Detach 48x28 Garage - Footings
   / Detach 48x28 Garage - Footings #101
I'll mount a 2x12 at the center location and then anchor it with numerous Tapcons into the concrete wall core.
The 12" wide wood surface area will provide a good load distribution point and the 3/8" Tapcons will provide excellent holding force
2x12 is overkill honestly.
2x6 or 8 is perfect
I’ve seen 2x4……some hold up some don’t.
Is the foam stiff?
The torque of the springs isn’t static. Door open=minimal load/door closed=max. If the foam is “stiff” it may be fine. I’m not well versed in mounting thru foam.
2x6 or 8 is perfect
Is the foam stiff?
Yes, the ICF is a solid form once concrete is inside the form. It's 2.50" of EPS, 6" of concrete and then 2.50" of EPS.
I'll do the 2x8 or maybe a 2x10 :)
   / Detach 48x28 Garage - Footings #103
I'd still go with the front-mount (jackshaft) opener.
Honestly I have never seen a conventional opener with a garage door that follows the roof pitch. Is that even possible?
But on most doors over 8' tall.....the jackshaft openers tend to be cheaper. Because by the time you buy a conventional opener, then start buying extensions to get the door height you have.....the cost goes up.
I only install conventional openers on 7' and 8' doors.
And the jackshaft openers are easier and cleaner to install.
   / Detach 48x28 Garage - Footings #104
Roof pitch can be either opener style.
I’ve personally done both.
Side space/headroom/duty cycle will dictate which opener is best
2x6 or 8 is perfect
Is the foam stiff?
The side 2x's can be just 2x6, right? They just hold the door tracking rails.
Funny how 2 companies, installing the same exact door, can differ on their bids by $2k. I understand they need to make money but profits vs gouging. After the pandemic, a lot of price gouging has been happening.
   / Detach 48x28 Garage - Footings #106
2x6 will be good for the jambs.
Run them higher than the header “H” will be how they look.
Your installer should have a drawing that shows elevations. I usually go about 6” higher. Countersink your fasteners so they don’t interfere with the door or tracks.
   / Detach 48x28 Garage - Footings #107
2-18x8 doors with roof pitch and Liftmaster 8500 series openers should take 2 guys one day to install
I got the center 2x10 board installed. I used TWO 3/8" Tapcon bolts (6" long) that anchored into the 6" concrete core by about 2" deep. Then I ran THREE 3" long screws on the bottom which anchor into the treated board that is attached to the concrete wall.
Should I run another 3/8" Tapcon where the "X" is shown? That will make 3 total. I don't want to go below the "X" area as the wall rebar is heavy there with #5 bars and also I don't want to interfere with the spring attachment they will install.
Still have to install the top board over the door. Got the center and 2 side 2x6 boards.
   / Detach 48x28 Garage - Footings #110
You’re probably fine with the tapcons you have.
Most openings are framed with the header 2x6 first, then the spring pad sits on top of that.
A couple “toe screws” would attach the bottom of the spring pad to the top of the header.
2022 KOMATSU WA500-8 WHEEL LOADER (A60429)
2022 KOMATSU...
Deere 35P (A53317)
Deere 35P (A53317)
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
2019 CATERPILLAR 239D3 SKID STEER (A60429)
2019 CATERPILLAR...
