3320 300 hour review
/ 3320 300 hour review #21
Thanks KB... I know you are sometimes not around for a while, and I knew you would get back to me when you could. I think I am going to go with a rear blower too. I could buy the rear blower, and the frame mounted front blade for about the same price as the heavier front mounted blower.
I am sure you will be happy with that setup. The Kub front frame mount system is both elegant and tough. Be sure to post photos and a review!
KB
/ 3320 300 hour review #24
i want to know the same thing. I definitely will switch to that upon a BATT failure.
It should be an Optima Yellow-Top model: D51R. If I recall, that was the particular Optima that was the closest in "specs" to the JD battery. That's what I'll be replacing my battery with when it dies, but so far the original JD hasn't given me anymore trouble.
:cool:
/ 3320 300 hour review #25
Thanks WH401, i am in the same status.
/ 3320 300 hour review #26
I have a 2010 model 3320, can I expect battery issues at some point or was this issue resolved on later models? I have just under 10 hours now.
/ 3320 300 hour review #27
I have a 2006 JD 3320 hydro.
After about a year and a half my John Deere battery just up and died one day, luckily while I was in the back yard. I shut it off to grab some lunch and when I returned it would not crank, no prior warning signs. When I went to remove the battery I noticed that it had bubbled over and corroded the battery tray and everything in the area. Maybe this was happening over a period of time as I don't recall specifically checking the battery because there were no problems starting (my fault for not checking sooner). I wanted to replace with original equipment so I got a brand new JD replacement, same model. I watched this closely and in no time it started to do the same thing. I took it back to the JD dealer and got my money back, bought a non-JD brand replacement and have little trouble with this one.
This tractor has been awesome otherwise; I blame the battery design, not the tractor.
/ 3320 300 hour review #28
Yes, Check your battery. You'll see a tube running down from the cap area to allow water/acid to flow away from the tractor.
This is why I love Deere, they're a pain in a lot of ways but they are a rock solid company. They fix the bugs.
Rob
/ 3320 300 hour review #29
Rob
Good to hear, too bad we can't +rep people on this site, I'd give you some. :thumbsup:
/ 3320 300 hour review #30
I have a 3320 on the way and will keep the battery thing in mind for down the road problems.
Now me talk about batteries, I have a 2003 D'max with a RH battery tray that I replaced due to battery corrosion, a 1996 Monaco RV that needs new pull out battery trays due to battery corrosion and you guys have newer tractors with battery trays that have corrosion problems.
So what do all of these have in common? They are using lead-acid or flooded cell type batteries that vent while charging. I never gave it much thought until I started fighting battery corrosion on two fronts. Replace that flooded cell battery with a AGM (Optima) type battery and your corrosion problem will go away. Cost a little more but in the long run well worth it.
It cost me $120 in parts to replace the battery tray on the D'max.
/ 3320 300 hour review #31
Glass mat batteries are OK, we use them in some solar systems when we can't monitor the batteries but they have different charge cycles and voltages. Usually it's a two stage charge. You bring the voltage up to a specific point, say 14.7 fora 12v batt, and then let it run to a float around 14.1 volts. I have made special charge algorithms for my AGM batts but I don't know that I'd use them in my tractor. I'm thinking the life may not be there. I know that Optima has had problems. Also number of charge cycles, the thing that determines battery life, is less than lead/acid batteries.
AGM batteries can vent also but it usually ends them. Over charge or push an AGM and the one way vent lets gas escape ruining the battery.
I suggest you find a way to install a tray into your RV that will stop any acid from doing damage. As far as the new Deere battery it should have a vent and preclude your problems.
Rob
/ 3320 300 hour review #32
Rob
Rob, I think your missing the point and over analyzing the problem. Optima batteries are used in some of the harshest conditions and are a proven product. As for RV battery trays that don't corrode when exposed to acid, good luck finding that.
/ 3320 300 hour review #33
I think my Optima is on it's 4th season. It has been good to me. No muss, no fuss.:thumbsup:
/ 3320 300 hour review #34
I use a local plastic fab company and they weld up PVC trays for some of the coaches I work on. That keeps the corrosion to a minimum. The AGM technology has come a looooong way in the past few years.
Rob, I think your missing the point and over analyzing the problem. Optima batteries are used in some of the harshest conditions and are a proven product. As for RV battery trays that don't corrode when exposed to acid, good luck finding that.[/QUOTE]
/ 3320 300 hour review #35
We do this all the time in solar apps. A cat litter tray with baking soda sprinkled around the edges. Cheap and simple.
(4) MONTREAL RADIAL S/T 205R75R15 TIRES (A60430)
(4) MONTREAL...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
PALLET OF FILING CABINETS (A60432)
PALLET OF FILING...
NEW HOLLAND TC55DA TRACTOR (A60430)
NEW HOLLAND TC55DA...
CAT 930M (A58214)
CAT 930M (A58214)
Deere 310SK (A57148)
