Cordless impact to crank trailer jacks
   / Cordless impact to crank trailer jacks #31
My jack shaft is hollow so I welded a small bolt to the end, it will fit inside the jack handle. Like I said, the drill only has enough power to raise/lower the legs with no weight on them. It didn't help much so I rarely use it.
   / Cordless impact to crank trailer jacks #32
Here is my jacks & handle
I know pictures are deceiving but that gooseneck riser appears to be 10" with a 1/4" or maybe 5/16" flange? That seems really light for a 38K gvw trailer, plus the deck on the neck will add weight/stress to it. Please confirm and tell me I am wrong:)
Youre not only wrong, you need glasses :laughing:
I need to do that.
I have a VERY strong DeWalt impact that I would rather use, but wonder if the impacts would damage the Jack internals or round-off the welded on nut?
   / Cordless impact to crank trailer jacks #37
   / Cordless impact to crank trailer jacks #38
Getting ready to try the same thing. Intention is to find what size deep impact socket I need, drill it for the pin, and use a corded impact to raise and lower.
So you want to put a deep socket over the jack shaft? Held in place with a pin cross drilled through the jack shaft? I like that idea because the impact socket should last a long time and if it wears out, its removable. If you need to use manual crank, its removable.
   / Cordless impact to crank trailer jacks #40
I thought about that. It’s by far the easiest way to do it but I work about the impact damaging the jack.
406 (A52706)
406 (A52706)
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
2017 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A60460)
2017 Ford F-550...
Case-IH 165 Puma (A57148)
Case-IH 165 Puma...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A56438)
2014 Doyle Dry...
