Cordless impact to crank trailer jacks
   / Cordless impact to crank trailer jacks #31
My jack shaft is hollow so I welded a small bolt to the end, it will fit inside the jack handle. Like I said, the drill only has enough power to raise/lower the legs with no weight on them. It didn't help much so I rarely use it.
   / Cordless impact to crank trailer jacks #32
Here is my jacks & handle
I know pictures are deceiving but that gooseneck riser appears to be 10" with a 1/4" or maybe 5/16" flange? That seems really light for a 38K gvw trailer, plus the deck on the neck will add weight/stress to it. Please confirm and tell me I am wrong:)
Youre not only wrong, you need glasses :laughing:
I need to do that.
I have a VERY strong DeWalt impact that I would rather use, but wonder if the impacts would damage the Jack internals or round-off the welded on nut?
   / Cordless impact to crank trailer jacks #37
   / Cordless impact to crank trailer jacks #38
Getting ready to try the same thing. Intention is to find what size deep impact socket I need, drill it for the pin, and use a corded impact to raise and lower.
So you want to put a deep socket over the jack shaft? Held in place with a pin cross drilled through the jack shaft? I like that idea because the impact socket should last a long time and if it wears out, its removable. If you need to use manual crank, its removable.
   / Cordless impact to crank trailer jacks #40
I thought about that. It’s by far the easiest way to do it but I work about the impact damaging the jack.
TANK MANIFOLD (A55745)
Ficklin CA9600 Auger Wagon (A59814)
Ficklin CA9600...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
DECORATIVE METAL GATE (A58214)
DECORATIVE METAL...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
