Buying Advice 4wd JD about 80-100 hp
   / 4wd JD about 80-100 hp #1
cleelum
john deere 4030
I am looking at buying a used 6400 series, 7200 series, or 7400 series 4wd JD tractor. I will be disking, baling and snow blowing with it. Does anyone know where I can get overall dimensions on these tractors as I would like to see how much bigger the 2 larger series are compared to my current JD 4030. Tractordata does not have it and I can not find it on the Deere website ? Any comments on these tractors if you own or have had one ? Also I have looked at tractorhouse and machinefinder and they appear to be the best sources for used machines. Any suggestions other than these for finding one. I have contacted the local Deere dealers and they are looking. Thanks for any help.
   / 4wd JD about 80-100 hp #3
my FIL replaced a 4040 with a FWA 6400 and loves it. Not sure what your use is, but that would probably be enough to do what your 4030 did
   / 4wd JD about 80-100 hp #4
Some data...
   / 4wd JD about 80-100 hp #6
Not being exact, but the 6200's - 6400's are about 95" wheelbase. The 6615 and 6715 wheelbase is almost the same as the 7200's & 7400's at 105"s. Then the large-frame 7600's are around 112" wb.
Thanks for the link to TTL - I will study that and compare the tractor's I am looking at. I have been looking on Ebay - but it seems the series I am looking at are not being let go of - at least not on Ebay.
   / 4wd JD about 80-100 hp #8
You may also try tractorhouse, machinefinder, fastline, equipmenttrader, and farmer'sexchange.com (I think)
Pull-Behind Batwing Rotary Brush Cutter Attachment (A59228)
Pull-Behind...
2007 Ford F-550 Flat Bed Dump Truck, VIN # 1FDAF56P47EA84806 (A57453)
2007 Ford F-550...
PT 1000 Gallon Supply Tank (A57149)
PT 1000 Gallon...
Honda UTV (A56859)
Honda UTV (A56859)
2025 Chery 14ft Bi-Parting Gate Cow Motif Style (A56859)
2025 Chery 14ft...
2014 BMW X1 S Drive 28I SUV (A56859)
2014 BMW X1 S...
