oldnslo
Super Member
Dubo,
repairing cylinders depends on several factors.
Cylinder assembly style. Some have large snap ring that can be difficult to remove while others may require a spanner wrench to get the end cap off.
Some safe means of pulling the piston rod assembly out of the bore. Smaller cylinders are usually less challenging that the bigger ones.
Then do you have the capabilities to safely hold the rod without damaging it to unscrew the nut holding the piston onto the rod.
If the bore is scuffed do you have a hone to remove any slight surface imperfections?
The are some of the things that make cylinder repairs simple or extremely difficult for the average shade tree mechanic.
If this were my tractor I would take a close look at how the cylinder is assembled and then decide.
