JWR
Elite Member
- Joined
- Apr 19, 2011
- Messages
- 3,995
- Location
- So MD / WV
- Tractor
- MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
Wow, green paint hides a lot of things!
Can you keep the tractor and continue to use the loader etc. until the dealer has the new part in hand? At least then the you will have partial use while waiting for the part, which I image could be a long wait.
A bit more looking around found a MF1735E whatever the E may mean, anyway new on dealer lot, that has a different design lift arm anchor than the 1735M No idea if this is "better" but probably is newer. Notice the web bracing is different and the single end pin support part of the housing is thinner but backed up by a rib making it overall thicker than the 1735M. Hmmm. Wonder what the story is ? Is the E model a cheaper 'economy' version ? Just newer? Was the differing design because the E model is a totally different tractor or because of a history of failures? Unlikely because of failure history because it does not look that much more robust if any... Notice that the E model has the single end supported post INBOARD rather than outboard of the cast metal. Very different.
View attachment 661478View attachment 661479View attachment 661477
