My Garage/Shop Heater Install
   / My Garage/Shop Heater Install #201
Hmmm, dinner; good plan :=)
Later... Steve
   / My Garage/Shop Heater Install #203
Says "invalid attachment"...
   / My Garage/Shop Heater Install #205
Did you check all connections , and is the unit properly grounded.......
   / My Garage/Shop Heater Install #207
Does the un-insulated part of the flame rod continue thru a hole in the burner, and if so how much clearance is there between that hole and the rod?
I just can't tell. It disappears behind the box on the left and I cannot get my hand around it. Or the iPhone camera to 'see' through the hole in the bulkhead that the probes are mounted to. I need a fancy little mirror on a stick but that is where the action is. Are you wondering if it is shorting to ground? I would think I wouldn't get combustion if this was the case.
   / My Garage/Shop Heater Install #209
Kill power, remove the spade from the flame rod, measure the rod to ground. Should be a few "gigaOhms" (OPEN)
Flame rod supposedly goes straight to control board (see page 18, lower left corner of the board)
   / My Garage/Shop Heater Install #210
Sooo, we done for the night or did you decide 9mm test gear wuz more fun? :D ... Steve
Adams 5 T Spreader (A55301)
Adams 5 T Spreader...
15" Concrete Pipe (A53316)
15" Concrete Pipe...
2015 Ford Escape SUV (A55758)
2015 Ford Escape...
2020 Chevrolet Silverado Pickup Truck (A55852)
2020 Chevrolet...
2025 Spirit Carriage Electric Cart (A55758)
2025 Spirit...
JMR Safety Basket (A53316)
JMR Safety Basket...
