Diesel Stabilizer
   / Diesel Stabilizer #31
Hi all,
Thanks for all of the good information on this thread. So if I were to use Power Service fuel stabilizer in a plastic 5 gallon fuel container, about how long can I expect the fuel to stay good?
   / Diesel Stabilizer #32
Hi all,
How long does it take you to use 5 gallons? I assume you’re talking about diesel?
   / Diesel Stabilizer #33
Correct about the Diesel. I'm not sure how long it will take me to use it all. I'm thinking about the winter (which is long where I live) when I'll only really be using the tractor to blow snow. Would diesel last 6 months in a 5 gallon fuel canister with stabilizer?
   / Diesel Stabilizer #34
Yes. Use the white bottle for Winter. It has some anti-gel.
   / Diesel Stabilizer #36
jd- I use a couple of PS products. The winterized fuel in my tank is ~6 months old and after a battery charge the tractor started right up with no white exhaust the other day. My tractor had not been run since early January/late December due to injury. I agree with Rick. Fuel storage success has a lot to due with storage area's general humidity.
   / Diesel Stabilizer #37
Thank you Jay. I'm living in a wetland, so there's a lot of humidity, but at least the winter is a little drier.
   / Diesel Stabilizer #38
For sure! You don't want to 'gel up' EVER,
At the very least it is good insurance for the price.
I did once and promise you , never again.
Like any insurance, you have 2 choices, Before or after, and after is too late.
   / Diesel Stabilizer #39
I used Power Service for several years in my '59 White's 220 Cummins. Whenever I fueled I would add at least a half gallon to the tank. This past summer I had to have the injection pump rebuilt. They found lots of rust inside the pump and we had to replace it with an updated pump. The owner of the injection shop recommended Howes Diesel Treat. I find it at Walmart and I use it now instead of PS.
   / Diesel Stabilizer #40
Why do you believe the rust was caused by the Power Services Product?
2005 Mitsubishi Fuso FE84D Auto Crane 3203 PRX 3,200 LB Crane Utility Truck (A59230)
2005 Mitsubishi...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59905)
2019 INTERNATIONAL...
2016 CATERPILLAR 330 FL EXCAVATOR (A60429)
2016 CATERPILLAR...
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
