OP
Doug Vee
- Joined
- Aug 13, 2022
- Messages
- 199
- Location
- Western Washington
- Tractor
- Kubota L48, Kubota F3060, John Deere 855
Ha! Your first sentence are the exact words my brother in law usedWow, you are getting after it! here are a couple photos of the SMW hammer. After market from Clean Cutter Tiller Blades. item name MAZ07. Here is a picture of the SMW hammer front and back.
Apparently the existing hammers on this machine are not original equipment.
I was able to remove the roller yesterday. The end cap with the good stub shaft that was askew in the last pictures came off without too much of an issue. The end with the bad stub shaft is another story. It appears is was rubbing so long on the end cap, that the joint between the stub shaft and the rest of the end cap is not whole. I tried tapping down on that stub to see if the end cap would come loose like the other end...no cigar, stub hub broke loose from the end cap.
There are no separate parts listed for the end caps/stub shafts, so I am assuming it will need a machine shop rebuild OR an entirely new complete roller. $$$$
The gearbox is apparently done draining. As noted earlier, there is no hurry to refill, but I have a question on the gear oil level...there is no level plug. I guess that is not too big of deal, a piece of wire could act as a dipstick. The question is- What should the oil level be? I have three other mowers with gear boxes, and it appears that the oil level on all three of them is "a little lower than the center of the gear set/output shaft". The bottom of the level plug is about 1" lower than the center on the 5' rotary cutter (New Holland), and maybe 1/2" lower on the 6' John Deere belly mower. I can't quite see good enough on the 6' Kubota front deck to know exactly, but it is around there.
Doug
