Advice on potential purchase (Nortrack 3500B)
/ Advice on potential purchase (Nortrack 3500B) #61
Hahaha. No, I don't know what you mean. People have put gasoline, kerosene, and all sorts of wrong stuff in their fuel tanks. Some people even refer to a diesel key switch as an ignition switch. Kinda makes me wonder some time. I am **** about some things.
LOL hahahaha
Changed the fuses and bled the fuel system. Fired right up.
/ Advice on potential purchase (Nortrack 3500B) #63
LOL hahahaha
Probably all you needed to do was bleed the fuel system, and the only time you really need to do that is when you change the fuel filter or (GASP! :embarrassed:) run out of fuel.
On that note,
Where do you get your fuel filters for the dozer?
Do you happen to have the proper part # from a supplier like Napa, ect?
/ Advice on potential purchase (Nortrack 3500B) #65
Probably all you needed to do was bleed the fuel system, and the only time you really need to do that is when you change the fuel filter or (GASP! :embarrassed:) run out of gas.
Fixed it for you:laughing:
/ Advice on potential purchase (Nortrack 3500B) #66
On that note,
I get my filters from NAPA, unfortunately I don't have the numbers with me but I can tell you when I get back to the shop. For the engine oil filter you will have to determine whether you have the metric or SAE filter head - the OEM filters are different but have the same part number. The TY395 engines came with both types.
That would be great if you could post the part number for the proper NAPA fuel filter. I have already covered finding the oil filter.
Thank you so much Bob.
I need to make you dinner sometime. Truly.
I found this information?
NAPA FIL3195 (gold)
/ Advice on potential purchase (Nortrack 3500B) #71
The Puget Sound area is really fortunate to have Bob Rooks and Shield-Arc, two friendly experts!!!!!!!!
Yes. That is what is stated for the fuel filter. I just wanted to confirm with you.
Well you need something. Some sort of kind gesture. Ill think of something.
You help alot. Answer quickly and its educated responses that add value to the discussion.
I just wanted to post, and confirm for anyone who is looking that the filter listed above is in fact correct.
/ Advice on potential purchase (Nortrack 3500B) #78
Very nice. Good work. What a story about the cows.
Hey everyone.
It has been awhile since I have posted.
I have been consumed with working on the jd 1020D and just recently got her up and running again.
Check out my other thread below that has been a work in progress for some time now. Big shout out to Tx. Jim and others who have helped me on the old girl. Gotta love the old iron diesels.
http://www.tractorbynet.com/forums/john-deere-vintage-tractors/372447-1969-jd-1020-diesel-6.html
Now back to my dozer. Over the winter I took out two of the Bradco backhoe cylinders and had those rebuilt.
They were leaking and just needed some good R&R.
It is relatively dry enough here in Western Wa. that I wanted to take it out last night into the pasture. To work the new cylinders, get to tear out some blackberry bushes, and move some rocks.
Well I made it about 15ft out of the barn before my hi-gear selector shaft sheared at the bottom. This was around 6 p.m. last night. Needless to say I was pissed, but I decided to well look into what the **** just went wrong.
I took the top cover plate off, after disassembling both gear selector shafts. The springs, boots, etc.
I then had to drain all of the transmission fluid to find the end of the shaft that obviously was gone. I needed a long magnet stick to get to it.
Please see the photos below. Can someone help me source this part? Or can I have it welded back up? If I can have it welded/fixed does it need to have that same shape as the low-gear shaft? That tapered end?
What material is this shaft made of?
Thanks for the help in advance!!!
Click on the photos to enlarge them.
2019 COLEMAN BT200X MINI-BIKE (A60430)
2019 COLEMAN...
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
2007 FREIGHTLINER M2 26FT BOX TRUCK (A59905)
2007 FREIGHTLINER...
2024 CASE TV450B SKID STEER (A60429)
2024 CASE TV450B...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
UNUSED FUTURE REMOTE CONTROLLED TOY (A60430)
UNUSED FUTURE...
