hey, per the pistons supplier's engine break in procedures, you need to use specific break in engine oil".
:shocked:
After some research, we were able to find that Napa in Sumner carried 1qt containers of this proper break in oil. If someone tries to sell you a break in additive for regular engine oil I have been convinced you shouldn't.
We get back to the barn and fill the old girl up.
We then had a **** of a time bleeding the tractor, but was able to use the manual and get it done. We bled at the injectors and at the fuel bowl/primer lever thingy. What a good idea JD, just shoot diesel everywhere from pumping that little primer lever!!!!
During the rebuild process I also changed out the water temp gauge and fuel gauge. I must have crossed the wires or not installed them correctly, because during the initial start up my engine wiring harness/loom started to smoke!!! I disconnected the fuel and water temp gauge's electrical connections to the harness and the smoking stopped. So I will need to cut back the tape and see how far the damage made its way into the wiring loom. Fix it, then reinstall gauges CORRECTLY!!!
The only other problem is that two of my new injectors are leaking. They leak/seep where the injector goes into the head. The new injectors came with new little rubber washers that are supposed to seal to the block? The retaining bolts that go into the block are tight. Any ideas? I was thinking of tapping on the plates that hold the injectors in the head to see if I can get them to "seat" farther down?
And here are some videos and pictures of the rebuild, and some other projects (french drain fix, down spout hard pipe project, retaining wall upgrade) I have been working on/completed since I started this rebuild months ago. And Marcus!!!!
IMG_122 on Vimeo
IMG_126 on Vimeo
IMG_127 on Vimeo
IMG_128 on Vimeo
IMG_94 on Vimeo
https://vimeo.com/211379931/5bbfbfc555
   / 1969 JD 1020 diesel #52
:thumbsup: :thumbsup:
You did that engine work with the FEL still mounted.. that would frustrate me.. to no end. But you managed and sounds/looks successful project.
   / 1969 JD 1020 diesel #53
Good job on the rebuild.:thumbsup:And good documentation of the work, very thorough documentation.
I did this on my 450 dozer in 1980 made me think how time flies by.
Thank you very much!!!
Yea I did all the work with the FEL still attached because I dont really know/have a way to get it disconnected?
Maybe its time to get a small gantry crane and learn?
I am looking to rip the injectors that are leaking back out tonight and see if I can fix them.
I truly hope the new liners don't leak after like 50-100 hours!!!! :yell:
Now that you have me thinking specifically about my FEL. I have some questions, and maybe Tx. Jim can shed some light on this subject specifically for me.
I have a JD model 47 loader on my 1020.
Look at the paragraph below from another tractor forum about JD's model 46a loader and my model 47.
The 47 is Deere's first quick attach loader.They were nice to take on and off.Do you have the bracket that attaches to the engine head and goes to the rear of the loader mast?This makes the 47 a much more stable loader. Many 2510's are missing this bracket.The 47 with hard use can tear up the side frames if the mountng bolts work loose,when new Deere had a plate that went under the bolts behind the side frames.The 47 could also be used on the 1020 and 2020 tractors but you need different mounting brackets and the rear mast frame is different on the utilities.The 47 is a good match for a 2510 and makes a nice looking outfit.If you ever get a chance buy a broke up welded up 46A for parts as the cyclinders interchange.We have bought several loaders for the cyclinders and buckets then scrapped the rest.Also a 47 and 46A use the same buckets.
What is he talking about in terms of "Do you have the bracket that attaches to the engine head and goes to the rear of the loader mast?"
Also, if my model 47 is in fact a 60's quick attach loader, can someone tell me how the **** I am supposed to go about accomplishing this?
   / 1969 JD 1020 diesel #56
I viewed the model 47 parts catalog & didn't locate any bracket that attached to engine cylinder head nor do I remember such a bracket from my JD dealership tenure.. Removing/installing model 47 would be much easier if you have the mounting stands.
Hey thanks Tx Jim. Did you happen to look over my videos of the tractor? Did you see or hear anything bad???
I did some research and followed what you did and went to the parts catalog and now see what stands you are referencing. Those seem to be necessary.
I also went about taking out the injectors etc.
I plugged the holes with some plug rags to ensure there wasn't debris falling into the head, and I dremeled the sealing washer surface. I then wiped it down to ensure it was perfectly smooth and clean of debris.
After the re-installation I am stilling seeping diesel out of this area on two injectors. What should I do to get this to stop?
Finally I have run the tractor for about an hour total. Picked some stuff up, moved some gravel etc. The manual stated to back off the head bolts by 5 degrees and then re-torque them to the proper 110lbs. Can someone tell me why this is important. The manual has it stated in bold and underlined.
   / 1969 JD 1020 diesel #58
Engine sounded fine in your video to my old ears. On subject of leaking injectors around hole in cyl head I'll recommend getting some new seals from JD. It's always been recommended to re-torque cyl head bolts after engine has been operated
   / 1969 JD 1020 diesel #59
Here is the page from the manual on detaching the loader. It mentions the bracket on cylinder head, but that was only used when installed on a 2510. If you don't have the parking stands, you need to support loader from above using a chain hoist or something similar.
Hey thanks Tx. Jim and JD110. I really appreciate your willingness to help me out and provide me with confidence.
As the saying goes, pictures are worth a thousand words. JD110, the image you posted really helps me. I know it isn't rocket science to get the FEL disconnected, but the last thing I would want to do is break something trying to remove it because I was simply uneducated on how to.
I believe I fixed the injector leaks, so that is good and I am happy.
Now back to this subject of break in oil.
As stated in my earlier post I picked up break in oil from Napa. The oil is made by Amsoil. It is literally called Amsoil Break in Oil. It is SAE 30 weight, single grade oil, with high zinc content.
After reading more and more, I am a little scared that I shouldn't have used this oil, and just used "John Deere Break in Plus" because well its from JD, and its a JD tractor....
The Amsoil product fits all the characteristics from what I have read about what a break in engine oil should be, but what the **** does the internet know....:confused3:
So, should I drop the oil, get a new filter, and put in "John Deere Break in Plus"? :confused3:
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
Orico 3000 Cook Top (A51573)
Orico 3000 Cook...
Hustler Raptor SD (A51573)
Hustler Raptor SD...
2007 Nissan Armada Multipurpose Vehicle (MPV) (A51694)
2007 Nissan Armada...
