Doug Vee
- Joined
- Aug 13, 2022
- Messages
- 200
- Location
- Western Washington
- Tractor
- Kubota L48, Kubota F3060, John Deere 855
New to me, definitely NOT new.
I have the mower on blocks in the shop. I was concerned about the ugly looking gear oil and not being able to drain it completely due to the drain not being at the low point of the housing. I removed the gear box and have it hanging at an angle that should allow it to drain completely...well, all that will run anyway. There will be a coating on everything that probably will not drain. I think I will let it hang for a while, then reinstall and fill it with new gear oil, then drain it after a short interval to flush out the remaining contaminates.
I started dismantling the rear roller bearing assemblies. It is not apart yet, but bolts are mostly loosened. It doesn't look like it will be very difficult to get the bearing supports removed. One bearing is completely. failed.
It looks like the left end of the rear roller has separated from the main body of the roller. I would like to remove it to try and address that, but that looks like it would be a tricky process. The roller support is lower than the bottom of the mower structure, which is what my blocking is under. The roller shaft is longer than the space between the two roller supports, so it looks like at least one roller support must be removed to completely remove the roller assembly. It appears that my roller is described as the "Prior Production" assembly in the manual, dated May of 2006. The roller and the inner shaft appear to be one part in the parts break down, so the shaft does not seem to be removable through the roller.
Does anyone have a feeling for whether it would be advisable to support the mower on the flail rotor with jack stands, at least one end? I am not sure how the fore and aft balance would be affected, but the front side would definitely get much lighter. If this would be safe to do (for me and the mower) it would make it much easier to remove a roller support.
Anyhow, I am sure I will be looking for more advice in the future. Thanks again,
Doug
Doug
