Took the plunge. Finally going solar!
/ Took the plunge. Finally going solar! #1
Soldier415
Vermont
2001 Kubota L3010GST. 2005 Kubota L3430HSTC
7.6KW 22 panel roof mount system with net metering and the option to add in Tesla Power Wall battery system later.
After looking at the numbers, it was a no brainer. For the same amount we pay the utility for power each month we could be paying the loan on a system we own and then be energy independent with no power bill once it is paid off. Not to mention increasing the value of our home.
We also get a federal tax credit of 30% of the system cost.
If you haven't looked into going solar, I highly recommend it. You might be surprised at what the numbers look like.
/ Took the plunge. Finally going solar! #2
I'm not sure how practical solar is in a northern state like Vt. I've known several people who thought they could go off-grid, and they ended up running a generator a lot more than they thought they would, especially in the fall & winter. Can you reduce your reliance on the grid? Yeah, but ISTM the payback period is gonna be quite long, probably coinciding with the need to replace the batteries.
/ Took the plunge. Finally going solar! #3
I looked into both solar and wind. Final analysis for my location indicated I could not go 100% off the grid using just one or using both combined.
/ Took the plunge. Finally going solar! #4
Did you buy a professionally installed system? I’m in the market for something or my off the grid hunting camp. Biggest draw is my 220 VAC pump. Other than that, just led lighting and an occasional power tool or charger.
/ Took the plunge. Finally going solar! #5
Does VT offer a state tax credit?
Later,
Dan
/ Took the plunge. Finally going solar! #6
... Yeah, but ISTM the payback period is gonna be quite long, probably coinciding with the need to replace the batteries.
Yep, batteries used to be the big, hidden cost of solar/wind power. As lithium batteries drop in price they will be a game changer. However, there are different Lithium battery chemistries out there, and the last time I read Tesla's spec on their wall battery, they only said "Lithium." Tesla also would not warrant the wall battery if it was grid connected like the OP and most people would want to do. Maybe Musk will change the warranty someday.
Later,
Dan
/ Took the plunge. Finally going solar! #8
We went solar a few years ago and love the savings, the second biggest saving was changing over our off peak hot water service to a heat pump, it draws 1500w as opposed to 5.5kw and even when overcast the solar will run it.
Our bills have dropped from about AU$1200 a quarter pre solar to $150, the old hot water service was just over half of our expense.
With rebates we paid AU$6k for solar but they have since come down to about AU$4.5k for a 5kw system fully installed, I would love a Tesla battery but they are cost prohibitive at the moment.
/ Took the plunge. Finally going solar! #9
Please share numbers if you do not mind. Living in coal country along with two active power plants our electric rates are some of the least expensive in the US so it probably wouldn't make as much sense for us vs. living somewhere like vermont where I suspect power bills are atrocious. What do you do for heat?
/ Took the plunge. Finally going solar! #10
A long time friend of mine went solar.. he told me it was a no-brainer too..
With the Fed & State tax credits/rebates, it was "basically" free.. {South Carolina}
BUT.. he does like to embellish his stories quite a bit.. Lol
/ Took the plunge. Finally going solar! #11
I've run the numbers...
At my current energy expenditures solar is not viable...
Here is an estimator for the Raleigh area...
If it is accurate...which I question...the numbers are not there...
How Much Does a Solar Home Cost?
/ Took the plunge. Finally going solar! #12
I have been interested in doing this but have never figured out how to make it cost effective even in Florida.
Would very much like to hear your experience and numbers. What type panels does your system have?
/ Took the plunge. Finally going solar! #13
I have 6.405KW system up. If you don't have net metering in your location it's very hard to make a financial argument for a system. If you have net metering, and plan to remain in your home for 12-16 years more, or think you can recover your capital investment upon departing in increasing home value, it's a winner. I wouldn't borrow money to do it... With the cost of the money added in, it's not viable. If your tax savings drop you into a lower tax bracket that could be something to consider too, realizing it's a one time event. I have 21, 305 LG panels up and use SolarEdge system. Fully investigate SolarEdge, it's simply the best way to go, no need with net metering for batteries, unless you want to use battery like an emergency generator, in which case you'll be weighing cost of batteries and their maintenance against a ICE generator and its maintenance and cost. Again, if you don't have net metering, it's a loser!!!!
Our house was built with solar in mind. We get direct sunlight 95% of the day. Already has a passive solar setup to heat the house. South facing with big windows in the front. When sun is lower in the winter sunlight comes in and heats the floors which retain it well. It can be -20F outside and 80 degrees inside without the heat running.
We are not doing an off grid system. Net metering system. Excess power generated gets fed back onto the grid in the spring/summer/fall earning credits from the utility which we draw against at night and during winter when production is lower.
Did you buy a professionally installed system? I知 in the market for something or my off the grid hunting camp. Biggest draw is my 220 VAC pump. Other than that, just led lighting and an occasional power tool or charger.
Yes
SunCommon - Solar Energy Solutions in Vermont and New York
Later,
Dan
I don't believe so
/ Took the plunge. Finally going solar! #15
Our house was built with solar in mind. We get direct sunlight 95% of the day. Already has a passive solar setup to heat the house. South facing with big windows in the front. When sun is lower in the winter sunlight comes in and heats the floors which retain it well. It can be -20F outside and 80 degrees inside without the heat running. We are not doing an off grid system. Net metering system. Excess power generated gets fed back onto the grid in the spring/summer/fall earning credits from the utility which we draw against at night and during winter when production is lower. Yes SunCommon - Solar Energy Solutions in Vermont and New York I don't believe so
Credits or selling back is NOT net metering! Only net metering makes it work financially.
/ Took the plunge. Finally going solar! #16
Yes, it is the very definition of a net metering system
What Is Net Metering?
Net metering is a billing mechanism that credits solar energy system owners for the electricity they add to the grid. For example, if a residential customer has a PV system on the home's rooftop, it may generate more electricity than the home uses during daylight hours. If the home is net-metered, the electricity meter will run backwards to provide a credit against what electricity is consumed at night or other periods where the home's electricity use exceeds the system's output. Customers are only billed for their "net" energy use. On average, only 20-40% of a solar energy system’s output ever goes into the grid. Exported solar electricity serves nearby customers’ loads.
How many years estimated for ROI?
About 12 years average just based on energy production/savings
For a 7.59KW 22 panel system with installation it comes out to $29k. after federal tax credit of $8,600 takes total system cost down to about $20.5k
We have high electricity costs. First 200 kw hours are at 10 cents per, after 200 its 23 cents per.
Instead of paying the electric company each month I will now be paying that money into a system I own. Did the 12 year loan option at 2.99% interest through a local credit unit and my monthly payment is equal to that of my average electrical costs
/ Took the plunge. Finally going solar! #20
Does your total system cost include the interest you'll be paying back?
Not trying to pick it apart. Trying to justify it in my pocket book.
Here in Indiana, the point is moot, as they changed the laws and anyone not in by the end of this year won't be able to get the benefits of net metering like they used to. The utilities have a good point, to some degree. The more people using net metering and not buying electricity, the fewer customers paying for the infrastructure that they still have to maintain. Kinda like the gas tax for road use. The more fuel efficient or electric cars, the less gasoline purchased, the less gas tax paid, the less money for road repairs.
UNUSED ZJG ZJ-380 STAND ON SKID STEER (A60430)
UNUSED ZJG ZJ-380...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
GIYI CLG72-72" HYD CURVED LOG GRABBER (A60430)
GIYI CLG72-72" HYD...
UNUSED FUTURE BOBCAT-E SERIES EXCAVATOR (A60432)
UNUSED FUTURE...
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
2019 CATERPILLAR 320GC EXCAVATOR (A60429)
2019 CATERPILLAR...
