1958 641 w/3 speed transmission and Sherman over/under unit
   / 1958 641 w/3 speed transmission and Sherman over/under unit
Champion H10 cross reference chart:
Champion H1 - Alternative spark plugs
Champion H12 cross reference chart:
Champion H12 - Alternative spark plugs
Federal Mogul / Champion heat range chart:
http://www.federalmogulmp.com/en-US...n Spark Plug Copper Plus Heat Range Chart.pdf
Read a thread where it was suggested that the Champion H12 is a good replacement for the H10 in these tractors. Why? H12 looks to be a hotter plug. Is there a reason I should be using a hotter plug? If the H12 or the plugs that cross over to it are the way to go then that's what I'll do, just looking to learn a little as to why.
Thanks!
   / 1958 641 w/3 speed transmission and Sherman over/under unit #52
Can't help you on the spark plugs, although back when I had an old Ford I always ran Champion.
For the drain plugs, I believe they can all be removed with a good Crescent wrench.
   / 1958 641 w/3 speed transmission and Sherman over/under unit #53
   / 1958 641 w/3 speed transmission and Sherman over/under unit #54
Thanks!
I'd go h12. burn off deposits easier. gas today is mor elike paint stripper than gas from 60 ys ago.
your parts hous may have the h12 plugs listed as 512
autolite 437 are equiv to the h12 either are fine.
the h10 and al 236 would make it start and run just as well.
   / 1958 641 w/3 speed transmission and Sherman over/under unit #55
Wasn't able to get up to the tractor today, but I did make some progress in assembling everything I think I'm going to need to accomplish what I want to do: 5 more gallons of gas, fluids and filters, compression tester, basic hand tools, drain pan and empty buckets etc...
Stooopid question, but what wrench(es) should I take with me for the drain plugs - oil pan, transmission, hydraulics, rear end? I should've paid more attention while I was there last, but was happy enough just to get her fired-up and driving under her own power lol
Looking at the weather it should clear up around here Wednesday for a couple days, will try to get up there then and have a go at things.
One last thing, which spark plug works good in this engine? Manual only says H-10 type. Not a big fan of Champion either so I'll probably lean toward the NGK or something. Thoughts?
take a pipe, and a parallel jaw adjustable wench if you have one. just in case, take a pipe wrench too.
take gasket paper ( cerial box, etc ) and a razor to cut new gaskets, and a tube of thread dope for the diffy plug. if you have a cold chissle and a hammer.. take it. very occasionally you have to get the chissle into the rim of a rounded head and tap it around. that or weld a big hex nut to it hanging upside down, then spin it out. :) btdt. :)
Thanks fellas. I'm hoping to get up there later this week.
Will pick up some hotter, H12 equivalent plugs. I don't know what's in there now, but they were pretty black (dry, film not heavy build-up, maybe either too cool or carb set a little rich but didn't look like she was burning oil and all 4 had the same appearance) so starting over with new plugs'll give me a visual benchmark plus blowing a compression and leakdown test will help me wrap my head around what might be going on inside.
Thanks too for the tool info. Have a couple big - as Grandma used to say - "Polish speed wrenches / Mexican socket sets" (crescent wrenches) loaded up as well as my 3/4" drive socket set. Pipe wrench is a good idea, no telling if the PO's rounded anything off or not. Will chuck a piece of cheater pipe in there too.
I'm guessing the locations of the drain plugs will be pretty self evident. On my JD B, there is an overflow by the flywheel that I open when filling so I know the crankcase/transmission is filled sufficiently. What's the system used on the 641, dipsticks?
Soundguy, you mention gasket paper. What will I be removing that I'll have to replace the gasket on? I'm good with making new gaskets, have ball pein hammer will travel, hahaha, but having a hard time visualizing what needs to come off that'll risk damaging a gasket.
It'd sure be different if the tractor were in my own backyard, tough going into this blind you know?
   / 1958 641 w/3 speed transmission and Sherman over/under unit #57
those tractors will have 3 rear sumps:
Diffy. drain is a pipe plug. it may be hard to see if you have a swinging drawbar.. but it is right under the diffy case closes to the back of the tractor. Use some thread dope on it when you reinstall. plumbers stuff.. doesn't have to be fancy.. just something to smear in the pipe threads to help prevent leaks. Fill is on the top cover behind the seat, under your right but cheek area. a flanged plug/cap. it has a gasket under it. It may or may not tear when you remove the fill cap. if it does, cut one out of cerial box or gasket paper or a manilla folder... etc. check level is a pipe plug on the side of the rear housing area near the pto shaft area ( level ) . I honestly can't remember right or left side.. just look for a pipe plug on the right or left side back there.
Hyds has a flanged drain plug ( cap ). It's roughly right under the seat area under the tractor. another flanged cap with a gasket.. usually you do tear this one because the previous owner left it in for 50 years. it has a flanged fill cap, on top cover under seat, under left leg.. convieniently inconvienient to get to... has a dipstick on left side by pto
trans.. fill by shifter.. level check plug on right side aft of heel, just above running board
these are as best I remember. there are some differences between these and naa and the 65+ machines so I mighta mixed up a detail.. but should be close
Roger that. Thanks souNdguy, all good stuff there, I'll report back with pics to help out the next newb in line :)
*EDIT* Thought y'all'd enjoy a pic of our "B" and the beautiful Lady who I'm surprising with this '641. Pic was taken in August of 2011 just as Hurricane Irene was coming up through our little part of Connecticut.
   / 1958 641 w/3 speed transmission and Sherman over/under unit #59
Autolite 437, as soundguy said, on the plugs, which is what I've been using for years in the fords but I do use an NGK plug in my 950 pulling tractor. Can't remember to number offhand but can check later in you need to know.
Kirk
Thank-you Kirk, I appreciate you weighing in. I went to NAPA yesterday, came Home with the NGK 3112 which was referenced in the Champion H12 cross-reference chart I linked in my post above for everyone.
If they don't work out, I'll give the Autolites a try. At $2.90 a pop I can't imagine getting hurt with the NGK's.
First rain-free day here, have other things to get to which'll keep me from the tractor, hopefully get to it tomorrow or Friday.
Couple more months and maybe I can find some accessories (bumper, etc...) at the CT antique machinery show in Kent - IF we're still here. One more thing we're trying to figure out...
2005 Superior Trailers VT130 T/A Vacuum Trailer (A51692)
2005 Superior...
7033 (A51691)
7033 (A51691)
Case 1083 20ft Corn Head (A53473)
Case 1083 20ft...
2023 Ford Explorer AWD SUV (A51694)
2023 Ford Explorer...
2009 Freightliner B2 School Bus (A51692)
2009 Freightliner...
UNUSED Clear Multi-wall Polycarbonate Pane (A53117)
UNUSED Clear...
