Buying Advice 4wd JD about 80-100 hp
   / 4wd JD about 80-100 hp #1
cleelum
john deere 4030
I am looking at buying a used 6400 series, 7200 series, or 7400 series 4wd JD tractor. I will be disking, baling and snow blowing with it. Does anyone know where I can get overall dimensions on these tractors as I would like to see how much bigger the 2 larger series are compared to my current JD 4030. Tractordata does not have it and I can not find it on the Deere website ? Any comments on these tractors if you own or have had one ? Also I have looked at tractorhouse and machinefinder and they appear to be the best sources for used machines. Any suggestions other than these for finding one. I have contacted the local Deere dealers and they are looking. Thanks for any help.
   / 4wd JD about 80-100 hp #3
my FIL replaced a 4040 with a FWA 6400 and loves it. Not sure what your use is, but that would probably be enough to do what your 4030 did
   / 4wd JD about 80-100 hp #4
Some data...
   / 4wd JD about 80-100 hp #6
Not being exact, but the 6200's - 6400's are about 95" wheelbase. The 6615 and 6715 wheelbase is almost the same as the 7200's & 7400's at 105"s. Then the large-frame 7600's are around 112" wb.
Thanks for the link to TTL - I will study that and compare the tractor's I am looking at. I have been looking on Ebay - but it seems the series I am looking at are not being let go of - at least not on Ebay.
   / 4wd JD about 80-100 hp #8
You may also try tractorhouse, machinefinder, fastline, equipmenttrader, and farmer'sexchange.com (I think)
Misc Pallet of Water Pump and Vacuum Cleaner (A57454)
Misc Pallet of...
Wood Native American Statue (A56859)
Wood Native...
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
INOP Kawasaki Bayou 250 Four Wheeler (A57453)
INOP Kawasaki...
2007 STERLING L7500 TANDEM AXLE DUMP TRUCK (A59575)
2007 STERLING...
2018 Dodge Charger Sedan (A56859)
2018 Dodge Charger...
