Snapped excavator bucket tooth shank
   / Snapped excavator bucket tooth shank #11
Usualy those are ductile iron or some other form of casting/forging. You could try to weld it back on but i dont see it lasting very long.
When you get replacement shanks get a spare because its only a matter of time.
Thanks for all the advice. I think I am going to cut it off with my oxy/acetylene torch and weld on the new one with 7018 rod. I thought about a repair but there is no way to add extra steel for reinforcement since the tooth has to slide over the shank.
   / Snapped excavator bucket tooth shank #13
I just came across this thread. You’ve already received good advise and prolly already have it fixed!
I’ll add exothermic lance to options for cutting it off though.
This is just a follow up question. The bucket I am using is relatively new. Maybe 150 hours dig time. The cutting edge and shanks only have 30 hours time. The reason is the original edge snapped (was told they had a defective batch) and the bucket mfg repaired the bucket with a new edge and shanks. The entire bucket is made with USA steel. The cutting edge and shanks are from Romac which is all Chinese steel. I was told that it is impossible to get a USA made cutting edge and shanks. Is this true and do others have any experience with Romac products?
   / Snapped excavator bucket tooth shank #15
I used to sell Arcair Slice Exothermic. ( still have one ) Fun product and crazy destructive.. Once we pierced holes in a huge boulder and hit it with sledge hammers to bust it up. Worked perfectly.
   / Snapped excavator bucket tooth shank #16
I know nothing about the Romac. Pretty sure someone on here does.
   / Snapped excavator bucket tooth shank #17
I have the SLICE too. Do you say “It’s been a slice” when you’re completed the cut like I do ????
Great for those pesky bank vault doors.
*not really. In actuality a lot of the loot would be on fire. Don’t believe everything you see in bank heist movies.
   / Snapped excavator bucket tooth shank #18
I can't answer the question about Romac products, but I can say that I've had Hensley shanks snap in the exact same place, I don't use any of the top pin or side pin teeth anymore and I've had zero problems with loosing teeth or snapping shanks. Cut off the broken one and weld in a new one OR cut them all off and put on alll new different style shanks.....
What type of shanks/teeth do you use?
   / Snapped excavator bucket tooth shank #20
Is their a good source to buy a tooth? I have a front tooth bar on my front end loader and the firm that made it is out of business.
JOHN DEERE 35G EXCAVATOR (A60429)
JOHN DEERE 35G...
2009 1770 NT 16R Planter (A59814)
2009 1770 NT 16R...
ST225/75R15 Trailer Tires (A55788)
ST225/75R15...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
