Wider front tires M7040 Kubota
   / Wider front tires M7040 Kubota #71
If you already have ag R-1 tires, and want to be less destructive, an ag radial won't help that much. Better to just find someone that wants to swap to ag R-1's and doesn't want their R-4's.
   / Wider front tires M7040 Kubota #72
Any issues filling radials with ballast?
   / Wider front tires M7040 Kubota #74
I once saw a video where a guy was making pin-point turns on grass with R-1 r's and the grass showed hardly a ruffle.
Don't know if this was slight of tire but my simple mind was impressed.
   / Wider front tires M7040 Kubota #75
If it's clay or gravel ground and dry you can get away with it. Not so if the least bit wet.
   / Wider front tires M7040 Kubota #76
I've had calcium filled radials since tractor was new. Zero issues to date. Loader tractor, rears have fluid, front radials do not.
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
2016 Doyle 10T Tender (A56435)
2016 Doyle 10T...
Adams Tilt Trailer (A56438)
Adams Tilt Trailer...
UNKNOWN  SKIDDED FRAC TANK (A58214)
UNKNOWN SKIDDED...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
