RCK5422BX mower spindle shaft seal, left, right
   / RCK5422BX mower spindle shaft seal, left, right #1
tshep
Gold Member
Richmond, VA
BX23 MLB
As above...
Upper seal has 'stop' flange, so depth is obvious.
Lower seal does not.
(The bearing does have a groove to go past, to show depth for lower bearing.)
So, does lower seal go in:
far enough to 'touch' bearing, or
just flush to shaft housing,
or anywhere in between.
I went with deep to bearing, as shaft has a bit of protrusion 'into' shaft housing area.
I can still feel the shaft engage seal surface as it goes in.
Anyone familiar?
   / RCK5422BX mower spindle shaft seal, left, right #2
Anyone familiar?
I don’t quite understand the sentence that I’ve highlighted in blue.
I replaced the bearings on an outside spindle on my 60 inch version of the same deck. I believe I just put the seals flush with the housing surface. You do want the seal orientation such that excess grease that is pumped in comes out the bottom seal (blade end). I believe my deck is a RCK60-22BX. It is on my BX2200.
Trying to say:
A visual quick check showed the shaft flange could not go flush to housing with a perfectly flush seal, there was a radius (filet?) between shaft and flange, and then a bit of shaft that was not machined down as much as the seal area. So, the seal needed to be, at least, a bit down in the housing, but I have no guidance as to how far.
I did find others' Youtube stuff with recessed seals, so I do not feel too bad about mine
   / RCK5422BX mower spindle shaft seal, left, right #4
I think I just put mine flush, but don’t remember for sure. Unfortunately I did not take any pictures and it’s been a while.
Edit: The parts manual I have for my deck is for a RCK60B-22BX
   / RCK5422BX mower spindle shaft seal, left, right #5
Here is the page from the mower deck Workshop manual which covers both of our decks.
John Deere 690B Excavator with Auxiliary Hydraulics (A57024)
John Deere 690B...
CAT 311FLRR Excavator (A57453)
CAT 311FLRR...
(1) HD 24ft Free Standing Corral Panel (A57454)
(1) HD 24ft Free...
2018 Peterbilt 389 Day Cab Truck, VIN # 1XPXD49X6JD476305 (A57453)
2018 Peterbilt 389...
1998 IMT EZ Hauler Mini Crane with Trailer (A57453)
1998 IMT EZ Hauler...
2013 GREAT DANE  TANDEM AXLE 48FT DRY VAN TRAILER W/CRANE (A59575)
2013 GREAT DANE...
