Should I use conventional oil, or synthetic oil in my tractor.
   / Should I use conventional oil, or synthetic oil in my tractor. #41
Valvoline is good oil and those are two great reasons. I would always follow the recommendation of the manufacturer. And I am uncertain of the supply in the distance future for T6, I was fortunate to find the 3 gallons I have now for the next oil change. I will stay with synthetic also if I eventually have to change from T6.
I switched to Amsoil, it is easy to get, readily available.
   / Should I use conventional oil, or synthetic oil in my tractor. #42
I don’t like the word “ probably” for a lot of reasons. Standards are the goal posts for all oils to meet, at the very least. It’s how long they stay within those standards is what differentiates brands/types from each other… I find that Amsoil is a tough contender to the top spot.
Has same API ratings as Shell.
   / Should I use conventional oil, or synthetic oil in my tractor. #44
Fleet Farm Specifications
  • High synthetic content
  • Superior lubrication of bearings and turbo charger setup
  • Improved fuel economy and extra soot handling and oxidation resistance
  • Meets latest CJ-4 requirements
    Kinda vague on information. No CK specs. I didn’t see a data sheet available 😬
   / Should I use conventional oil, or synthetic oil in my tractor. #45
I run synthetic in everything I've owned for the last 10 years or so since the price became reasonable, and I'm very happy with it. Better gas mileage in my cars and trucks, and they're supposed to be better for wear. All my small engine stuff still runs like new for years with it. I'm running 15w-40 Super Tech dino in my tractor engine to break in after the rebuild because it's the cheapest diesel oil I could find and it exceeds the ratings the manufacturer calls for. Changed it once already after a couple heat cycles like I always do after a rebuild, and yes I always find some metal in the filters no matter how thoroughly I clean the block before assembly, which is exactly why I do this with cheap oil. Will probably change to synthetic at 30 hours or so and then change it yearly thereafter.
   / Should I use conventional oil, or synthetic oil in my tractor. #47
I don’t think so…
   / Should I use conventional oil, or synthetic oil in my tractor. #48
personally I will only use synthetic oil.
why bother with a blend?
T6 or Valvoline
willy
   / Should I use conventional oil, or synthetic oil in my tractor. #49
T6 or Valvoline
willy
T6 is full synthetic. Valvoline also makes a full synthetic.
   / Should I use conventional oil, or synthetic oil in my tractor. #50
For me it's very simple. I use the oil grade recommended in my Owners Manual. I use Rotella T4 - 15W40.
   / Should I use conventional oil, or synthetic oil in my tractor. #51
Most also recommend 10w30, which means 0w30 would be the absolute best. The 15w40 is absolute goo in cold weather. Your overhead valve gear probably is smoking by the time oil ever hits it.
   / Should I use conventional oil, or synthetic oil in my tractor. #52
I actually found T6 in stock at Walmart yesterday. I was excited and grabbed a 2.5 gallon jug. Then I saw it was only available in 15w-40 and put it back. I change oil annually, not seasonally.
   / Should I use conventional oil, or synthetic oil in my tractor. #53
That's all that's around here-1540. I need 540.
Changed over to the Farm-Rated stuff yesterday. True enough, has CJ, but not CK rating. CJ is adequate for my machine.
Maybe Rotella will become more available at some point and this stuff can become my spring change stuff.
   / Should I use conventional oil, or synthetic oil in my tractor. #56
There’s several grades (Heavy Duty and Signature Series) and viscosities of diesel oil available from Amsoil. Check it out online yourself and you can choose one you would prefer and the corresponding price. Free shipping with $100 I believe. I’m in Canada so it’s different for us up here… Wouldn’t use anything else myself.
   / Should I use conventional oil, or synthetic oil in my tractor. #57
Amsoil 5W-30 synthetic diesel oil; $124/gallon.
Valvoline 5W-30 synthetic diesel oil at my local Cummins shop; $30/gallon. I can buy 4 gallons of Valvoline for the cost of one gallon of Amsoil.
   / Should I use conventional oil, or synthetic oil in my tractor. #58
Did it take some searching to find such a rip off price!!!!!!
Here are the actual prices;
and the one is less then your valvoline
   / Should I use conventional oil, or synthetic oil in my tractor. #60
Can buy a 5 quart container of M1 0w30 ESP for $39 at Advanced Auto. It's rated C3, light diesel use. Our tractor engines are not steam ship nor locomotive diesels.
2015 Toro Sand Pro 5040 Bunker Rake (A59228)
2015 Toro Sand Pro...
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
2014 Ford Fusion SE Sedan (A59231)
2014 Ford Fusion...
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
2017 CATERPILLAR 305E2 CR EXCAVATOR (A60429)
2017 CATERPILLAR...
Caterpillar 906M (A53317)
Caterpillar 906M...
