Buying Advice 2501 or 3301--Questions, Questions, Questions
   / 2501 or 3301--Questions, Questions, Questions #21
I might be misreading tractordata info but it looks like my B2650 should lift slightly more than the 2501/3301--can that be right?
Difficult for me to find direct weight numbers but maybe I'm not looking in the right place.
Need to factor in lift height -- the L lifts 8-10" higher than the B and ratings are given at each loader's max height. At 8-10" lower, the L will have more capacity than the B. You need to study the lift curves to make a fair comparison. Here's a comparison of the two loaders based on the curves in the owner's manual. The L lifts marginally more throughout the range, but only about 90kg more (200 lb).
560572d1530365231-2501-3301-questions-questions-questions-b2650-l2501-jpg
   / 2501 or 3301--Questions, Questions, Questions #22
One issue with bucket mounted forks is the inability to see what you are doing. I have enough trouble figuring out where the ends of my forks are, how high and what angle with a quick attach. Having a bucket in between would be a bear without a second person guiding you. If you have room and don't need to worry about messing up a lawn or finding the septic tank the bad way, I'd be looking at the mx series or the L deluxe versions. Weight is your friend.
   / 2501 or 3301--Questions, Questions, Questions #23
If you are going to be using the FEL, filled tires and ballast are a must in my humble opinion. I have mine filled and am always having some ballast on and will soon build a good ballast box.
QA for sure as RickB said.
I have a 3301 and love it. If I were to do it again, I might consider even going bigger, though mainly for better FEL power. Being my first tractor I had too high of expectations for the FEL. I know better now and know what it can and can't do and just work around it.
YOU HAVE TO LOAD TIRES ON THESE L SERIES... These are great little tractors, but light in the rear. I loaded my tires AND added wheel weights, made all the difference in the world. And remember, BIGGER IS ALWAYS BETTER...
   / 2501 or 3301--Questions, Questions, Questions #24
That's a ok deal. I paid 27,700 for a new L3560 last month-LA 805 FEL, one rear remote, 3rd function and Grammar seat.
Will
   / 2501 or 3301--Questions, Questions, Questions #25
Also, I mow around 3 acres with my tractor. I don't think it too heavy for a "farm yard." I have a ZTR for the nicer areas, use the tractor out behind my barn, way too rough for the ZTR.
Will
   / 2501 or 3301--Questions, Questions, Questions #26
Grand L for $23K with the 805 loader is a great deal. Much more tractor than a standard L.
Went and looked at it \ drove it around Saturday.
It's BIG--obviously much bigger than my B and my old DT L but will fit in most all the places I go regularly.
Sure does come with a lot of bells and whistles--dash screen says "Welcome" when you fire it up. (How have I lived without that?!)
Size and power will help me do some projects the B can't do or would take a long time (dirt fill in of a swampy area, piling up 10' long \ 3' diameter logs, moving more firewood in less time, moving big rocks)
In excellent shape and the seller is a personable young guy (at my age anyone under 35 is still a "young guy") with a nice piece of property that reminds me of ours. Basically, he bought too small and is looking at a MX model
For $600 more he is including a QA for the rear and forks for the front (he paid about $1000 for those) and is willing to transport it the 2+ hours to my house for gas money (I have access to other transportation but this would be a lot easier).
Got home Saturday and cut grass for an hour or so and did a few other chores. Although it was nice to be back on "my little B" I was wishing for more power and lift capacity.
Good chance I'll have that soon.
   / 2501 or 3301--Questions, Questions, Questions #28
Previously owned Grand L's usually find new owners REALLY fast.
   / 2501 or 3301--Questions, Questions, Questions #30
I moved up with the need for ANY loader, more HP for bigger brush hog. SO I sorta looked at those things more as buying 'points'.
I went from kubota to kioti - more features for less money. And their deal was free loaded tires. EVERYONE here loads their tires, last tractor did not have them this one does. This one is double the weight (3300lbs est compared to 1500) and it's MUCH more stable on unlevel ground.
The QA is std - wouldn't have gotten a tractor without it, as one task is moving roundbales and clamp on forks move your pivot point even farther out. I got the cheap ones from titan (palletforks.com) and they're great. For 90% of what I've done it's been a non-issue, light rear wise. I did move a large bundle of rough cut lumber and found the loader can out lift what the rear can handle...had to use 4x4 to even move the tractor as the rear was too light. But I've moved very large rocks and logs and not had a light rear end. Convenient to NOT have to go get a ballast box or other implement for weight.
HP..I went with 35 over 26 - only $1800 more. 40 is their biggest model in that 'frame' size but was $2500 more yet..not worth it. One can always use more HP! If not..it's not like it's in the way or anything. I have managed to stall it a couple of times (HST) going into brush piles to push them about. No matter your HP you can still 'overload' it I suppose.
I opted for rear remotes, rubber floor mat, cruise control (hst and brush hogging it's a godsend), link pedal, mirror (love it), arm rests, the filled tires of course. Plan to add a hyd top link soon I think as i do a lot of box blade work and just got a disc harrow and adjusting the angle of attack changes what these tools can do and doing it from the seat would be handy.
More weight does have a side effect or two - you'll need a trailer that can handle it should you need to move it about, and you'll likely see ground impressions. The kubota left no real marks on the ground..this one is leaving noticeable impressions outside the barn door on the grass from the in/out all in one place nearly daily.
BTW, I paid 22450 out the door. The options listed above - totaled $640. Yes, two rear remotes were added and only cost $295.
The CK3510 over the 26 also gets a heavier loader as part of the upgrade. 1800lb lift capacity.
Spent time today on the "little B" moving dirt and brick\cement block to fill in some erosion in a run off ditch I have.
Tractor did ok, but the whole time I kept thinking "if I had that 3560 this would get done a whole lot faster".
Contacted the seller tonight and we are "go for purchase"!
Just need to work out the delivery details and cut him a check (that's the hard part!).
Hoping to have the Grand L in it's new home before the end of the week.
Thanks for all the advice and education!
One more question for now: Looking for a better way to move rocks than wrapping a chain around them. Do they make a metal "net" or something you can roll the rock onto and then chain it up. Not sure if chain link fence would work or what the weight limit would be for that. Any ideas?
   / 2501 or 3301--Questions, Questions, Questions #32
Many use an old car hood from the junkyard to sled rocks. Car hoods pull easy.
   / 2501 or 3301--Questions, Questions, Questions #33
In the near future I plan on upgrading to either a high end B series (B3350) or an L series (L33XX or L35XX). I'm leaning more towards the L series because it seems like a more beefier built tractor. I don't want something huge, but something that I don't have to worry about hopefully for the rest of my life.
I plan on buying some more land later on in life, and I want to have the right machine to bush mow and keep the land tamed.
What kills me, is I don't want to use my BX2200 for a trade... I absolutely love my tractor. Especially for all the stuff I've thrown at it... they ain't kidding when they said Kubota's are as tough as nails.
I found that you can overload these machines, as long as you do proper maintenance, they will indeed last forever.
   / 2501 or 3301--Questions, Questions, Questions #34
When I wanted a larger tractor than my B7100 I was first thinking B3350. After driving some tractors, reading and posting here and thinking what my needs are, I decided a larger tractor would be more useful. I did not like the L3301/3901 and ended up with a Branson 3725. There's one task- mowing a small area with fence on three sides- where the 3725 is a little cumbersome and the old B7100 would have done better. But the B7100 felt tippy there while the Branson is very stable. I've taken it on much steeper slopes. It's been able to go more places than the B7100 because it's more stable on slopes. It turns out that I get so much out of it that I could have justified an L4760.
   / 2501 or 3301--Questions, Questions, Questions #35
I just picked up my new L2501 this week, and used it for around 6 hours over the weekend for brush hogging the pasture that had really grown over, and doing some rock work on the driveway thinning some thick areas out, and building an extension of the driveway for my son to park on gravel. Granted, I'm new, and have very limited experience, but here are some of my thoughts, after reading through this thread.
1. paying to fill tires? Surprises me, my dealer did that for free, water and alcohol mix. Is there something special and more expensive some dealers are charging for?
2. Power. The L-2501 fit my price range (barely). Will it do what I need it to? Clearly, yes. We only have 10 acres, all pasture. It was pretty thick, and had to really go slow in some thick areas, especially up hill. We have lots of slope, and terse rows on top of that. It did it, but a bigger tractor would have done it much faster I think. I would skip the L3301, and jump to the L3901 if you can afford it. I wish I could have, but just wasn't able to make that investment for what will essentially be a big lawn mower. If I had more than 10 acres to do, I think I would have.
3. they are light. On the terse rows, some were a little sketchy, had to really adjust our angle to go up or down them, felt unstable a few times as we learned. I don't like that. Also with all the rain, on a few sloped areas with mud, the front end slipped downhill a couple times. That is a scary feeling. I think that was more operator inexperience than tractor issue, but something to be aware of.
4. It's a great tractor for the money. I wanted an American tractor, in a different color, but the build, ability, and reliability record of the orange one sold me. And operating it, I really think it's going to do everything I want/need it to, and more, just need to stay within the realistic capabilities of it. I like the full size of it, but could use a bit more power, but not only was the cost of a 3901 a turnoff, so was the emissions/DPF stuff. That sold me on it.
5. Buy an HST. I have used my neighbors older Kubota 3800 I think, with direct transmission. REALLY like the ease of the HST.
6. 4X4. DO it. Seriously. It's very helpful.
   / 2501 or 3301--Questions, Questions, Questions #36
1: Its typically a couple hundred bucks to load tires. Some dealers just roll that cost into the sale price. Alcohol is cheaper than beat juice, but lighter.
2: As all the L3x01 & L2501 machines are pretty much the same other than engine (L2501 was designed to get under the 25hp emissions limit). So it's mostly a question of how big of a mower do you need to spin & how fast do you need to travel. The bigger ones just have more HP & can cover more ground with a bigger mower (rough ground usually prevents going faster unless it's a smooth lawn).
5: I agree, but HST eats up 15% of the HP. I think it's worth it, but if it may not be for somebody who just mows all day. I find the HST control is great for precision mowing near obstacles I couldn't easily do with a gear machine.
6: Ya, unless it's just on as manscured lawn, these tractors are balanced for 4wd. No way you could reasonably or safely use a loader on a 2wd economy Kubota.
   / 2501 or 3301--Questions, Questions, Questions #37
5: HST eats 15% of the HP. I think it's worth it, but if it may not be for somebody who just mows all day. I find the HST control is great for precision mowing near obstacles I couldn't easily do with a gear machine.
Clarification: Gear tractors have power loses between the engine and ground too. Somewhere around 5% to 10%, varying by model.
So HST is 5% to 10% less efficient (+/-) than gear equivalents.
   / 2501 or 3301--Questions, Questions, Questions #38
I'm not clear if the 15% HST HP tax is from the engine, or compared to a gear machine. I always assumed it was compared to a geared machine power to the ground.
It makes a big difference for field machines pulling impliments in big circles all day. Increased fuel costs & slower production add up. But in the SCUT & CUT range the HP tax is usually (but not always) offset by increased usability & productivity.
   / 2501 or 3301--Questions, Questions, Questions #39
At the end of the day, you'll be hard pressed to notice the difference in power between these choices, even a 20% jump from an L3301 to L3901 is not always super noticeable. When you're splitting hairs like this on transmission choices I think you kinda miss the point. Its best to buy what can you operate comfortably and efficiently.
   / 2501 or 3301--Questions, Questions, Questions #40
Agree. It's true you lose a bit of HP in the hydrostatic. It's also true that a BX (for example) is unable to put all it's power on the ground anyway, it can spin it's wheels on pretty much any terrain and with any tires on it. So while in theory you're losing HP, in practice it was HP you couldn't use for driving. It may be noticeable in some PTO applications, but with a 23 it's got enough power to drive the loader, to drive the mid mount mower, and to drive pretty much any implement that's the right size for the tractor. In effect Kubota put a 23hp motor in it instead of a 20, and so the 15% you lose they fixed by putting more HP in it.
Bottom line, not something most SCUT owners should worry about.
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
UNUSED RAYTREE RMBD72-72" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
2018 JOHN DEERE 333G SKID STEER (A60429)
2018 JOHN DEERE...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2012 UTILITY REEFER TRAILER (A58018)
2012 UTILITY...
