"AGM Car" batteries for less used tractors?
   / "AGM Car" batteries for less used tractors? #31
I did, ambient temperature has a huge effect on lead-acid self-discharge:
Yes, ambient temperature can have a larger affect than the difference between AGM and Flooded lead-acid.
That right-hand column is very telling. Best never to let the battery get that low, and if it does, charge back up as soon as possible.
   / "AGM Car" batteries for less used tractors? #32
Goeduck so true. It is nice not to have corrosion. Many a good battery has been replaced because of it. My first AGM was on my corvette. Difficult to service so I wanted no corrosion. And I still use them on hard to service places
AGM's typically don't have corrosion because they don't off-gas much, if any at all. Lead Acid batteries, even the really good ones, off gas due to the charge cycles.
   / "AGM Car" batteries for less used tractors? #34
So it is off gassing that creates the corrosion on lead-acid batteries? I always thought it was the acid wicking up past the posts. I learned something today.
   / "AGM Car" batteries for less used tractors? #35
Yup, ordinary LA battery cell caps are vented and very near battery posts.
Acid can wick up around posts, that is usually because of over-tightening battery clamps and moving the post during the process.
Remember the old battery strap carriers? They clamped onto the posts with side force, plus the upwards pull on posts. I only use one when that is the only option for removing a battery.
   / "AGM Car" batteries for less used tractors? #36
I never really thought of acid leaking / wicking from the posts, or consequences of the terminal style battery carriers.
My current carrier is the single jaw type that grips the case sides.
   / "AGM Car" batteries for less used tractors? #37
That's where corrosion comes from. I grease up the battery posts on led-acid batteries for that reason with every oil change. That's or spray them with white lithium grease in a can.
   / "AGM Car" batteries for less used tractors? #38
When I need a battery in one of my tractors I pull the oldest one from car or truck and replace that one. You have a warranty on the new one going into car or truck that way.
   / "AGM Car" batteries for less used tractors? #39
I also have AGM batteries I purchased through Amazon at a very competitive price that have worked well in my stand by generator, the BX2660, and my 2016 3500HD Duramax. When the battery in my 7 year old L4060 HSTC finally dies I'll replace it with an AGM as well.
The only problem I had was the offered sizes were limited and I had to use measurements versus standard sizing to find units that would fit my applications.
   / "AGM Car" batteries for less used tractors? #40
personally I use an interstate deep cycle battery with the most cca that will fit the space. never had an issue, I don't charge it except when running the engine. I live in SC so I use my tractor all year so there is really no down time. When this one quits, I will buy another one. Just my opinion and preference.
2018 INTERNATIONAL 4300 NON CDL 26FT BOX TRUCK (A59904)
2018 INTERNATIONAL...
Ratchet Straps (A59230)
Ratchet Straps...
2000 ITASCA SUNCRUISER 37G CLASS A RV (A58214)
2000 ITASCA...
2017 Autocar Xpeditor T/A Heil Front Loader Garbage Truck (A59230)
2017 Autocar...
2000 Volvo Semi (A59814)
2000 Volvo Semi...
UNKNOWN TANK MANIFOLD (A58214)
UNKNOWN TANK...
