Flail Mower New to Me- Seppi SMO 200 Flail Mower
   / New to Me- Seppi SMO 200 Flail Mower
Just wanted to chime in and say that last week I received my hammers and nuts & bolts for my Seppi, here is a picture of the drum. I am well pleased with how this mulches up the 6 foot plus weeds and woody stemmed bushes. Here is a picture of drum with attached hammers!! I will try to get some pics or video(if I can figure that out) of the mower in action.
blitz,
I received my new hammers and bolts this week also.
I will be picking up 4 sets of hammer ears to replace like in kind on my rotor. I will need to remove the rotor and take to the machine shop for them to R&R the bad ones for the new ones. The rotor looks pretty heavy. The frame will be completely naked, which be a good time to paint it...talk about scope creep.
I would like to ask you- All my new locknuts except 2 threaded all the way to the bottom of the threads on the new bolts, by fingers only. That is not how the old locknuts came off. I had to use a wrench, almost to the bitter end of the bolt. How did your locknuts thread on? Did they have to be wrenched on most of the way? Is there some sort of special procedure of some sort to lock them in place?
I bought new hammers and bolts/nuts from Flail Master. I called them about it and they were not aware how the Seppi "special" bolts/nuts worked. They agreed that some sort of locking arrangement was a must for flail applications. They said they could take them back, or I could buy nylon locking nuts and they would credit me for the cost of the tapered locking nuts that I received. They seemed willing to make sure I was happy, which I commend them for.
Thank you,
Doug
   / New to Me- Seppi SMO 200 Flail Mower #22
Happy mowing blitzen, I look forward to drooling over my keyboard watching your mowing videos.
Leon
Thanks, Leon, for the vote of confidence.
I am a rookie when it comes to video. My best idea would be to sweet talk the wife into recording.
   / New to Me- Seppi SMO 200 Flail Mower #23
blitz,
Thank you,
Doug
Hey Doug, the hammer ears as you called them have a recess on one side for the bolt head to fit in. I put them on by hand until I had to use a tool, and mostly used an impact to tighten. You can see in one of the recent pics that the bolt head is recessed into the ear. That held the bolt and kept it from turning when tightening the nut. Worse case scenario you will have to weld the nut to the bolt
Blitzen,
Thank you for the reply. I have bought 4 sets of replacement ears to repair the bad ones on my rotor. I really like the recess to help with installation removal. My concern is, the new locking nuts that I have don't seem to have any locking quality to them. Unless there is something that needs to be done after they are fully tightened to create the locking quality. Until I bought this Seppi, I had never seen this type of nut.
Looking at the bolts I cut off, the nuts appear like they may have been flattened on the very end of the bolt, maybe.
Doug
   / New to Me- Seppi SMO 200 Flail Mower #25
Blitzen,
Doug
Are the threads a match? I could only hand thread so far and then I used an impact.
Yes, the threads match too well. I could spin 19 out of 21 nuts all the way to the bottom of the threads with my fingers while sitting on the bench. I was thinking they need to only turn two or three threads before having to use a wrench to complete the tightening.
Doug
   / New to Me- Seppi SMO 200 Flail Mower #27
Hey Doug, here are some of the dog ears that I have. These are from SEPPI...
Yep, that's what mine look like. Now the hard work...removing the old ones.
Doug
   / New to Me- Seppi SMO 200 Flail Mower #29
Doug
I've got a plasma cutter that should be able to cut those off.
Ah yes, the plasma cutter...that would be handy! I watched a cool video yesterday demonstrating the process of Arc Gouging. Pretty interesting.
Doug
2011 Ford F-250 Pickup Truck, VIN # 1FT7W2BT3BEC34199 (A51572)
2011 Ford F-250...
2014 Dodge Ram 5500 Chevron Wrecker Tow Truck (A51692)
2014 Dodge Ram...
New/Unused Gold Mountain Container Shelter 20ft x 40ft (A51573)
New/Unused Gold...
T3 Motion Patroller Segway (A51694)
T3 Motion...
2005 Reinke 48ft Stepdeck Trailer (A51572)
2005 Reinke 48ft...
JOHN DEERE LOT NUMBER 72 (A53084)
JOHN DEERE LOT...
